Question about agoda.com
Why i cannot open agoda website
The agoda home screen only appeared for a few second and then goes to blank white screen
Why can't I log in?
Will not open. Just continuous loading.
Aug 22, 2015 | Evermoremedia DoubleDown Casino
If you've already booked with agoda then please contact them to make changes in your booking.
May 15, 2013 | agoda.com
When I switch my laptop on and it gets to the log in screen, after I type my password and click log in the screen goes blank for a few seconds then a white screen pops up saying navigation to the webpage...
Click Start/Control Panel and look for Display or Appearance and Personalization. You can also just Right Click on an empty space on your desktop and select Properties. When the Display appears, click the Desktop tab and select a background.
May 18, 2012 | Acer Computers & Internet
IPhone Smartphone: I can get the apple to appear on the screen, then ...
Boot holding power and home at same time. After 10 seconds, release power and continue to hold home screen for another 30 seconds. The screen will stay blank but should put phone in DFU recovery mode. Plug into iTunes and recover.
May 16, 2010 | Apple iPhone Smartphone
Toshiba M300 screen turns white blank.
White screen means that your lamp (back light) is working absolutely fine, but you could have a loose connection for the data ribbon cable, which sends the images to the monitor.
Carefully open laptop to reach its lcd, there must be ribbon cable which looks like this: mrc-0069.gif
It is very sensitive so be very careful with that, very gently remove this from the chip and reconnect it.
Hope this helps, Please feel free to ask me any further.
Apr 10, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 29, 2009 | Apple iPhone 3G
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Blank grey screen appears for few second & goes.
hi..thats the problem in your phone.So take the
phone to the service centre with your warranty
bill.
check it out..
thank u..
rate me..
Feb 13, 2009 | Sony Ericsson w580i Cellular Phone
Phone does not turn on all shown on screen is a still hour
Pull the battery and reinsert, you didn't lose anything. ;)
Jan 19, 2009 | AT&T Blackberry Curve 8300 Smartphone
agoda.com Logo
98 people viewed this question
Top agoda.com Computers & Internet Experts
David Payne
David Payne
Are you an agoda.com Computer and Internet Expert? Answer questions, earn points and help others
