Question about A4tech A4 Wireless Optical Mouse MO-NB-30
Why my wireless mouse does not work properly?
My mouse does not work
Wireless mouse and stick won't work
Have you tried to add a mouse pad under it. I have a capricious mouse myself that has to be on a pad to work fine. If you don't have a pad just try it on a dark surface, no glass that's the worst one...
It can also be a simple battery matter, distance is also important depending of the communication technology in use.
good luck
Nov 28, 2013 | Trust Wireless Optical Mouse Mi-4150K
My acer mouse model number mg-0919 stops working after about 2 minutes. I have to turn the mouse off then back on. This happens constantly. What is going on? Is it defective? My mouse is under...
I had the same problem. This mouse came with my Acer Revo which was still under warranty. Tech support basically says to check the obvious (batteries, USB connection, RF interference). Their obviously canned answer goes on to detail a manual reconnect procedure that does not apply to this model. And when all else fails, get a new mouse.
This is what Acer tech support emailed me:
If you are experiencing issues with your wireless mouse not working properly, perform the following steps to troubleshoot the wireless mouse.
1) Ensure that the receiver is 8-inches from other electrical devices. Avoid placing the cordless devices on metallic surfaces.
2) Verify that the USB connector from the receiver is properly plugged into a USB port on the computer. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
3) Remove the batteries and then reinsert the batteries into the mouse, making sure that the battery polarities are correct.
4) Test the batteries to ensure that they still have a charge.
5) Try the manual connect procedure.
Manual connect procedure:
1) Press and release the Connect button on the receiver.
2) Within 30 seconds, press and release the Connect button on the mouse.
If the issue persists, we can replace your computer's wireless mouse.
We will ship the new wireless mouse within 3-5 business days.
Before placing an order for wireless mouse we would like to confirm the following.
1) Complete shipping address:
2) email address:
3) phone number:
In order to place an order for wireless mouse, the computer must be registered.
Oct 06, 2010 | Acer Aspire One PC Notebook
Logitech wireless rf keyboard and mouse quit
To fix the problem,
please press the connect connect button on the bottom of the mouse and the connect button on the reciever and relaese both the buttons together. this would rest the wireless connection and then the mouse should work fine.
regards.
Jan 28, 2010 | Logitech Wireless Access Duo Optical...
My 1023 wireless mouse is not working. When USb
maybe your connecting the usb to far from the mouse because the mouse can only reach the amount that its cabable of.
Oct 29, 2009 | Microsoft Wireless Notebook Optical Mouse...
Hp wireless mouse not working
HP wireless mouse may not work due to improper connection of the receiver. If unknowingly you connect the receiver to a different port, then it may cause serious issue with HP wireless mouse.
If the connected port is corrupt and if the port is experiencing any problem, then the wireless mouse may not work properly.
In order to resolve this issue, you need to repair the port.
Get more information to fix HP Wireless Mouse Not Working . Hope this information helps you.
Oct 29, 2009 | HP Wireless Optical Mouse
Wireless mouse is not working
Hi
Please ensure that the batteries are not down, try replacing the batteries.
Regards
Sep 12, 2009 | Microsoft Wireless Optical Mouse
Left mouse button doesn't work
You need to check the mouse settings.
If the mouse settings are ok. Then you need to replace the mouse.
For more information please visit the below mentioned link.
http://www.microsoft.com/windowsxp/using/setup/personalize/mouse.mspx
Aug 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
Dynex wireless mouse..DX-WLMSE..Left click does not work properly...unless you Press Really HARD...???? What's wrong???
It is the problem of the Hard ware( Mouse). The contact is not get activated on soft clicks. dismantle the mouse. clean the contact points and put the click button properly might solve the problem. if not it should be replaced.
Mar 25, 2009 | Dynex Wireless Optical Mouse
Wireless mouse not working properly
I had the same problem, please check if the batteries are fitted properly, if not the put them properly, it should solve the problem.
Batteries on Mouse/Keyboad and reciever(if any), if its a optical kind of thing, it gives problem, later I got the laser one, it works perfect.
Mar 24, 2009 | Computers & Internet
Wireless mouse
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Check to make sure they are set properly.
Hope this helps. Bud
Jan 01, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
A4tech A4 Wireless Optical Mouse MO-NB-30 Logo
29 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
