Question about Irons
Laurastar iron Check that the filler cap is screwed on tight and positioned properly. Check the condition of the seal. If it is worn, it should be changed
3 Suggested Answers
  • 4088 Answers
SOURCE: I have Laurastar steampump model 01-0165. How
Vinegar and water mix (about 1 to 4 ratio) and run through. Use distilled water only thereafter--rinse through several times to clear out vinegar.
Posted on Aug 01, 2009
ercupa190
  • 12223 Answers
SOURCE: My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Posted on Nov 15, 2012
How can i dismantle a laurastar s4 iron?
not really-- use the correct iron cleaner and if that doesn't work, the damage done dismantling the iron will require a new unit any way
May 11, 2016 | Irons
I have a lauraStar Magic Evolution and Steam is escaping around the filling cap. Alot What do I need to do
rubber fittings destroyed in internal compartment,ervice by expert professional
Jan 12, 2015 | Irons
I have had a laurastar iron bought from John Lewis on the. 16/01/10, it has just exploded on me, please let me know if I Can get in touch with someone to repair it ? I live in glasgow, thank you look
cannot look into your wallet ...but i would just get a new one or secondhand these things are so sensitive with their water connections once you take it apart you cannot get it together again without leaking...
Nov 11, 2014 | Irons
Steam comes out the filler cap on the water base on my Rowenta DG5030
WIre brush the caps screw threads and replace the O Ring ASAP.
DOn't use the iron until you get a new O ring and they need to be the orange/red rubber ones they are able to withstand the hot steam black o rings at home depot won't last.
Jul 24, 2014 | Rowenta Pressure Iron and Steamer DG5030
Nov 14, 2012 | Irons
My new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
Nov 13, 2009 | Irons
Aug 01, 2009 | Hamilton Beach Steam Excel 14770 Iron
Need a new rubber ring seal for the screw off cap
take the cap off or the old o ring and off to the hardware store in the plumbing section
Jul 10, 2009 | Irons
My Braun Si 3120 Optistyle Iron is leaking water from steam holes
Scale buildup is unseating the rubber seal. Disassemble the iron. (Water filler hole part pulls directly forwards and can be pushed out from behind with a screwdriver.) Otherwise it's fairly straightforward. Clean scale off baseplate. Seal with silcone gasket before reassembly.
Jan 10, 2009 | Irons
Does not steam. No pressure being built up.
I do not know if you did clarification request prior to ordering the new part.
Since I am in California, I use the website below for DG-980 parts:
California Electric Service
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
http://www.californiaelectricservice.com/
Hope this helps, good luck and keep in touch.
Apr 14, 2008 | Rowenta DG-980 Iron
Irons Logo
42 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
