Question about Brother MFC9320CW All-In-One Printer
REPLACED THE TONER CARTRIDGE AND IT STILL SAYS REPLACE CARTRIDGE
4 Suggested Answers
SOURCE: Toner Problem.
Is this a remanufactured/ compatible unit? I suspect that the toner reset lever on the cartridge has either not been installed or not properly set. return for another one
Posted on Apr 24, 2009
app_3rp12972
  • 3 Answers
SOURCE: we replaced the toner and it is still saying
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Posted on Jan 28, 2012
SOURCE: brother 9970cdw toner
The Brother printers have a counter which will shut the printer down when the preset number of copies has been reached. You can reset the counter and it should print again. I did this 4 months ago. It bought me a little time, but my printer has begun to print a solid line down the left side of each page. I have cleaned everything that I can access to rule out smudged glass, etc. Perhaps it is just best to replace the drum or buy a new printer(much to Brother's delight and design).
Posted on Aug 10, 2012
We have an error message CRUM 009-367 and we are unable to figure out what is wrong with it on our Dell 3110cn. Thanks
009-367:The Yellow (Y) Toner Cartridge CRUM Data error is detected.
  1. Cycle power on the Printer.
    1. Turn the printer off.
    2. Wait 10 seconds.
    3. Turn the printer on.
    4. Determine if the issue still occurs.
  2. Verify that the toner installed is Dell toner
  1. Cycle power on the printer again.
  2. If the error persists, replace the desired toner cartridge.
    • If the desired toner cartridge has already been replaced, replace the Toner Dispenser CRUM.
    • If the Toner Dispenser CRUM has already been replaced, replace the Printer.
Mar 07, 2011 | Dell 3110cn Laser Printer
I PUT A NEW TONER AND IT IS SAYING THERE IS EMPTY
Are you sure it was a full NEW toner cartridge?? Not an old one you had lying around.
If it was a new one the next question line goes as follows.... the machine will say in the display to "Rplace toner soon"...that dosn't mean its empty and to replace it..that means itsLOW and you should have a new toner cartridge "on-hand" because it will soon stop printing and say "REPLACE TONER". At that time the toner cartridge should be replaced, when it is installed a "fuse" on the cartridge blows and resets the toner light on the display. If you installed the toner cartridge when the display was saying "replace toner soon" you have blown the fuse in the new cartridge, now the machine has run about another 100 copies and says "replace toner"....but you now can't reset the light because the fuse is already blown because you may have replaced the cartridge too early!!! WHAT CAN YOU DO if that is the case...you can replace the fuse on the cartridge..its pretty easy to see, just replace it with another mini-fuse of the same rating written on the existing fuse..then put the cartridge in again..the fuse will blow, reset the light and away you will go. When all else fails read the operators manual.
Jan 23, 2011 | Muratec MFX-1430 Copier
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Samsung sf-5100 fax toner empty
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Mar 05, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Toner and Imaging Unit issues
If this IS a CLP-510, first make an information confirmation print.
Press MENU, then press ENTER, and ENTER again.
Look at the counter for the imaging unit, is it a low count confirming that you have indeed replaced it ?
If not you will need to reset the counter.
Check the counters for the toner cartridges, and check the capacity of the cartridge. On a CLP-510 the image counter for the toner is held on the chip on the cartridge (which also identifies the capacity of the cartridge).
There have been some faulty (oiginal Samsung chips), and of course re-manufactured cartridge chips could fail (many re-manufacturers don' test their cartridges before dispatch, they don't have the facility to do so without starting the count on the chip (or 'bowing' the reset fuse on a CLP-500 cartridge). VERY few re-manufacturers can test these cartridges without starting the count.
Sometimes the 'replace xxxxx toner' messages are caused by toner on the three contacts on the side of the cartridge, or their mating contacts inside the printer. Rarely, this can be caused by a faulty circuit board.
Dec 20, 2007 | Samsung CLP-510 Laser Printer
Brother MFC9320CW All-In-One Printer Logo
90 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
