I feel like it is clogged, but the drain hose seems OK. The problem seems to be from somewhere inside the machine where the water goes to the pump and out to the hose.
SOURCE: washer will not drain, seems to be plugged
Try using a wet/dry shop vac and see if you can pull water through the drain hose in the back. If you can, duct tape the vacuum nozzle to the drain hose to make a good seal. With the vacuum on, watch the drain hose under the tub. If it collapses, you have a clog somewhere. It may be easier to remove the hoses from the pump, first to see if there is anything stuck in the impeller. It doesn't take much to restrict water flow. If you need to remove the hose from the bottom of the tub, try to get as much water out using the method I mentioned. It may be slow, but as long as it can pull water, try to drain. This will save you from a big mess later. If there is a clog in the hose, all that water will gush out with the hose disconnected. You may want to have a few towels handy. Now...in some models there is a plastic ball valve in the drain hose connected under the tub. This needs to stay there, but may also be jammed with crud. Sand and dirt is notorious for clogging at this point in the drain system. This hose should come off with a simple clamp tightened with a screw. If you go through all the effort and find the lines clear, you may have a failed drain pump.
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
SOURCE: clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
SOURCE: F21 error
Peace Friend,
ngfam1 At your service!
NO GOD FOR BID DO NOT USE DRAIN OPENER IN AN APPLIANCE!
First try this, unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
SOURCE: LG WM2233H* Clogged drain
After draining and cleaning filter, reset washer--Unplug unit and hold Start (selector) button for 10 seconds. Plug unit in and restart.
