Question about Kenmore 33169 Gas Single Oven
My parmco oven light wont come on - Kenmore 33169 Gas Single Oven
I have a parmco ar900leg gas stove with a multi function oven power. Its been cooking a treat for the last six months when we bought it. was installed by a gasfitter and correctly. Now, the bottom...
u say element not working? so its a gas and electric? If so check the element with a multi meter for continuity. I would say check ur gas safety valve also but u say it does work in grill?
Mar 08, 2015 | Ovens
How do I stop my parmco wall oven from turning off doing cooking
I am having the same issue. I can only cook in it for an hour to two hours at 180 deg and after that it keeps turning itself off
Feb 19, 2015 | Ovens
Parmco OV-1 trouble
check your fuse box for blown fuse first
May 11, 2014 | Ovens
Oven wont light gaves F4
Hi, the F4 error code means Open or shorted oven temperature sensor (RTD)..
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 20, 2010 | GE 30 In Freestanding Gas Range ...
The oven wont light. Panel light comes on and
Attach a amp meter to the ignitor wire. If you read 3 amps or less,replace the ignitor. 3 amps or more replace the gas valve.
Sep 06, 2009 | Ovens
Stave works but oven wont light,not getting gas
May be your ignitor. You'll need to replace this to get it to work. Hope this helps you.
Aug 14, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 | GE Ovens
Magic chef oven wont turn on
yes oven ignightor to confim this try broil if it lights then its bottom oven ignightor get back wit me ill outline procedure
Dec 29, 2007 | Ovens
Kenmore 33169 Gas Single Oven Logo
24 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
