Home | Mitsubishi | WS-55809 55 in. Rear Projection Television | Mitsubishi WS-55809 pic...
Mitsubishi WS-55809 55 in. Rear Projection Television
Problem for Mitsubishi WS-55809 55 in. Rear Projection Television
Mitsubishi WS-55809 picture shrank inwards, tv
By hellian82 on Jun 23, 2009
Mitsubishi WS-55809 picture shrank inwards, tv turned off, wont turn back on...I did not see any fluid on any of the three main boards from the CRT's leaking coolant, However..I did experiment with turning it on again...somethings up with the red CRT..
The Green and blue seem to be ok i guess.... when i power the set, the red CRT has an electric arc inside the tube, or whatever it is. I dont know if that's normal or not. When it does, the lights in the room slightly dim for a second. All 3 CRT's glow orange on the bottoms, however the red one is kind of inconsistant, like the electrical arc in the tube is robbing it's power? this seems more like a power problem now...would this be correct? is there a way to disconnect the red crt to see if the set will power on without it?
Comments:
Jun 23, 2009
- is there a way to diagnose the PSU instead of just replacing it? ive got a multimeter handy if that'll help.. Thanks!
Best Solution
posted on Jun 23, 2009
Helpful)
rulds2008
Rank: Guru  Televisions & Videos  Expert
Rating: 86%, 982 votes
I would be checking the power supply unit instead of messing with the guns at this point.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Mitsubishi WS-55809 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55809 55 in.
Do you recommend Mitsubishi WS-55809 55 in. Rear Projection Television?
Answer
Answer
color is off on my tv im seeing colored shadows how do i reset that without a remote
Answer
i have an older projection tv and the red yellow and blue dots are showing through.projection dots i... (More)
Answer
the TV will not turn on and the green light just blinks. The directions say to push the reset button... (More)
Answer
Mitsubishi W555809 TV won't start. Had a play station 2 hooked up for a couple of weeks and once... (More)
Answer
My dad's tv has sound but no picture mitsubishi television (model wd52528). BUT he messed with the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55809 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
