Question about Janome Sewing Machines
Stiff to turn unless presser foot is up
Have oiled all main points but with presser foot down turning machine by hand it goes very stiff as looper starts to cross needle .loopers are not bent.
SOURCE: BabyLock Proline upper looper thread keeps breaking
I ended up switching the spools of thread around. Apparently, even though I had purchased good quality threads, one of the spools was wound in a way that made the thread loop and twist around. So I put the offending spool of thread through one of the needles and put the needle thread on the upper looper. That seems to be working. By the way, BabyLoc was very unhelpful dealing with this problem.  Thank you!
Posted on Sep 09, 2008
SOURCE: thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Posted on Mar 29, 2009
Australian S
  • 46 Answers
SOURCE: Viking Huskylock 910 Upper Looper problem...
You will find that it was most likely the top looper has moved to the left too far, undo the looper clamp and press the looper to the right by about 3mm. Then turn the machine over to see if it still hits anything, when the top looper comes up past the bottom looper there should be about 0.5mm clearance between the two. Try this first please.
Also the arm shaft may have moved. Trace the shaft back to where there is a clamp type crank with usually a hexagon head clamp screw. Loosen this and set the top looper so as the eye of it is just past the needle when it is all the way up and to the left.
You are correct in not using the machine under power, turn by hand when you think it is correct and make sure there is nothing hitting.
Posted on Jul 07, 2009
SOURCE: The needles on my Janome 9102D keep breaking
I had a similar problem with my machine. What I've started doing with mine is setting the stitch length at 3 and the differential feed ratio at 1.0 then I set all 4 thread tensions at 3. I thread the machine from right to left, and then when everything seems to be working okay I take scrap material to test the tension and then set them to suit the material I'm using. Right now I'm working with a twill so my settings are 4-4-5-5. This seems to have stopped the thread slipping off the bottom looper and I haven't had any more needles break. I hope this is helpful.
Posted on Sep 01, 2009
WonderTech
  • 268 Answers
SOURCE: When i use my janome overlocker the needle is
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach
your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into
the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for
sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,
left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or
pressure foot.
I hope one of these solutions help you.
Posted on Sep 15, 2009
New home combi
First, be sure to have the presser foot in the RAISED position when threading the machine. When threading the tension disks, give each thread an extra little tug to make sure it is seated completely.
Start with brand new needles.
Be sure to thread the machine in the order recommended for the machine--most machines are 1) upper looper, 2) lower looper and the thread tail drapes over the upper looper, then 3) the needles. Pull all of the thread tails toward the back of the machine and under the presser foot.
Start out with the tension disks set at the midway point--this is the general tension for basic overlocking, but each machine is different and they may need to be tweaked to get them where they look best.
Perhaps you can find a manual.
New Home Sewing Machine Manuals PDF and CD
Make It Handmade Threading Your Serger or Overlocker
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjrmPaHhtnOAhVTHGMKHeY4BLcQFggeMAA&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fsergers%2Finst-book-7034d-english.pdf&usg=AFQjCNFntgvjSwJ-8qZxc6muEqF4gx_kAw&cad=rja
How to Thread Serger Overlock Machine
Janome Domestic Overlocking Machine Tutorial (this instruction threads the lower looper first!)
Note--be sure to clean and oil your machine frequently--probably every time a project is completed or more often as needed! Open the looper door and remove the lint & loose threads from inside the machine and then apply a drop or two of good quality sewing machine oil (or Tri-Flow Synthetic Lube) every place where metal rubs on metal. (Slowly rotate the handwheel and watch where things move.)
Aug 23, 2016 | New Home Sewing Machines
Difficulty to do needle threading on S4D overlocker
Sergers are absolute "bears" when threading compared to sewing machines. If/when you get frustrated, walk away. It took me the majority of one day before successfully getting my first serger threaded properly. Using four different color threads is also helpful when learning the serger--especially when it comes to adjusting the tension.
It is very important to pay attention to the order the threads are threaded, as well as making sure the thread path for each is correct. (Consult your owner's manual as different brands will look different.) Most machines require that the upper looper be threaded BEFORE the lower looper because the lower looper thread will cross OVER the upper looper thread as the final step before going under the presser foot.
ALWAYS RAISE the presser foot when threading!!! This releases the tension disks.
Also, when threading through the tension disk, be sure to give the thread an extra little tug to make sure the thread seats firmly in the tension disk. (Grasp the thread just below the thread stand with one hand and then grasp the thread below the tension disk with the other hand and give a little tug--sometimes it will make a little popping noise when it seats.)
Start out with the tensions set at the midway point. From that point, you can test your machine to make sure it is serging properly. Then you can adjust the tensions to suit you or the project you are making.
If the either looper thread breaks or pulls out, remove BOTH looper threads and rethread from the beginning!!! Trying to finagle threading of only one thread will most often result in a machine that will not operate correctly. Just bite the bullet and rethread both threads (in the order specified in the manual).
I seem to have trouble using the tweezers to thread the looper eyes, so I use dental floss threaders instead.
floss threaders Google Search
One more hint: NEVER pull the thread out of the machine by pulling it UP through the machine. This could damage or wear the tension disks. Always clip the threads just below the thread stand, RAISE the presser foot, and then pull the clipped threads DOWN through the looper eyes and needles.
Be sure to clean and oil your serger frequently. This is very important to get the best performance from your machine. Use only fresh oil recommended by the manufacturer and apply only a couple drops each spot.
How to Thread Serger Overlock Machine How to Thread Serger Overlock Machine
Empisal Overlocker S4D User manual
Jun 14, 2016 | Sewing Machines
Model 3434D. Why does lower looper thread keep breaking?
Usually thread breakage is due to incorrect threading or tension set too tight. When thread breaks, the Best Course of Action is to clip all the threads between the thread tree and the tension disks, Raise the presser foot, and pull all the threads down and out. (Never pull threads up through the tension disks.)
RAISE the presser foot, rethread each and every thread in the order specified in the manual and confirm that each thread path is correct. Grasp each thread between the thread tree and the tension disk with one hand and with the other hand grasp the thread below the tension disk and give a little tug to make sure each is seated firmly in the tension disk. Also on most machines, the lower looper thread must drape over the the upper looper before being pulled under the presser foot.
Lower the presser foot and set each tension guide to the midway point (the factory standard) and retest.
Usually, rethreading only the broken thread will fail. (For some reason, sergers are very finicky.) Just bite the bullet and rethread each and every thread.
Feb 22, 2016 | Janome Sewing Machines
Forming stitches beautifully, but not on the fabric
Be sure to RAISE the presser foot when threading the machine so the tension disks are open to accept the thread. It also helps to grasp the thread between the thread tree and the tension disk and with the other hand grasp the thread below the tension disk and give the thread a little tug to make sure it is seated all the way in the tension disk.
Of course, make sure that the machine is threaded in the proper sequence--check the owner's manual (usually the upper looper is threaded first, then the lower looper and the lower looper thread tail is draped Over the upper looper in the last step before being pulled under the presser foot).
If the thread breaks or comes unthreaded, Best Course of Action is to remove all the threads and rethread from the beginning. Nine times out of ten, trying to rethread one thread will not work!
Also, when removing thread, it is not a good idea to clip the threads between the thread tree, raising the presser foot, and then grabbing the thread tails at the presser foot and pulling all the thread ends down. Threads should not be pulled UP through the tension disks.
Feb 22, 2016 | Sewing Machines
Left needle not sewing
Assuming this is a serger/overlocker...
Check to be sure the left needle is installed all the way in the holder. Sometimes debris (threads, lint, etc) accumulate and prevent the needle from seating properly. Use the needle holder tool to hold the needle up while tightening the screw.
Cut all the threads between the thread tree and tension disks. Set all the tension controls to zero. RAISE the presser foot and pull out all the cut threads (always pull them Down through the machine, never Up).
Now, with the presser foot still RAISED, rethread each thread in the Order specified in the manual. Give each thread a little tug when pulling it through the tension disk. Make sure each thread is threaded through every guide as instructed. (Usually the upper looper is threaded first, then the lower looper--if this is your sequence, be sure to DRAPE the lower looper thread over the upper looper in its last step.) Then thread the needles. Pull all the thread tails under the presser foot and toward the back of the machine.
Now, lower the presser foot. Set all the tension controls to the midway point and test.
Feb 06, 2016 | Sewing Machines
Turn wheel not turning easy
Hand wheel "stuck" because you have an obvious jam. Remove bobbin and clean bobbin case, put good quality sewing machine oil on oscillating hook and put new needle in flat side toward back all the way UP, and make sure presser foot UP when you thread machine. Jimmy
Apr 07, 2012 | Brother Sewing Machines
I dont know how to thread this serger. i dont
Have you opened the front of the serger to see if there is a threading guide.
Basically:
Lift the thread antenna to it's highest position.
Lift the presser foot and set the tensions to zero.
Turn the handwheel so the loopers are at their highest point.
Begin with the upper looper (first thread cone on the right/ end of looper is pointing toward the presser foot). .
Second spool is for the lower looper (end of looper is pointing away from the presser foot).
Third spool, right needle; fourth spool, left needle.
Be careful that the threads do not cross during the threading of the loopers.Follow all the guides, taking the thread under the presser foot and to the left side of the serger.
Set the tensions back to 3 - 6 and lower the presser foot. Sew a few inches and if the threads knit into a chain, you can then do a test sew with fabric.
Simplicity's Simply The Best Sewing Book has good information with regard to using a serger that you may find beneficial.
Feb 24, 2010 | Sewing Machines
I need a replacement manual for Babylock Xscape BL66
You will need to contact a BL dealer to order a manual, if any are available. This model has been replaced.
There is a threading guide in on the inside of the door on the front of the serger.
Raise the presser foot and set the tension controls to zero.
Turn the handwheel until the upper looper (curved looper) is at it's highest point - there may be a mark on the side of the serger and handwheel for aligning to this point.
Thread the upper looper first, then the lower looper, then the needles.
Pull the threads under the presser foot and to the left side of the serger.
Set the tensions back to 4 - 6 setting, lower the presser foot and stitch a chain before serging fabric.
You may be able to find a free manual download at the Brother website for a similar product.
Feb 20, 2010 | Baby Lock Sewing Machines
Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Feb 19, 2010 | Juki MO-734DE Mechanical Sewing Machine
Jul 06, 2009 | Husqvarna Huskylock Computerized 910
Sewing Machines Logo
19 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
