What is mac error code-8003
I try to empty trash and get eror code-8003 why?
    Problem Solver:
  • 10 Answers
Try
http://www.macupdate.com/app/mac/8214/trash-it!
Posted on Jul 22, 2014
    Master:
  • 630 Answers
If you are a Mac user then I know you have experienced this. You've been deleting files and your Trash Can is showing that there are items in it. You try to empty the trash and all of a sudden an error window appears. It probably looks something like this.
I share a link please visit and read it.
http://www.easypctutorials.com/how-to-fix-error-code-8003-os-x/
Thanks,
Apple Support
Posted on May 29, 2014
Error code 311
The Error 311 indicates a communication error between the Mac and the printer. If you upgraded the Mac from Leopard to Snow Leopard, there could be older driver files for the iP4300 that are conflicting with the new driver. Therefore I would start your repair by trashing all of the Canon files.
The first step is to disconnect the USB cable between the printer and the Mac.
The next step is to delete the current printer queue for the iP4300. Open Print & Fax, select the iP4300 in the list and click the minus ( - ) button to remove the queue. You can now exit Print & Fax.
The third step is to remove the Canon files. These are located in HD > Library > Printer > Canon > BJPrinter. Select all the files inside this folder and trash them. Then empty the Trash and restart the Mac.
With the Mac restarted, you can now run the installer for the 10.6 driver you downloaded from the Canon web site. Ensure this driver is version 10.26.0.0.
Once the driver has been installed you can connect the iP4300 USB cable to the Mac again and open Print & Fax. If the install has worked, the printer should automatically appear in the Printers list (note that this can take several seconds). If the printer does not appear, click + to add and select the Default view. The iP4300 should appear in this view. Select it and click Add. You may get a prompt stating the printer is already installed. If so, cancel this install and try printing with the new iP4300 queue.
If the error message still occurs, then I would try another USB cable. They have been known to cause the 311 error.
Nov 09, 2015 | Office Equipment & Supplies
Tip
Mac OSX Keyboard Shortcut To Empty Trash
To Empty Trash:
Command Shift Delete
To Secure Empty Trash:
Shift Command Delete
on Jul 10, 2014 | Apple Leopard 10.5 Osx Mac Operating...
Tip
Easy way to empty trash on a Mac when it tells your files are in use.
Ever try to empty your trash on your Mac and the system gives you an error telling you that a file in the trash can is in use and it will not allow you to get rid of it no matter what you try? Well, here's a little trick to help you get around this.
1. Open up terminal and type "sudo nano .bash_profile" and input your administrator password. This will allow you to view and edit this text file. We are going to use this to create an alias.
2. Click inside the terminal window to take control of an active cursor and use your arrow keys to move around. Type alias emptytrash='rm -rf ~/.Trash/*' into the window. Be sure to type the command exactly as shown otherwise you may end up deleting something you didn't intend to.
4. Press the "Control" key plus the "O" key to write the text out to the file and press enter to accept the default file name.
5. Press the "Control" key plus the "X" key to exit.
6. Close the terminal window.
Now any time you run into the issue of being unable to empty your trash due to stuck files, you can just open up terminal and type "emptytrash" and hit enter. Doing so will automatically run the 'rm -rf ~/.Trash/*' command and clean out your trash can for you, regardless of what is in there.
A video tutorial can be found here at the bottom of this tip.
I hope this helps!
on Jun 28, 2011 | Computers & Internet
Error code 8003
Copy/paste ONLY the following in to a Terminal window (in Applications>Utilities.) sudo rm -rf
Then, important, leave a space and drag in the item you want to remove. Then hit return. You will be prompted for your admin password, which when you enter it, won't appear anywhere and you will be given a warning. Proceed by hitting return again. Note: it won't go to the Trash; it will be deleted immediately. When finished, just close the Terminal window.
Jan 21, 2014 | Apple Computer Mac Mini 2.53GHz Intel Core...
Fixing error code 8003 on macbook
Did you modify your Time Machine files in any way using Finder or the command line? This can cause this error. There's a program called Trash It that might be helpful if all you want is to get rid of those files.
Jun 29, 2012 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Deleted wrong bloggie videos trash is empty how to restore? using a MAC
Take a look at this article: How to Recover Files Deleted in Trash Mac.
Note: before recovery, do not put more items to the Macintosh HD where those trashed stuff originally located. Best regards.
Jun 03, 2011 | Computers & Internet
Empty trash
try closing all programs first, then go to trash can and hold "ctrl" and left click. Then click empty trash, this should let you can everything unless you are trying to trash an application that is still running. To find out if you are hold "apple, FN, ESC" it will bring up task manager.
Oct 08, 2008 | Apple iMac 24" Desktop
Flip video camcorder says camcorder full and then camcorder empty
I found the solution!
Just put the Flip camera back into any computer on which you deleted files — then, with the Flip camera still attached, empty your trash bin.
All of the time comes right back. The only catch is if you have deleted files on many different computers. At some point, you will have to go back to those computers, insert the Flip, empty the trash and then you'll get your minutes back.
It's awesome. I am back in love with the Flip.
GERSH
Jul 01, 2008 | Pure Digital Flip Video Ultra Camcorder
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
