Question about Coffee Makers & Espresso Machines
Homemaker Espresso coffee machine, lights keep blinking and wont stop after my first ever coffee with the machine and now it doesnt work...I hd the same problem with my previous one took it back to kmart had it replaced and now its happeneing again...Has anyone else had this problem and what did they do to fix it...
  • 2039 Answers
SOURCE: DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Posted on Feb 08, 2008
  • 54 Answers
SOURCE: Espresso maker doesn't work properly
It is clear that there is a problem with water supply. Check if pump works, if it does, there is blockage in water supply to pump. Check and clean.
Posted on Jul 11, 2009
  • 80 Answers
SOURCE: My breville espresso machine wont heat
try priming water
Posted on Aug 01, 2009
SOURCE: water leaking in espresso machine
I have a Krups 2010 and it leaked from day one I used it for about a month before I decided to fix it myself instead of paying for shipping it to them. After opening the back (yes the warranty is broken) I took some photos and here is what I found. Poor quality control there are two screws holding a hose interface to the reservoir and they are not tight or became loose since they are metal screws going into plastic that get hot and vibrates.
The fix is to tighten the screws just slightly so that you do not crack the plastic then dab them with nail polish so that they do not move. (see second photo). This machine still makes one of the best espressos I have tasted and now it is one of the easiest to clean.
Posted on Jan 07, 2010
systemloc
SOURCE: MY MR Coffee ECMP50 has two blinking lights
After 8-10 months or so, my Mr Coffee ECMP50 died too. Both lights were blinking. The power light and the ready light were both blinking, not the buttons. Thankfully, this was an easy fix for my machine. The machine heats water with a heating block that is controlled with a thermisistor. For safety, the power to the heating coil goes through a Sefuse thermofuse on either lead. Thus, if the machine malfunctions and the heating block heats continuously, the fuses will cut the power when the temperature goes too high. In my case, the thermisistor was fine, and replacing the fuses solved the problem. I think the microcontroller senses a failure to increase temperature and blinks to show an error condition.
Here's how I repaired mine, keep in mind there is life and property threatening risks in opening your machine, and that the fault is caused by a safety fuse, which should never be bypassed or altered.
For dissassembly, you'll need to start out by taking the bottom panel off. This has two saftey screws. You can easily get a safety screw bit set at Harbor Freight or maybe NAPA. Some of the screws are also under the rubber feet. Pulling it off, you'll need to cut a plumbers tie and disconnect the drain tube. Next, you'll need to remove the top cover. There are screws around the outer underside where the espresso head is, and there are three screws way down inside. You'll need a really long small philips screwdriver for those. The side knob does pull straight off and isn't connected to anything underneath; it may require some jiggering with to get it off. If you need to get the button panel off to get the top off, there are two screws under the label. Just poke right through. It's a plastic panel and not connected to the lights. The metal is separate and doesn't need to come off.
Once you get the top off, the heating block is located in the center of the rear, hanging from a metal plate held in by four screws. All of the wire connectors have a rubber cover and a locking mechanism that you'll have to squeeze a button to remove the wires. You'll also need to disconnect one of the plastic hoses from the bottom. It is held in by a split pin inside a small plastic block.
On the side of the heating block are two metal plates securing the wires. These are clamping the safety fuses to the block. I just removed the plates, slid back the insulation, chopped out the old fuses, and put in new ones. Soldering them in will blow them, so wire crimps are used. The fuses are carried by Radio Shack in the drawer with regular overcurrent fuses where they keep electrical components. Keep in mind that different fuses for different temperatures are available. Mine was 190 C, 10A. Never use a higher rated fuse, as this is a safety device!
You might test your machine before reassembling it in order to check that the thermisistor isn't gone too. You can safely test it with a ohmmeter. It should read around 110K +- 10K. If you hit it with some ice, it should increase in resistance. Heat will make it decrease in resistance.
When reassembling, ensure that all the hoses get new plumber's ties to ensure no leaking, and don't forget that drain hose! Remember again, tampering with this may induce leaking next to line voltage electronics making a lethal hazard, or disable safety devices which may start fires!
I would suggest never leaving the machine on while not in use, as it puts wear on the heat block and fuses.
Posted on Jun 16, 2012
We can't get the coffee light stop blinking.... In this regard, we can't make coffee
Is the heating element working? did you check it for continuity.
Replace it.
Sep 06, 2015 | Gaggia Syncrony Logic 74884 Espresso...
On light will not stop blinking on my Senseo coffee machine
my senseo did the same. i read on hear to clean magnet/float mechanism inside the water resevoir. i did this with a tooth-brush and soapy water. as you invert the empty water container you will see/hear the float slide up and down when clean. work a treat for me.
Nov 20, 2012 | Philips Senseo HD-7810 Coffee Maker
Saeco magic machine, all the lights are blinking. Turning the machine off makes no difference. Can't make coffee. occasionally if we run a cup of coffee it will stop the blinking, but now that does not...
If all the lights are blinking in a row then you have a Main electronic board problem. Most common issue is that boiler has leaked water on board and caused it to fail.
Mar 23, 2010 | Saeco Magic De Luxe Espresso Machine
The red Water warning light keeps blinking,even there is enough water supply.
It means ventilate, purge the air out of the system by turning on the knob, the pump should run .Keep it running until the red light stops blinking.If not there's a blockage in the line.
Jan 23, 2010 | Starbucks Saeco Italia Digital Barista...
Water light keeps blinking and won't brew coffee?
it sounds like either the pump is giving out or the flowmeter.
since it is releasing water from teh steam valve, i'd aim more for the flowmeter giving out.
Not sure if saeco sells them to the public. Usually gets sent out for repair. Repair will run ya 100-150 usually.
May 23, 2008 | Saeco Magic De Luxe Espresso Machine
Can't get the coffee light to stop blinking
Try to take out the degdraw box and make sure it is off the machine 10-20 sec then put it back again.
Dec 30, 2007 | Saeco Vienna SuperAutomatica Coffee...
Coffee Makers & Espresso Machines Logo
19 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
