Question about Amana AAC051FRB Air Conditioner
What type of freon dose ptac use - Amana AAC051FRB Air Conditioner
  • Amana Master
  • 4,655 Answers
Most are switching to R-410a because it is more efficient and cools and heats better that the older R-22 freon. R-22 is supposed to be obsolete this year also. Sea Breeze
Posted on Jun 23, 2009
  • 439 Answers
These are hermetically sealed units and you are unable to recharge them without using a piercing valve. If you are able to do this they normally take r-22 freon, but you need to be EPA certified to purchase it.
Trying to recharge a ptac unit at my hotel with freon where are the hose hookups
It may be sealed, you may need to solder on pressure taps or saddle taps.
Oct 11, 2017 | Heating & Cooling
I have a LG LP150HED-Y8 AC, A CH CODE LIGHT CAME ON HOW DO I FIX THIS?
Low pressure switch will shut down right after starting when it is low on freon. A small amount of freon will get it started but when the compressor starts it moves freon from the low line to the high
Jul 28, 2015 | LG PTAC LP150HED Thru-Wall/Window Air...
What is the average freon charge on ptac
Factory charge and refrigerant type are on the placard of the condensing unit.
Nov 03, 2014 | Amana Heating & Cooling
Have Ptac units that work fine one minute and 2 hours later just blow warm air.. some that also freeze up the front coils
I think your PTAC is under charge, if the air filter is clean and the evaporator is also clean together with the blower. Check the freon charge and refill if suction pressure is below 50psi and discharge is below 190 psi.
Sep 03, 2011 | Amana Heating & Cooling
How do i charge a AMANA Ptac with R22 freon
Also, if you get caught working on ANY freon based refrigeration without a license, you could face a large fine. Freon isn't $3 per pound anymore, it's quite expensive and you don't want any of it wasted. Have a licensed technician do the work. He will know exactly how much refrigerant your system needs, and he can remove what's there and add to it.
Jul 02, 2009 | GE Zoneline AZ55H07D Air Conditioner
Air conditioner donot work.
THERMOSTAT SWITCHBOARD IS MOST LIKELY THE CAUSE DREAMGREENSERVICES.COM HAS ALL YOU NEED TO FIX ALMOST ANY PTAC AC UNIT 770-233-9987
Nov 25, 2008 | LG BG8000ER Air Conditioner
Charging a ptac unit?
Full service both coils first ,add your filter, then add a line temperature probe in the supply air flow or on the line going to the compressor add freon till you get the lowest temperature nad then it will start to climb, you've had the correct charge,!
Sep 08, 2008 | GE Zoneline AZ55H07D Air Conditioner
Filters needed for Old GE Zoneline 2100
My name is brian pfeiffer . I run a ptac business in griffin ga. I have many parts and filters for most all types of ptac units. Please feel free to contact me at brian@dreamgreenservices.com. Nobody can beat my prices!!!! Or call me at 770-233-9987
Sep 03, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Zoneline PTAC short circuit
Most likely you will need to either replace transformer or there may be a low voltage flat type "car fuse" usually 3 amp or 5 amp for just such an occasion. Good luck!
Mar 29, 2008 | GE Zoneline AZ55H07D Air Conditioner
Amana AAC051FRB Air Conditioner Logo
421 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
