Question about GPS
Binatone sat nav u435
The sat navs working fine but the volume is on mute ive tried hard reset but the icon on the left hand side screen still stays on mute
SOURCE: navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
Posted on Jun 19, 2008
  • 62 Answers
SOURCE: evesham sat nav update??
Evesham is no longer in business but the following url is for a company that supports their products..
http://www.tewktech.com/
As a matter of fact, I understand this company has ex-Evesham employees. Good Luck and please rate this solution..
Posted on Apr 09, 2009
  • 20 Answers
SOURCE: how do i get updates for my binatone carrera sat
GO TO BINATONE WEBSTIES
Posted on Nov 22, 2009
  • 3 Answers
SOURCE: my sat nav just stays on the start up screen which
Posted on Jan 21, 2010
SOURCE: MY GUIDE SAT NAV 3100 SERIES Car GPS Receiver: my guide sat nav 3100 series update...
switches on but no navigation. Press navigation and it bleeps only but will not change mode for search
Posted on Jun 06, 2010
How can I update map to my Binatone GPS Z430 ?
  1. Sat Nav Binatone Z430 Map Update Free Download
    tags.topshareware.com/sat-nav-binatone-z430-map-update/.../1.htm Nav-U v1.0 is an easy-to-use and completely customizable preview-type menu system that supports both text and image previews and includes custom cursor ...
Jul 22, 2015 | GPS
How do i update my Binotone 430?
You should be able to find out how to correctly update it in the manual. You didn't specify exactly which 430 model you had, but here are the links to each of them. Hope this helps you out.
Binatone R430 Sat Nav GPS Manual
Binatone D430 Sat Nav GPS Manual
Binatone G430 Sat Nav GPS Manual
Binatone F430 Sat Nav GPS Manual
Binatone B430 Sat Nav GPS Manual
Feb 05, 2013 | GPS
Binatone sat nav - when I turn it on the screen flickers and all i get is lines going across the screen.
hi please try reseting the system and calibrate it a couple of times this should work for you goodluck
Mar 18, 2011 | Toymax Binatone Carrera X350 Car GPS...
Sat nav just stopped working today in perth wa, not picking up any sat signal. any way to fix this? is it my sat nav or the sats?
It isn't the sats. They're fine.
Try resetting the unit. Use a paper clip to press the button in a small hole on the bottom.
Try to reset the sats. To do this:
Tap the satellite bars in the lower right-hand corner.
Then, on the next screen, tap the satellite bars in the right-hand margin.
On the next screen, select "Configure." Choose a different configuration. Tap "Done," then "Done" again on the next screen.
Did that help?
Nov 03, 2009 | Tomtom GO 300 GPS Receiver
No volume on my F20
It sounds like you have muted your F20.
If this is the case you need to turn on the Sat Nav (outside so it picks up the Sats). Once the sats have loaded and machine is working. Press the arrow button bottom right, which takes you to map pages, press the screen on an empty area on the map page. This will bring up another on screen menu which gives you another 6 options (these include pausing routes, brightness etc..) one of the options is 'mute' (top right on screen button) press the button once and you should be un-muted.(It is one press to mute and press again to un-mute). Once un-muted, use the side + & - keys to raise and lower volume.
Hope this helps, if you are already un-muted and still have no volume, you may have a faulty unit. You could try a master reset by inserting a pin into the reset hole on the bottom of the unit.
Feb 01, 2009 | Navman F20 GPS Receiver
No audio directions
try doing a hard reset underneath the sat nav is a small slide reset remove sd card first, reinsert and switch on, good luck
May 23, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Sat nav
GO TO PREFERENCES ,LOCALIZE , LANGUAGE, UK OR US ENGLISH . EXIT BACK TO LANGUAGE , TAP VOICE , MALE / FEMALE TAP TICK . ALSO INCREASE VOLUME ON SIDE OF NAVMAN + OR -
May 02, 2008 | Navman F20 GPS Receiver
GPS Logo
287 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
