Question about Husqvarna Garden
How to remove carb on husky 135 chainsaw? - Husqvarna Garden
  • Husqvarna Master
  • 1,807 Answers
3 Suggested Answers
  • 149 Answers
SOURCE: how do you remove the drive sprocket from the
the clutch is Left hand thread. you can use a drift and hit it at the star part.
Posted on Jun 29, 2010
  • 4088 Answers
SOURCE: carburetor tool
Unless you are skilled enough to make your own, you are stuck taking the saw to a servicing dealer as they are the only ones allowed to possess the necessary 'D' head screwdriver. Give thanks to the EPA for mandating the prevention of mal-adjustment pollution.
Posted on Jul 07, 2010
Husky genenaortor 5000 will not idle down
Maybe drawing air into the system, check the fuel line, carb and gaskets
Apr 09, 2016 | Husky Garden
Husqvarna husky boy 50cc My 6 year old son has a husky boy 50cc it starts up an ticks over fine but wen he turns the accelerator the engine starts to cut out then when he releases the accelerator it fires...
If equipped with a spark arrester then you should remove, clean and reinstall. If you don't have a spark arrester then you need to have your carb looked at
Jul 18, 2014 | Garden
Chainsaw chain keeps running
This is a carb adjustment issue and needs to be rectified before using it again, the L jet on the carb is set too lean, if you cannot correct yourself i would suggest taking it to the local chainsaw shop.
Jan 19, 2014 | Husky Garden
Huskvarna 240 isnt getting any gas? there is spark
Carefully check the integrity of the gas line in the tank...make SURE the fuel filter is absolutely clean. If that's all OK, maybe you need a carb kit....try not to run ethanol gas if you can...it destorys small carbs on chainsaws.
Sep 23, 2011 | Husky Husqvarna Chain Saw 240E w 16in bar
Husky 61 lots of spark fuel is getting to carb cylinder is dry wont start would comprison be bad?
Two stroke engine have a reed valves, or something like it, that prevents exhaust pressure from causing the gas to back up.
Because of long idle times in the winter, if you don't use a fuel stabilizer, the gas dries up an leaves a sticky varnish residue.
This not only plugs up orifices, but glues the reed valve either shut or open. Either is bad. So you probably have to take the carb off and clean it to remove the varnish.
Aug 26, 2010 | Husqvarna Chainsaw Piston Kit for 61...
Carb assembling question
Thanks Jerry.
The only that came to my mind is to try here:
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did a quick search and saw nothing for a 61 carb but it does not mean it is not there. Someone at Arborists has rebuilt your carb. The hard part will be digging them out then dredging up the right memories. Good Luck. HTH Lou
Mar 05, 2010 | Husqvarna Chainsaw Piston Kit for 61...
My hUSKI 395 is stalling when i pull the throttle wont rev
So, it idles ok but when you go for any extra throttle it dies?
Your carb may have a blocked main jet. You can removed your carb and after taking off the top and bottom diaphragms remove the main jet and blow through it with a splash of gas *(no carb cleaner! Some carbs are coated and carb cleaner can strip off this coating. Ruining the carb)
Use compressed air to help clear out the main jet passage and reassemble. Be sure you know how many turns your carb main jet needs to be set at before you remove it! Usually its 1-1/2 turns.
You should check online for a Husky website that may have additional guidance.
Good luck and be careful.
Dec 29, 2009 | Husqvarna Garden
Fuel filter replacemfnt on husky chainsaw model 345
the feul filter will be in the tank disconnect feul line from carb and access through filler cap you will need a pair of long nose pliers remove through the tank
Apr 05, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Leaking petrol
Hi bob
Below the carb there are towards the cilinder:a gasket,a plastik suport and another gasket.Check the gaskets from there.Also the 2 bolts of the carb should to be tightened.
cheers savumihai71
Dec 13, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
46 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
