I just purchased a great condition Philips-Magnavox 7P6033 rear projection TV. Where can I find an owner's manual for this TV? Also, is there a code to set the convergence?
    Master:
  • 752 Answers
I tried the magnavox website: http://www.magnavox.com/support/download_list.php?model=7P6033+
there was no manual for that model. You might try contacting support and asking.
Or you could go here, $17 for a manual apparently
(by download; paper is $25)
http://www.servicemanuals.net/ServiceManual/MAGNAVOX/7P6033/pos1/results.aspx
12.May.2014
Posted on May 12, 2014
ctf1800
  • 4402 Answers
SOURCE: philips rear projection tv 43pp8545 no picture sound ok
do you get a blinking read light?
Posted on Dec 14, 2007
  • 1153 Answers
SOURCE: Magnavox Projection Model # 9P5034 C101
Yes you will need to discharge any electrical equipment before working. One way of doing this is keep equ. unplugged for sometime or after unplug short hot to ground which will most times cause a spark. You can go to vancebaldwin.com or andrewelectronics.com or any online parts store and get the part number off old IC, yes these are on the convergence module. They are big STK's, also there are resistors that will need to be changed and maybe pico fuses.
Posted on Jan 05, 2008
Hauleywood
  • 9 Answers
SOURCE: no color adjustment
*CONVERGENCE SERVICE MODE PROCEDURES*
*Note: This procedure is required for all of the following geometry and
convergence adjustments.*
*Using the remote transmitter, enter the following seven-button sequence to
activate the convergence mode.*
* 06 - 25 - 97 - Menu (M)*
*The "Opening Menu" will appear offering choices:*
*Channel 3*
*Use Channel up/down to*
*Select a Channel with Video*
* Remote control key functions:*
* Use arrow up/down and left/right: Adjust Convergence*
* M: Advance "cross" location*
* Up, Down, Left, Right*
* 3: Exit Convergence*
* Status: Abort/Cancel Changes*
* M: Begin Convergence*
*Note: video information must be present to correctly adjust the
convergence. A signal source is required to lock the vertical and
horizontal sync. After entering the "convergence service mode" verify the
presence of a video source by confirming the presence of active audio (use
the volume up function on the remote). Use the channel up and down function
on the remote to select the desired tuning source.*
*Select item "M" from the first menu, the "Convergence Menu" will appear
featuring 5 possible selections.*
* Channel 3*
* Convergence:*
*1. green geometry*
*2. red To green Convergence*
*3. blue To green Convergence*
*4. green To red Convergence*
*5. green To blue Convergence*
*CONVERGENCE TOUCH UP PROCEDURE*
*1. Enter the "convergence service mode" as described above in the
"convergence service mode procedure".*
*2. Select the desired color requiring adjustment. Note: Do not
select Green Geometry (1). This procedure is described under "Major
Convergence/Geometry Alignment. If Green Geometry is altered during this
procedure a "Major Convergence/Geometry Alignment" maybe required. *
*3. Cover the Output Lens of the single color presently NOT being
adjusted. Example: If you select Green to Red Convergence (4) cover the Blue
Output Lens.*
*4. The highlighted adjustment Icon (Cross) should be illuminated on
the middle left side of the screen. Make the necessary Convergence
Adjustments using the following Remote Keys:*
*· Use the Arrow Up ( ) to adjust the selected color up.*
*· Use the Arrow Down Key ( ) to adjust the selected color down.*
*· Use the Arrow Right Key (-) to adjust the selected color to the
right.*
*· Use the Arrow Left Key (+) to adjust the selected color to the
left.*
*5. Move to the next location to be converged. It is not required
that the full Convergence Sequence be followed while performing the
"Convergence Touch Up Alignment Procedure". The following alternate Remote
Keys allow for positioning of the Icon to the desired adjustment location:*
*· Key 2 on the Remote Transmitter will position the Adjustment
Icon upward on the screen.*
*· Key 8 on the Remote Transmitter will position the Adjustment
Icon downward on the screen. *
*· Key 4 on the Remote Transmitter will move the Adjustment Icon
to the Left.*
*· Key 6 on the Remote Transmitter will move the Adjustment Icon
to the Right.*
*6. Return to the "Convergence Service Menu" by selecting Key number
3 on the remote transmitter or by sequencing the Icon to the last adjustment
point at the lower right corner of the screen and pushing the Menu (M) Key
on the Remote Transmitter..*
*7. Repeat steps 1 through 6 for other required Convergence
Alignments.*
*8. To Save the Adjustment completed in the last procedure,
Exit/Save the Convergence Service Mode by selecting Key 1 on the Remote
Transmitter. This forces the corrections to be written to the EEPROM on the
Convergence Module.*
*Note: To save the convergence corrections made above you must exit the
convergence menu by selecting Exit/Save Data (1)*
Posted on Jul 05, 2008
SOURCE: philips magnavox rear projection tv mn 9p5514c101
tv power light comes on no audio
Posted on Feb 23, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Convergence on a Philips 51pw9303 rear projection TV
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
In need of an owners manual tv for magnavox tv 55"diagonal model #6p5441c103 can`t connect dvd player also magnavox
send me a email request to slinteriors@yahoo.com and I will give you a download link so you can download the user manual for the 6P5441C rear projection TV.
May 27, 2011 | Philips Magnavox 55P9271 55" Rear...
60"inch projection tv need to purchase the red liquid fluid(s)
Hi. I am an ex Philips Tech and still have the same exact TV in my living room. I may have a manual here , there are some sites that post manuals online too. typical problems with your TV are:
convergence issues, power supply (picture pulses), CRT fluid contamination, Great Model Set
Aug 19, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 55P8288A Picture is cloudy
You can purchase a factory one from www.remotes.com. and for you manual you can download it here just click on get manual http://www.retrevo.com/s/Philips-50ML8105D-TVs-review-manual/id/277ag615/t/1-2/
I sure do hope this helps you and thanks for using fixya.com
May 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
OPERATING A MAGNAVOX TP3170 C101
i would try the magnavox website,just go to support or customer service and they should have a manual there.if not let me know how you make out.
Dec 07, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Instruction Manual for a Magnavox Rear Projection TV Model MRP43
If you go to magnavox.com they have a pdf of the original owners manual.
Nov 07, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
PICTURE PROBLEM
It isn't likely that you will find this as a free download since they can be quite complex.
The link below will give you the chance to download the service manual for $11.99:
Magnavox manual
Happy hunting -
Oct 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
I am trying to program a new remote and i need my remote code to program the tv can you find the code for magnavox msd513f
Not sure your MSD513F is not listed, and dont know your chassis # so here is what I can offer with what you gave me from the manuals
FOR THE
51MP392H/17
PHILIPS phone # 1-800-432-8542
Universal remote control - RC2018/1
Universal RC managing TV and peripherals
from the parts manual
Cabinet & Accessory Parts
REMOTE Transmitter, RC2061/01 . . . . . . . 3128 147 14611
Sep 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox Model 7P6033 W101 (60") moved tv and picture now has distorted vertical hold
ok..... I,m a dummy !!! but not DUMB .....enough to play this freaking game When I figure this **** out I will POST it
Jul 23, 2008 | Televison & Video
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
