T-11 error on Risograph GR3770
HI! Lately I've been having issues with a T-11 error coming up on my machine. It's a secondhand risograph that I bought to print comics on, so I didn't expect it to work perfectly all the time, but I was hoping I would be able to learn how to fix it myself. Is there a way that I can fix this T-11 error myself? I have already worked out that the T-11 code means that there is a possible issue with the pressure control motor, but the technical manuals I have been able to find for my machine online aren't that helpful with solutions to the problem. What I would really like would be photos of where exactly the problem is and details about how to fix it. Thank you!!!
  • 34 Answers
SOURCE: Risograph 5800 repair
This is a cutter moter lock. you would have to replace the cutter unit.
Posted on Feb 20, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Code d--13, ---9 risograph rz220
Check out copytechnet.com. Its a free service that covers copiers only. You can get in touch with a Risograph technician to give you the answer.
Posted on Oct 15, 2008
  • 81 Answers
SOURCE: Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Posted on Jul 07, 2009
  • 81 Answers
SOURCE: risograph rp 3100 ui
Reset machine... and check connectors to the boards... its a communications error to the digitizer cpu
  • 17 Answers
SOURCE: what does the error code P04-513 means ? Risograph
P04-513 means ink overflow. Don't worry though, sometimes this is not always the case. The ink sensor inside the drum has two antennas, a short one a long one. The long one is always supposed to have ink on when sticking into the ink bead. If it doesn't it calls for the ink pump to turn on and draw ink from the bottle. If the short one ever gets ink on it, this error code comes up. Sometimes it is just caused by ink splattering inside.
Take off the drum screen and drum body. Inside, you will see these two antennas in the ink bead. Clean out most of the ink and make sure the small antenna has no ink on it. Reassemble.
Posted on Mar 30, 2010
How to solve e13 error in risograph ks 800
E13 Cutter motor Lock
• If the Cutter home position switch is not turned OFF within 500 ms after the Cutter motor is activated.
• If the Cutter end position switch is not pressed within 2000 ms after the Cutter motor is activated. http://printcopy.info/?l=en&mod=free&chap=erc&brand=Riso&model=KS800
Apr 17, 2015 | Washing Machines
Risograph GR3770 - cannot pul out the drum, Error code T14. How can I pull it out :)? thanks
This solution is ONLY for pulling out the drum.
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
Jan 03, 2011 | Riso RZ220 Duplicator
RISOGRAPH (RISO) - Service-Manual
my Risograph CR-1630 AW, error 5. what can i do?
Jul 29, 2010 | Computers & Internet
Anybody know if Risograph GR hd black ink is ok for use in Riso FR machines?
Short answer is no. RISO GR HD ink is only compatible with a GR3770, a 600 dpi machine.
Mar 05, 2010 | Eagle Signal Br1 30min Reset Timer
My risograph CR1610ui won't work. E03 is appearing in the display. i don't have service manual for this.
Where is the near service station for Risograph CR1610 in North East India please give me add and Pnone. no. plis
Feb 15, 2010 | Riso Office Equipment & Supplies
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
Mar 11, 2009 | Riso Office Equipment & Supplies
Oct 08, 2008 | Office Equipment & Supplies
jasbo
jasbo
