Question about Toshiba HD-A30 HD-DVD Player
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
How do I correctly connect my Phillips 2880DVP dvd player to my toshiba 3 yr. old flat screen (dont know model) tv that is connected to Direct tv? HDMI from dvd player to tv and then?
    Sergeant:
  • 376 Answers
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
Posted on Jun 25, 2014
SOURCE: Red Screen
i have the Toshiba A1 and a benQ W9000 projector. I never had this problem with my Sony HS60. I switched the video from 1080i to 720p and then back to 1080i and it fixed it immediately .... its really annoying though
Posted on Feb 08, 2008
SOURCE: Changed HDMI settings and can't now see image on screen
I did the same thing, if you hold the hdmi select button on the player (not the remote) while ejecting and inserting a dvd, it will reset so you are able to access the setup menu again.
Posted on Feb 18, 2009
  • 3 Answers
SOURCE: how to reset the default value for the toshiba sd 6100 dvd player
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
Posted on Jul 18, 2009
SOURCE: YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Posted on Sep 23, 2009
  • 8457 Answers
SOURCE: My toshiba sdk990ku dvd player stopping playing
Tries unplug,replug it back like an hour later.Letting the DVD player resetting itself back to the factory setting.Tries it than,see if it work than.Not,than tries hook it up with the RCA component cable Y,R,W.If still have the same problems,the PCB in the DVD player is bad.Not worth repairing.Trash it.DVD players are very cheap these days.U can get a brand new one like for $40 dollars.
Posted on Nov 18, 2010
Connecting dvd player to old tv
Turn off the progressive scan and then connect. Also let me know the ports available on the TV so that I can check whether it requires any converter to make the connection. Thank you.
May 05, 2012 | Toshiba SD4300 Progressive Scan DVD Player...
We are trying to connect our Sony DVD player to our Toshiba Tv We plug it according to the diagram. We get no sound or picture although the power is on to the DVD player. We have the TV on Channel 3 ....
Make sure the connections are correct according to the Diagram.Sony DVD player Video Out and Audio out should be connected to Toshiba TV ,AV1 or AV 2 Etc. don't forget to switch the TV from TV mode to Video mode (Input mode)
Jun 13, 2011 | Televison & Video
New DVR67)KU toshiba DVD video recorder/VCr recorder Problem: Cannot get on-screen display to set up new DVD machine. Both DVD and TV are Toshiba
unplug everything lets start over.....the TV is set on Ch 3..........and is working.... the new DVD machine should have red, white and yellow RCA cable.... connect these to the correct DVD outlets ........now connect it to the TV (digital IN)..... this is to view........ now to record using the F connecting cable plug this into the DVD (rear top right hand corner) this should be coming from your sat/cable out ........... now from the DVD F connector out .this goes to the TV...........note to record from another DVD player use the front jacks.........turn the power on and enjoy that movie(s)
Jan 27, 2011 | Toshiba Televison & Video
We don't know how to hook our Phillips DVD to our new Westinghouse HD TV. We have Dishnetwork. We had it hooked up to our old TV and it worked fine.
The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV.
Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV.
Daniel Busa
DISH Network Customer Service
Dec 27, 2010 | Philips PET710 Portable DVD Player
Connect TV to dvd player
hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Dec 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Oct 21, 2008 | Televison & Video
Sony Bravia with Phillps dvd player
The DVD player may have multiple output formats that can be displayed. Sounds like you have the composite output selected when you have the component output selected on the DVD player. Check the menu options on the DVD player and confirm they match the way you have the player connected
Aug 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
How do i connect my GPX dvd player to my hd tv? I have Direct TV also.
I also have a GPS DVD Player and Direct TV. On the back of the TV there are slots for AV1 and AV2, I chose AV1. The yellow cable is your video.When placing the YELLOW in the video I noticed the pic was Black and White. After changing it to the slot marked Video Y the color came back. The white and red are audio. I put the WHITE in Audio L and the RED next to it in Audio Pr. Granted I am using a Phillips TV but the concept is the same. Hope this helps. If you don't have sound, switch the position of the Audio (red and white) cables.
Apr 05, 2008 | GPX D1816 DVD Player
Toshiba HD-A30 HD-DVD Player Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
