Question about Apple iPhone 3G
Touch screen stopped working.
The power button works but can not shut it off or do anything with that since it requires the touch screen. The three buttons below do not work as well. I have taken the battery out a few times letting it sit out for a few minutes to let it cool off since i know it has been getting hot out so i thought maybe the heat was getting to it. But it is still does this when i turn it back on. I have all my contacts in this phone, and job related information on the notepad in the phone from earlier today when it was working) What should i do? It was working perfectly just a bit ago.
  • Kendal Brake
    Kendal Brake May 12, 2014
    It is a ZTW Android phone btw
  • 84 Answers
The digitizer cable must be loose or the screen busted during your replace battery operation. You posted apple 3 g and the additional info says ztw Android.
Posted on May 12, 2014
5 Suggested Answers
SOURCE: iphone touch screen
Thanks!!!!!! I just tried resetting the phone and it worked. It turned on and everything was back to normal. Why did that happen?
Posted on Jan 01, 2008
SOURCE: iphone froze
hold down the power button and home button for roughly 10 seconds sometimes it can take anything up to a 1minute. This almost always works. My froze and i tried this, worked first time.
When your screen goes off from holding them down. Plug you iphone into itunes and it will load and your all set.
Posted on Jan 07, 2009
  • 630 Answers
SOURCE: My touch screen won't work after I've dropped it.
Probably damaged or loosened an internal connection. Similar thing happened to me and I needed a new motherboard.
Posted on Sep 19, 2009
  • 5 Answers
SOURCE: my apple i phone has frozen screen went black can
this should probably work try holding the homescreen button and the lock button at the top for about 15 seconds it should restart and you'll see the apple logo wait for a couple of minutes and you should be fine
Posted on Sep 02, 2010
How do I fix the touch screen on my phone
Remove the battery and wait 30 seconds.... then put the battery back and try it. If it still doesn't work....it has to be looked into by a technician. Could be loose connection to the touch screen.
Jul 07, 2017 | Cell Phones
How to disable blackberry z30 z10 screen reader
Press the power button three consecutives times to activate the screen reader. Press the power button three consecutives times to de-activate the screen reader.
Mar 02, 2015 | BlackBerry Z30
The touch screen in my Ipad stopped working. It works to unlock or to shut a screen but that's all.
Try restarting it: hold power button down until "slide to power off", power off for 10 seconds, press power to restart.
if that doesn't fix it, reset your iPad: hold BOTH power button and Home button until device resets and apple logo appears.
Feb 14, 2015 | Apple iPad Mini
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
How to fix error code c-3725
c-3725 -> Fusing abnormal high temperature detection. To get rid of this code, you have to follow the below procedure:
1. Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed;
2. keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below.
3. Restart it normally and it should work.
If the error is still there, you might need to replace the fusing unit. If you need anything else, just drop us an email at office@bizhubreset.com also, visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 14, 2014 | Konica Minolta Bizhub C550
Touch screen on minolta bizhub 200 not working all the time
Need a new touch screen.One other option. Push utility/counter meter count then press stop 00 stop 02. Places machine in maintenance mode. Then press the utiltiy/counter will see maintenance mode press that find touch screen adjustment. follow the screenthen press start. T clear maintenamce mode and flashing start button. Power off machine main power left side of the machine to the rear.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 07, 2014 | Minolta bizhub 200 Copier
When I turn on the copier the screen says Xerox with a yellow line on the bottom and 1/6. it stays like that all day. none of the buttons work nor does the touch screen. it won't copy. I have pushed the...
Please once again shut it down. And re-install the cartridge. Also then reset it without cartridge. And if this does not work then simply its time to send it to company service station.
Thank you.
Oct 02, 2013 | Xerox Office Equipment & Supplies
The touch screen stopped working this morning. Can't do anything. Is there a reset button for the computer?
Re: the touch screen stopped working this morning. Can't do anything. Is there a reset button for the computer?
No there is not. If the touch screen is blank and you know that you have power at the outlet, then the computer module has been fried and will need to be replaced.
Possible reasons for a computer module going bad are most commonly due to power surges. If you plug in an outlet surge suppressor then plug your computerized washer and dryer into it, that will save you BIG $$$ over time.
May 27, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
The touch pad works while turning computer on, but as soon as the home screen comes up, the touchpad stops working and an external mouse has to be used
there is a little button that shuts off the touch pad near the power button on some models and located in diff areas on other models hope this helps
Mar 14, 2011 | ASUS Eee PC 900HD Netbook
Apple iPhone 3G Logo
19 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
