Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
42cc chainsaw plug gap - Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
  • 45 Answers
.025" or .6MM
Posted on Jan 08, 2015
dontbother10
  • 2220 Answers
SOURCE: Chainsaw pull cord wont tension up
Its almost certainly made by Poulan.
This may help you find an IPL at Sears, they are available:
http://www.searspartsdirect.com/partsdirect/modelHelp.pd?modelNumberId=29
This lists all Poulans. It will be difficult to find your saw but it is here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
It sounds as though the starter spring is broken.
This thread explains how to reinstall the spring.
http://www.fixya.com/support/t1839024-broken_recoil_spring
The IPL for your saw shows all the parts and provides an idea of how they fit together. GL
Lou
Posted on Sep 08, 2009
joecoolvette
  • 5660 Answers
SOURCE: I NEED TO KNOW THE SPARK PLUG GAP AND MAGNITO GAP
Spark plug gap is .025
As for the air gap in-between the flywheel, and magneto, I generally start with a piece of notebook paper in-between them.
After the bolts are snugged down, turn the flywheel by hand to spin the paper out.
Posted on Oct 29, 2009
  • 4088 Answers
SOURCE: it is firing from the spark plug but will not
Try a squirt of starting fluid in the plug hole, replace the plug and try to start. If you get a pop or two, then you have fuel problems. Make sure you have fresh fuel mix in the tank. Check the condition of all fuel lines including the in-tank line plus the fuel filter for plugging. Check the muffler and air cleaner for plugging. Does the engine seem to have good compression? If everything looks ok, then it may be time to disassemble the carburetor, clean and re-kit it. Set both needle jet screws initially at 1-1/2 turns out CCW from the CW stops (lightly). The engine should start and run--allow to warm up. Pull the throttle full on and adjust H CW until the engine runs faster, but is still 4-stroking. The correct adjustment is for the engine to 4-stroke, but immediately 2-stroke when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Set idle speed screw to stop the chain from turning at idle, but keeps the engine running. Hope some of this helps!
Posted on Apr 17, 2010
  • 4088 Answers
SOURCE: Pro 42CC 2 Cycle Chainsaw, 18": New gas, clean plugs..Ran fine last year, won't st...
Check for a plugged fuel filter and defective fuel lines. Make sure the carburetor fasteners are tight. Check for spark at the plug--it should be blue and snappy with a new plug. If ok, squirt in some fuel mix in the plug hole, replace the plug, and see if it will pop a couple of times. If ok, make sure the primer bulb draws fuel into it after several pumps. If still won't run, remove the lower chamber of the carburetor and check the diaphragm for flexibility and no holes. Hope this helps!
Posted on May 14, 2010
  • 111 Answers
SOURCE: maxtra CHAINSAWS
I would check jackssmallengines.com the link is below. They supply Poulan replacement parts.
http://www.jackssmallengines.com/poulan_chainsaw_parts_index.cfm
Good luck.
Posted on Oct 29, 2011
What is the air gap on the coil & the spark plug gap on a 42cc poulan chainsaw
Hi Mike:
It's hard to go wrong with 30 thou on a spark plug, and If I remember correctly, isn;t there a mark on the coil bracket that shows where to line it up? As long as it's not touching the flywheel those saws want to run.
Bolt it up and back to the woodpile!
Jul 16, 2015 | Poulan Garden
Gap coil on ppb 330 poulan pro
First and foremost ppb330 is a model number for a grass line trimmer, gas model.
Second, I am unsure what you are asking. Gap coil?? Do you need the spark plug gap for your chainsaw? That gap is .025.
I hope this helps. If not, please re-post with the correct model number for you chainsaw.
Jul 08, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the spark gap for 221 pro 40cc
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What spark plug (make, number) can I get for a Poulan 2025 chainsaw and what gap?
Replace with Champion CJ-7Y or RCJ--7Y spark
plug and tighten securely with a 3/4 inch
socket wrench. Spark plug gap should be
0.025 inches
R stands for resistor on the RCJ-7Y. Either plug will work.
PDF of Owners Manual
If you have other questions about your saw, there is an 800# at the top of PDF.
Hope this helps.
Oct 21, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the proper gap for the mag to flywheel?
0.3mm for the air gap, 0.5mm fot the spark plug gap.
Apr 30, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My saw will start but dies immediatly
Spark plug gap The right spark plug and the right gap is critcal to good running on a 2 cycle motor(you DO have gas in it right?)
Aug 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan will not fire off, no report when primed manualy.
Yes. I would start with the plug wire. If your gap is correct and you know that the coil is good. Then it should be the wire.
Jun 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
