Hoover dyn9144dg How to reset the machine as its getting stuck mid cycle
  • 1462 Answers
SOURCE: Machine stuck mid cycle
filter blocked or brawire or similiar in drain pump take off cover at bottom rear. take of hose going to bottom of tub. filter is in that hose you will have water everywhere. one way round that is to lay machine on side - left side down viewed from rear
Posted on Mar 20, 2007
aborcass
  • 2651 Answers
SOURCE: manual reset
take note of whoch lights are flashing on back panel, generally i ask cust to take a index card or similar size paper and placedit under your light indicators(wash--rinse----spin)think thers 7 or so lights .noting which ones are flashing when shuts down, will determine problem for you,under main console(2 screws across back) is a tech sheet to help you out
Posted on Feb 22, 2008
aborcass
  • 2651 Answers
SOURCE: KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
Posted on May 12, 2008
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Posted on Jun 04, 2009
SOURCE: can anyone help my hoover washing machine modal
Hi, had same problem the filter was blocked again. It needs to be regurly cleaned out.
Posted on Jun 26, 2010
Spin cycle won't pick up to full speed. It tries to, and sounds like it's trying, then won't, so goes back to slower speed.
sounds like a gearbox bearing failure. To repair this is expensive, I suggest it time for a new machine.
Dec 19, 2014 | Hoover Dynamic 9 DYN9144DG White 600 mm...
I have electric current going into the hoover DYN 9144DG washing machine but no display
board inside these washer has internal safety devices fuses on there pcb
you need to let a tech look at this
sounds like the psu to the controller board has failed
and you need to either replace or repair the controller board
Oct 03, 2014 | Hoover Dynamic 9 DYN9144DG White 600 mm...
Hoover dyn9144dg washing machine door lock flashing wont start.....lock changed still wont start.....light still flashing
Hello the
Plesre and welcome to fixya
can i ask you a question did you unplug the machine and leave it sit for at least 1 hour
See these machines have a internal computer that stores information like any settings that are in the programed in the machine
It normally takes any where from 45 min to at least 1 hour to compete the memory loss on the computer thus resetting the computer ok
so please tell me if you did this if so there is more that we can do ok
Best regards michael
Dec 10, 2013 | Washing Machines
Gets stuck in mid cycle
you need a new timer mechanism
May 23, 2010 | Kenmore Front Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Progam gets stuck mid cycle like any were in the wash cycle
I had this problem with a washer a few months ago. I believe it has something to do with the timer. Not too sure about this washer, if knobs are electric or not.. If it makes a clicking noise where the knob panel is it probably can be fixed fairly easily.
Also another problem that happens is the door switch. These two problems are the main ones for washers that continue to work but have problems in the cycle.
Sep 03, 2009 | Hoover UltraCare HC6 150M Front Load...
Washing Machines Logo
Top Washing Machines Experts
