Question about Motorola Mobility RAZR V3
My phone was in my pocket and it got a little wet.
It won't come back on now, and I don't know how to get the back off.
  • 39 Answers
There is a tiny ledge on the back of the phone (top of the battery cover), you should be able to see a silver button inside that ledge, you just push it down and pull the battery cover off. Some people with small fingers can push it in with their fingers, if you can't try using a coin or key to push the button.
Posted on Jun 23, 2009
My Safelink Wireless phone got wet while I was out in a recent storm and hasn't worked since. What do you suggest I do?
Not a good thing to happen, you can try taking battery and covers off and leaving the phone in a warm dry place for a few days and hope that all the internal componts will dry and that they have not been damaged. Otherwise you will have to replace the phone.
Jun 16, 2012 | LG Cell Phones
My blackberry torch isnt turning on. when i remover my batterry then put it back, the led light becomes red for like 3sec then nothng and the screen stay black! what can i do?? my blackberry is only 2...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 24, 2011 | RIM BlackBerry Torch Cell Phone
Got my cell phone a little wet yesterday with milk. Placed it in rice overnight. Is jumping from taking pics by itself to sometimes calling by itself.
I would let the phone sit in the rice for at lease a day. It sounds like it's still damp. With luck it will be fine, but if you continue to use it while damp it could be damaged. Try a little patience.
Jul 30, 2011 | Cell Phones
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 | Watches
My blackberry pearl trackball doesnt work
Take it where you bought it and try to get it replaced, saying it's defective. Hopefully you're under warranty, unlike myself who has a **** blackberry who's radio keeps turning off randomly and won't make or recieve calls without having to manually reconnect 'mobile network' hundreds of times a day. Your phone must have got really wet though because buttons and **** don't ******* unless exposed to extremly wet conditions (trust me, I know). I'd like an iphone over this **** for damn sure but i'm stuck with any annoying and fairly useless phone for now.
Aug 03, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Keypad wont work
we will need to replace the keyboard it is usually pretty easy depends on the phone you have fairly cheaper than buying a new phone. hope it helps.
May 02, 2009 | Cell Phones
Vtech v.smile got wet. Need to know how to open
get a needle, heat it and meld a hole in the covers (round inserts) on the back. skrew a little skrew in the hole and pol de round thing out. Take a kros skrewdriver and remove the skrews. Also under the battery cover are 2. take of the cover and you can see the inside of the unit. Dry them, also the plastic contacts on de prints.
Apr 24, 2009 | Vtech V.Smile Pocket
My cell phone sonyericsson got wet.. not working now.
Take your battery out, and look for the moisture indicator.... it should be a little circle with red hash marks. If it's solid red, the battery is probably toast.... you might want to see if you can borrow a battery and try it before you sell the phone.
Mar 04, 2009 | Sony Ericsson w580i Cellular Phone
Odder phones don?t listen to me
hi,
 u just do one thing open the hndset again & put in the sunlight for approx 2-3 hrs & dry up in that ..it will remove all the moisture from ur hndset & it will wrk properly
Thanks
Gizmo11
Oct 21, 2007 | Nokia 6020 Cellular Phone
Motorola Mobility RAZR V3 Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
