Question about LG Washing Machines
What is the 0E error code on LG direct drive washing machine
SOURCE: my LG Tromm washing machine
what do the letters UE mean on my Tromm front load washing machine?? PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I P
Posted on Oct 10, 2008
MNTECH
  • 1543 Answers
SOURCE: LG tromm error code 0E
That's not OE, that's DE as in Drain Error. Open the access panel on the lower left front of the machine, use the small hose to drain out the remaining water, then unscrew the large plug and clean out the filter attached to the plug. If there is nothing in the filter, you may have a blocked pump impeller (not very likely as the filter stops most objects) or the pump impeller may have come off the pump motor shaft. If the later, replace the pump motor, as just popping the impeller back on will only result in repeat of your problem.
Posted on Oct 31, 2008
MNTECH
  • 1543 Answers
SOURCE: WHAT DOES ERROR CODE IE MEAN ON LG DIRECT DRIVE
IE = Inlet Error. Check for plugged screens where hoses screw onto machine (especially the cold side). Other possibilies are kinked hoses, valve shut off where hose goes to washer, or a bad inlet water valve (the part the hose screws onto), or even a bad control board or bad wire to water valve.
Posted on Nov 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: My LG washing machine is giving me a dE error
Drain error. It took longer than normal for the machine to drain. This is caused by the wrong detergent, too much detergent, drain hose way too high, slow drain, and my fave: frozen drain. I have your wm2277 deluxe polyunsaturated, 99 and 44/100th% real deal repair manual. Right ova HERE
Posted on Feb 16, 2010
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
AE ERROR PROBLEMS
AE error code : base sensor has sensed water.
Dec 07, 2015 | LG WT4801CW 27" Top Load Washer with 3.7...
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
Oct 24, 2015 | LG WM2301HW Front Load Washer
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Aug 29, 2015 | LG Washing Machines
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
LG washing machine error code 0e....filter clean and machine level but still have error code
The drain pump on the machine could be faulty. This pump cannot be repaired it will have to be replaced if found to be faulty.
Sep 08, 2014 | LG Washing Machines
LG washer has an error code 0E. Any suggestions/
its a drain error not fully drained within 10 mins
Oct 26, 2010 | LG WM-2277HW Front Load Washer
What is the AE error code on LG steam direct drive washing machin
Dec 29, 2009 | LG Washing Machines
My lg is displaing 0e can you tell me what this means.
Drain error, are you using h e soap? is there a kinked drain hose? That code will diplay after trying to drain for 10 minutes
Oct 31, 2008 | Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
