Question about iLO 3200 32 in. LCD Television
Does a HDMI cable help with reception
Does HDMI cable help with reception
  • 439 Answers
No, this will not make a difference with tv reception, just better picture when the reception comes in.
Posted on Jun 23, 2009
Bought 42in Philips SmartTV from Singapore and used in Philippines, attached to cable but reception is rainy. i tried to connect a renco digital converter, got sounds but black screen on TV. Pls help.
Sound like you HDMI settings is not set right. put it back the way you had it so you can change different setting for you HDMI.. like 1080i or p or ip or 720i or p or ip...
Maybe that will help
Good luck.
Apr 24, 2015 | Philips Televison & Video
How to connect Roku 3 or do I need Roku 2?
I think it will only work if connected directly to the tv with the correct cable.
Dec 27, 2014 | Pioneer Televison & Video
HDMI Ports on Toshiba Flat Screen TV stopped working
That's highly unlikely!!! More likely is that the cable is having problems or that someone mistakenly changed the picture i the TV from HDMI to regular reception. If the HDMI ports are changed to regular TV reception they don't see the HDMI ports only the regular video ports!
Jan 01, 2013 | Televison & Video
TV was working fine. Plays DVD's fine. Can't find HDMI from the cable, hence to TV reception. TV set works fine however on DVD's so it is not the set itself. Can't find the HDMI 1 hook up only the HDMI...
Tries tv and cable or satalite boxes unplug,replug it back for like about an hour later.By letting tv resetting itself back to the factory setting and those pay boxes upgrading it softwares.The tv HDMI signal for the tv incomming broadcasting signal should be back,if not, tv might have a dead HDMI cable or that the HDMI 1 hub it plug in is shorted and dead.
Feb 12, 2011 | Mitsubishi WD-57733 57" HDTV
Samsung HLP4663W DLP 46' tv: Just replaced with new color wheel and the lamp is newer -6months old. When I plug in the hdmi cable, I get picture but no sound. However, if I plug in the coax, I get...
You still need to get an audio Left and right connected from the video source.And for the digital reception from the antenna source is not possible because your unit is not equipped with a digital tuner(it is NTSC or analog reception only)it needs an add on digital tuner that has an hdmi output.Newer ones now are equipped with digital tuners.
Oct 27, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Do I need an HDMI cable in order to get HDTV on the Polaroid FLM 3732? Or can I get HDTV with the cables provided
you can still get HDTV broadcast, the only difference with the ordinary cables vs. HDMI cable is, the reception on HDMi cable is the best there is.
Jun 12, 2010 | Polaroid FLM-3732 Television
HDTV Reception
Yes , If  a  high definition device is connected to the tv then you can watch high deff tv.
Dec 21, 2008 | Mitsubishi WS-55313 55" Rear Projection...
HDMI f/ dvd, dvr, receiver and tv
best set up if you have all hdmi is to have all your components go into the receiver ie. hd cable box, dvd etc. by using the hdmi output from the player(s) to the hdmi input to the receiver. next use one hdmi cable from the receiver to the tv then your laughing.
good luck
smeags
Dec 31, 2007 | Onkyo TX-SR605 Receiver
iLO 3200 32 in. LCD Television Logo
93 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
