Question about 2002 F550
No fuel pedal - 2002 F550
    Scholar:
  • 135 Answers
What? Is it missing ?
{Please be More Specific} When You describe a Problem,it is Not easy as it is to answer some of these problems without a decent discription of the Problem
Posted on Jul 18, 2014
1994 Chevy 3500hd 6.5 turbo diesel starts then stalls. I have to pump the gas pedal a lot before it starts again. Once started, it runs rough. Specially when I step on the pedal.
As there is no connection between the accelerator pedal and the fuel system then pumping the pedal will have no effect.. I would be checking and bleeding the fuel system from the filter to the pump and checking for a leak in the fuel supply system. Hard starting and running rough is an indication of air in the pump and in the lines to the injectors.
Sep 15, 2013 | Chevrolet Silverado 3500HD Cars & Trucks
1997 ford contour
hold pedal to floor and it tries to start ! Not sure if your vehicle has clear flood mode , Most vehicle have clear flood mode strategy programmed in the ECU , PCM ,ECM .when you hold the accelerator pedal to the floor the engine computer cuts down on the injector on time to clear a flooded engine .
Fuel pressure regulator problem ,maybe ! You say there was a blown fuel pump fuse an you replaced it ? Fuse's don't blow for no reason ? Fuel pump bad , short , too much current !
Disconnect the mass air flow sensor an see if it starts !
Apr 24, 2017 | Cars & Trucks
Car won't stay goin without foot on gas
There has to be a story about that situation
Share it with us ---the long version & what possibly
could we do for you ,IF --you never work on your
own cars,if that is the case
Dec 07, 2012 | Cars & Trucks
Where is the carbeurator?
There is no caberator, It is fuel injected,
Dec 01, 2012 | 2006 Ford Freestyle
1999 cavalier hard starting if hold gas pedal to floor it will eventually start.
Holding the pedal to floor should not do anything because the car is fuel injected...
You may check your fuel filter.. it sounds like its taking along time for fuel to start engine...
The fuel filter is located on the cross member just forward of the fuel tank....
Jun 14, 2011 | 1999 Chevrolet Cavalier
Stuck gas pedal cause the car not to start
Yes, if the gas pedal is stuck fullt down the Throttle Sensor located in the throttle body will note the throttle position and shut down the fuel injectors. If in the future your fuel injected car becomes flooded, hold the gas pedal down and turn the engine over this will help free the engine of too much fuel.
I hope this may have assisted you,
Tom
Oct 21, 2009 | 2002 Mitsubishi Galant
I don't here a humming when key is turned on. Electric fuel pump ?? When I pump gas pedal it some times starts after it sits a while.
Could be a fuel pump although they normally only hum very briefly and change to a clicking sound that means they are maintaining fuel line pressure that was built up quickly when the ignition is turned on.
BTW; pumping the gas pedal is a good way to flood the engine; if the choke is still operational, pressing the pedal once to the floor and then releasing it should set the choke and enrich the air-fuel mix for starting. If the engine get flood, holding the gas pedal to the floor will help dry out the plugs so they can fire again.
Oct 04, 2009 | 1988 Ford Econoline
Engine will start will run with pedal pressing the fuel but will shutdown everytime i release the fuel pedal for a 1994 chevy astro
well it could be the module but it sounds to me like a fuel problem have you checked if while van is warm if the fuel pump is matainng fuel pressure
Jul 20, 2009 | 1994 Chevrolet Astro
Motor bogs down at stoplight when pushin gas pedal
The fuel pump relay will cause a stalling or no start condition. You are likely having mass airflow sensor, fuel pump, or fuel pressure regulator issues.
Bret
RepairPal.com
Nov 08, 2008 | 1985 Volvo 740
2002 F550 Logo
23 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
