Question about Dometic Rooftop RV Air Conditioner
Snapping noise then quits
AC runs for a while then starts making snapping sound/crackling noise then quits. After waiting 10+ minutes it will start again and may or may repeat the issue. It only seems to do this when the compressor is on, not when running the fan. When it quits, I can't turn neither back on. Thx.
  • Rick Fleming
    Rick Fleming May 17, 2014
    Thanks for the response, it's a Dometic dual therm model# 457915.301 Its on a trailer that is a 2011 model year.
    Problem Solver:
  • 8 Answers
Not sure what model yours is, but sounds like you have a bad start capacitor that has dried up or swelled and "snapping" when making connection. If you can give me the Brand and model number I can see what capacitor you need.
Posted on May 12, 2014
Testimonial: "Thanks for the response, it's a Dometic dual therm model# 457915.301 Its on a trailer that is a 2011 model year."
22yooper
  • 828 Answers
SOURCE: Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Posted on May 31, 2008
koolbreezes
  • 540 Answers
SOURCE: Hard Starting Dometic Rooftop AC unit
Just add a$10:00 hard start kit to the compressor.
Posted on Sep 07, 2008
  • 587 Answers
SOURCE: We have a Coleman 7300 rooftop ac unit. When the
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of
tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 587 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
motor1258
  • 6674 Answers
SOURCE: A/c turns on for 10 minutes
If it was start up capacitors, it wouldn't start initially every time. Do me/you, a favor, and remove your filter inside (return air) , and if it's a ducted system, remove entire plastic cover inside. Take a flashlight & look way up where filter covers in hole & take a good look at cooling fins on evaporator (front of AC). Look for restrictions such as dust etc. That dust will turn just like mud on there due to condensation mixing with dust, and block off flow which could cause unit to freeze up & compressor to kick out. If your real ambitious, and find lots of dust there, taking cover off roof unit would be next, and check same there at back end (condenser) coils & cooling fins.Get back to me after inspection from inside. Could still be electrical but lets check that it has proper maintenance & best chance to work properly by doing this first.
Posted on Jul 16, 2009
Strange Noise While engine is running
do you have ac in your car let me know
Jan 04, 2014 | 2008 Toyota Prius
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
Kenmore 868738000 Elect Dryer Starts for 10 minutes then stop.
That is gong to be a bad motor. $72.
Tools needed:
Putty knife
nut-drivers
screwdrivers
adjustable wrench
locking pliers
Notes:
Motor blower is reversed threads
Difficulty 1 to 10 = 3
Start by: removing filter and filter housing screws
then remove front panel screws LIFT UP on panel to remove it.
Remove belt remove tub. Get filter housing off
Clean up dryer. Lock down shaft and remove blower. Pop motor mount clips. Unplug motor. make hote of position f motor. Install new motor use nutdriver to snap down clips. I have the manual and some photos. In my sleep I can completely replace a motor in less than an hour and that includes oiling the rollers and idler and doing a through hoovering out the machine. This machine is worth replacing the motor and really a breeze to repair. Nothing has worked better for over 50 years. Go for it.
Apr 22, 2010 | Kenmore 62602 Electric Dryer
Amana Electric Dryer Model NDE 7800YW squeals when running will quite after 5 to 10 minutes
my amanadryer will run for 10 minutes and then start squealing and quit.wait 15 minutes and it will restart and do the same thing. any help???
Mar 09, 2010 | Dryers
Oven Noises
Try to unplug it from power. Wait 10 minutes and plug back in outlet.Sometimes electronics need to be reseted.
Dec 31, 2009 | Jenn-Air JJW9330D Electric Single Oven
Dryer wont start
Your motor is bad.
Apr 19, 2009 | Dryers
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Dometic Rooftop RV Air Conditioner Logo
89 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
