Question about Garden
Not start ignition
Key turns ignition lights but doesn't start
Ignition problem
be more specific.... if theres no dash lights when u turn key in on then its the main fuse under hood. if it turns over and wants to start could be ur ecm/ ignition module , ( if theres coils pretty sure its feul injected ur ecm,/or ignition module would be ur coil packs). when u turn the key in on u hear any kind of noise under trunk might take two people for that if not ur feul pump
May 25, 2013 | Cars & Trucks
Avital 4103 when i push start button the ignition lights come on but doesn't start the engine
Try leaving the key in the ignition (but don't turn it) and then try. If it starts then you need to properly bypass the transponder system. If not then most likely you don't have your ignition and/or start wires hooked up properly. On many cars there is a second starter wire that needs to be connected
Feb 17, 2013 | 4103LX 4Button Remote Start System with...
1988 Trans Am will not start when ignition is turned all the way.
Take a test light to the small wire on the starter and have someone turn it to the start position. If the light lights up and the engine doesn't turn over, I would suspect the starter itself. If the test light doesn't light, try it in neutral and repeat test. If it still doesn't light up, it may be the PRNDL switch or the ignition switch itself.
Sep 22, 2012 | 1988 Pontiac Firebird
Security light cons on
try a different key, the light will come on and stay on if the tumbler is not reading the resistor in the ignition key.
if that doesn't work try to start car, then don't turn key off leave it in on position for about 10 until the security light goes out, turn key off then try to start again.
Sep 15, 2012 | 1993 Buick Park Avenue
My plymouth breeze won't start, won't make a sound, but my lights and horn still works , help me.
any real answer yet? did the problem ever get resolved? i have the same problem with my sister's car. too cold to diagnose tonight, but will post the solution probably tomorrow. since the lights and heater works, but ignition and radio arent getting power, my first guess is there's probably a fried fusible link which controls the 2nd accessory power to the ignition switch. will post a solution soon.
Jul 17, 2012 | 1999 Plymouth Breeze
My key doesn't turn in the ignition, its automatic and the shifter and wheel wont move either. Everything is locked how do I unlock it? help pls?
If turning the steering wheel to the left or right doesn't allow the key to turn, it sounds like your tumblers in the lock cylinder have failed. Unfortunately, there is no way to know when this is going to happen, but eventually, it happens. Not a real expensive fix. Replace the ignition/lock cylinder.
Apr 25, 2012 | 1992 Pontiac Sunbird
My 94 Taurus will not turn over. Lights work...I replaced starter then ignition switch. Car will not turn over. It has a history of intermittent starting problems. It may or may not start. Now it...
They have a bad ignition problem. Its more than likely the ignition. Turn the key on, Then right below the ignition theres a hole. take a long skinny phillips screw driver and push it up through the hole and you will hit a release for the ignition. Push it up as you pull the ignition out. Then try to start the car with a flat head screwdriver. Write back if that doesn't work but i have a feeling it will.
Jul 10, 2011 | 1994 Ford Taurus
My 2004 Pontiac Grand Am ignition switch all of a sudden with the key will not turn on or turn at all for that matter this has not happened before Why ?
It sounds like your telling us the key won't turn in the ignition anymore for some reason. If that is the case the problem is one or more of the tumblers in the ignition have fallen, if this is the case you will have to replace the ignition itself or at least the ignition core. If you mean the key turn but the vehicle doesn't start I would start by disabling the alarm system you installed to eliminate the starter kill switch as the source of the problem. Also, if this is the case try jumping the vehicle. If it turns over and starts with a jump your problem is the battery having a dead cell in it. It can have all the world but if you have a dead cell it doesn't have the amperage to turn the starter over.
Apr 19, 2011 | 2004 Pontiac Grand Am
The car doesn´t start the battery is ok fuees ok
Do you have any check engine lights on? Is your anti-theft light flashing? If so, put key in igniton, turn to on (NOT START) leave in on position for EXACTLY 10 MINUTES
As SOON as theft light turns off, try to start.
There is a problem with your key.
May 23, 2009 | 2000 Chrysler Grand Voyager
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
