Question about Insignia Televison & Video
Hdmi inputs are loose - Insignia Televison & Video
    Problem Solver:
  • 10 Answers
Then you have to open up the back panel and solder them back in, if you cannot do this then take it to a repair shop the solder them back in problem, you can ask if they can secure it better with epoxy or some resin after soldering. unless you know how to solder, then its a good project to accomplish!
Posted on May 12, 2014
SCREEN FLICKERS WHITE 2 LIGHT BLUE
Sounds like a loose connection. Make sure your cables are secure. Try switching your INPUT selection on the remote to something else, for example, if you're watching cable, switch to HDMI, or A/V or something.
You can also try, if the input w/ the issues is HDMI, either swapping your cable for a new one, or swapping which HDMI input it's plugged into.
Good luck.
Sep 21, 2016 | Televison & Video
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
Where is the HDMI connection on my Sharp LC-46SB57? I installed X1 and cannot get picture. Sharp Input 1,2&3 are grayed out but Inputs 5Roku & 6blue ray work.
The X1 box acts like a set-top cable box. The HDMI output can be connected to any HDMI connector. There are three HDMI connections on the rear of the set. You have the Blu-Ray connected to one of them, Input 6. You should have no issues with connecting the X1 to either Input 7 or Input 8. There is no specific "TV" HDMI connection. You simply use the remote to select the HDMI port that the X1 is connected to.
Nov 18, 2015 | Sharp Televison & Video
On my LT42HVi with HDMI input source, the image comes through with a lot of green then will change back to normal color. Switching cables or HDMI input port makes no difference. Using normal TV inpu
is the normal tv input for high definition? Don't understand that term. I have a dish receiver, when I use an hdmi cable I get a really nice picture even with Roku
Jan 02, 2015 | Olevia LT42HVi 42 in. LCD Television
PJ-TX300 suddenly not detecting HDMI input
I think that its a port issue, if all the other ports are working but hdmi is not then one of the pin on the circuit board may have come loose. I have the same issue. Could try to solder it back on or use a glue gun. let me know if this helps?
Sep 21, 2014 | Hitachi PJ-TX300 LCD Projector
Is it possible to replace the HDMI input connector of my Samsung LNR408DX/XAA? What is the exact name or code/type etc for replacement of the HDMI female connector of my Samsung LNR408DX/XAA? I seem to...
Re soldering the sockets connections on the pcboard will normally fix this problem. It is unusual to require a socket but possible. Sockets are available through a good electronics outlet, depending on your country.
Dec 27, 2010 | Televison & Video
When I attach something to my television using the HDMI input nothing gets displayed. The TV detects the input and asks if I would like to switch to HDMI 1 for example. Once the input is switched, all...
That problem may depend then on the HDMI compliant device that you have connected to the TV and/or the integrity of the connection. First verify that the connection is secure from coming loose and that both ends are seated properly. Then power on the TV, then power on the HDMI device.
If you still have no signal the next step then would be to confirm that you have the proper output resolution set on the TV, AND on the HDMI device. Confirm first that HDMI on the device is enabled. Then, if possible, set the TV resolution to 480P and the device to 480P as well. Go through all of the output resolution selections on the device until the TV shows picture. If you continue to have trouble, repost on here ALL of your devices you are using and how it is connected.
Aug 14, 2010 | LG 42LG50 42 in. LCD HDTV
Loose hdmi monitor out connection brand new cable
hd EZ lock may help your issue. It's a Universal Locking HDMI Cable Adapter which acts as a strain relief and HDMI Cable lock. It is very effective in eliminating intermittent signal loss caused by a loose connector, as well as eliminating harmful stress on an HDMI Input caused by a heavy HDMI Cable.
It's universal and works with most HDMI Cables and most HDMI Components, and typically installs in minutes. Here's a short video showing installation:
http://www.youtube.com/watch?v=-AyR9higu0M
Sep 22, 2009 | Yamaha RX-V2600 Receiver
My LG 42pg3000 stopped displaying hdmi inputs.
I have a similar issue. HDM1 does the same thing, did you ever find a solution?
JP
Apr 05, 2009 | LG Televison & Video
Input 7 not working
Did you go to "Label Inputs" in the settings? Make sure Input 7 is not set to "skip."
Dec 06, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
50 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
