Question about Breville Kitchen Appliances - Others
Breville kettle illuminates but doe not boil - Breville Kitchen Appliances - Others
  • 274 Answers
SOURCE: new kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
Posted on Sep 11, 2007
SOURCE: Boiling
Purchased at Canadian Tire mid December 07.....great sale....still more than I expected to spend on a kettle. EE and nothing.....same as previous customer comments.
Posted on Feb 28, 2008
jerryg50
  • 1667 Answers
SOURCE: kettle lights but doesn't boil
Most likely the thermo fuse is blown.
You have to take the kettle apart and see the spec for the thermo fuse. You can get these at most any electronics parts supplier for appliances.
To change the thermo fuse you will need the proper crimp type connectors and the crimp tool. This is not able to be soldered. It runs too hot, and soldering in a circuit close to a heating element is not able to be used.
Before changing the thermo fuse, you can test it with an ohm meter. It should typicaly read about 0.1 to 0.2 ohms. The heating element resistance should typicaly read about 8 to 12 ohms.
If the heating element reads below 6 to 7 ohms on a well calibrated ohm meter, or above 15 ohms, it is defective.
If the thermo fuse is blown, the kettle may have been left running when boiled out and over heated, or there is a short in the heating element.
If you feel that you are not comfortable to do this type of repair, it would be best to give the kettle out to an appliance service centre to have it serviced.
When you change the thermo fuse, and if it blows again the heating element is probably damaged. It must be replaced if possible, or if worth the cost.
On the other hand, if the kettle is more than a few years old and you don't want to go to all this trouble, you may want to consider to simply get a new one.
Jerry G.
Posted on Apr 29, 2008
SOURCE: filter for breville kettle jk155
Contact Breville on 0161 652 1211 and they will mail out one
Posted on Feb 26, 2009
SOURCE: Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Posted on May 09, 2010
No lights or boil
I would test the thermo fuse, power switch, and the AC cord. You will need the proper connectors, crimp tool, and replacement parts.
Jerry G.
Jun 21, 2012 | Brita Breville White Filter Kettle Model...
Can I use vinegar to descale my Breville single cup coffeemaker?
White wine vinegar is a great descaler as it can dissolve the white deposits. For kettles, fill them up and leave them overnight. Don't boil it, though - the vinegar will froth up and go everywhere. Afterwards, rinse the kettle thoroughly, fill with water and boil before using it again. Malt vineger can also be used as the malt only adds flavor
May 05, 2011 | Breville BKC600XL Coffee Maker
How do you clean a Breville JK73 kettle. I have lost the instructios.
Put a cup of vinegar and a cup of water into the kettle and boil. Clean with a brush, rinse, boil once with clean water.
Aug 05, 2010 | Breville JK73 Cordless Electric Kettle
How do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
May 16, 2009 | Breville SK550XL Electric Kettle
Filter for breville kettle jk155
Feb 09, 2009 | Breville Kitchen Appliances - Others
Light switch on Breville SK500-XL Kettle
e mail askus@brevilleUSA.com
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Jul 24, 2008 | Breville SK500-XL Stainless Steel Cordless...
Continues to boil and does not switch off.
The termostat or electronic controler is not working properly.
Jerry G.
Jul 12, 2008 | Breville SK85XL Nova Cordless Electric...
Breville spectra kettle, light flashing- cause unknown?
It could mean that the warming element is defective; open.
May 01, 2008 | Kitchen Appliances - Others
Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Apr 21, 2008 | Breville SK500-XL Stainless Steel Cordless...
Kitchen Appliances - Others Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
