Question about Dishwashers
Hi, my dishwasher keeps shorting out all the power in my house. We have tried to run a power cord elsewhere in the house and it does the same thing? Is this an appliance or electricity problem?? not sure who to get to come out and have a look.
  • 790 Answers
If it is a US dishwasher for the home, it should be a 120vac unit.
Check the power cord for shorts.
If the unit is worth the repair cost, have a appliance repair check the unit.
Alkso, you can not use a extension cord of any length to run trhe unit.
Posted on May 12, 2014
bigg t
  • 640 Answers
SOURCE: Dishwasher is shorting out power supply when on hot cycle
The wash tank heater is likely the issue.Remove the 2 wires on the heater and tape them up and run a cycle,let me know.
Posted on Apr 27, 2009
majortom350
  • 23 Answers
SOURCE: Fuses blown & controller card fried
Take this from a 4 board and 9 fuse owner.I believe the ceramic thermal fuse does not blow quick enough and during voltage spikes,or under a load cause overheating of the control board.All my boards had burnt marks on the back of the board(apposite where the 4 prong plug goes).I purchased a new board ,new ceramic fuse with the wire.They say the wire must be replaced too.(Ebay under Whilpool dishwasher fuse 14.00) Next on Ebay I purchased a 15 amp marine push button circuit breaker which I mounted in the side of the front panel.Split the one leg going to the ceramic fuse,run it to one of the legs of the breaker and run the other side of the breaker leg back to the ceramic fuse.I know someone out there is saying you don't need the ceramic fuse if you have the breaker in the line.Humor me.Lets say you get a large surge that fries the breaker closed as in a lightning storm.The ceramic fuse may save the day.Since I have set ours up this way the breaker trips once in a blue moon.Reset it and your off and running again.Oh and don't bother calling Whilpool(makers of Kitchenaid) You can't get anywhere with them.Now if for some unfortunate reason this doesn't solve your problem,don't throw away that dishwasher.Remove the upper and lower baskets,bolt them to the trunk of your car and the next time you go to the car wash bring your dishes with you.LOL
Posted on Jul 27, 2009
SOURCE: Bosch Dishwasher will not power on
I have a bosch dishwasher model 2046. When you try start the cycle you hear the timer inside start to activate but the cycle doesn't start. The light in the start switch does not come on as well but I think it may be burned out. We have checked the breaker and I seems to have power.
Gerald
Posted on Oct 31, 2009
  • 901 Answers
SOURCE: We have an ariston LS
The problem seems to be water seepage into the electrical contact.
If the heater has lost its insulation this problem could accur
( element to body )
Disconnect the heater and give a try without any load and soap. If it
performs OK , you have to check the heater by removing from the
machine. Mainly I suspect water seepage into the electrical system.
Posted on Aug 30, 2010
Crew Dawg
  • 275 Answers
SOURCE: Have an omega technowash dishwasher, not sure how
Sounds like the motor or something overloads the circuit.
You could always call a repairman...but with the prices on these at Lowes or Home Depot, it might just as well to replace it.
I always take the price of an appliance and divide it by the years of service to see how much it costed me to use each year. I know, sounds crazy...but if ya spend $300 on a washer and only get 3 years out of it...then it costed you $100 a year...6 years you're down to $50 a year.
(These days, if you get 5 years out of an appliance...you're on borrowed time. They just don't make appliances like the "Admiral" that grandma had.)
Posted on Jul 23, 2011
Keeps blowing my electric
You are having a dead short in the dishwasher somewhere.
If you would, please do not use it again until it is repaired, as it may burn your house or apartment down.
Some one who is good at such things can take it apart and find the short, likely a wire is touching somewhere it shouldn't.
Be blessed.
Mar 15, 2013 | Beko 24 in. D3421F Free-standing...
Fisher and paykel dishwasher pump constantly runs
Please clarify model of dishwasher. It is likely the motor compartment has flooded and it is shorting the power system. Turn off mains power to dishwasher to avoid damage to dishwasher. The source of flooding has to be found.
Jan 16, 2013 | Fisher and Paykel Dishwashers
Whirlpool 665-13442K901 dishwasher electrical plug in shorts out
You reversed the black and white wires on what? Don't ever do that. One is the line and one is common. They are polarized for a reason.
Immediately stop using that outlet before you burn your house down. Switch the breaker off to that power circuit, then have a qualified electrician check it out.
Jan 28, 2018 | Whirlpool 24 in. Built-In Dishwasher w/...
When switched on the machine trips the power. Changed fuse in plug and tried different socket but still same problem? took bot of machine no visable burn or soot marks? any ideas
Is it tripping the breaker in the breaker box? If so you have a short to ground. Could be A bad spot on the dishwasher cord. Turn power off and pull dishwasher out and check the power cord all the way back to the dishwasher terminals
Dec 31, 2009 | Dishwashers
How to Replace Little Giant Water Wizard Utility Pump Power Cord
Yes, If it goes together it will come apart. If it is the one I'm thinking of if you take the base apart there will be through bolts that run through the whole pump, remove these I want to think there are some that are short and these hold the base to the motor but they may be behind the impeller. Be warey as I'm not sure. But once the through bolts are out you should be able to carefully remove the top. Some have very frail gaskets here so be gentel. Once you have the top free there will be a compression nut holding the cord before pulling cord through use a light sand paper to clean the cord so the part you pull through will be fresh enough to seal. Don't lube the cord this will keep it from sealing. Pull it hrough and make your repair and put it back together the way it came apart. Use a sharpie to mark the top and housing as you take it apart. When finished loop some cord through pump handel and tie it off so this takes the weight in the future to keep from having the same problem again. good luck
May 29, 2009 | Little Giant Pool Cover Pump Water Wizard...
Dishwasher has no hot water running into it only cold
Have you checked your hot water heater downstairs in the basement? Are you getting hot water elsewhere in the house?
May 24, 2009 | Dishwashers
Apr 27, 2009 | Dishwashers
Using power cord for dishwasher
Any utility cord the orange or yellow one will do fine just make sure it is on a breaker that no a lot of large things are on like microwave or computer ect .
Mar 29, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE 2200 Dishwasher-no power at all, circuit breakers are fine, switch works
with your volt/ohm meter check for power going to the dishwasher. the power supply is located under the kick panel. the power wire may be shorted out due to poor installation. if you are not comfortable testing power, I would advise calling a professional. If no power is found at the power box (this has a power cord or electrical wire going to it) the problem lies within your house electric. if 120 volts is present, check for power @ the door switch. aftrer that you just need to follow the power wire and see where it stops
If this is a newly built house and new to you the builder may have put a light switch above your counter ,the one you didn't think went to anything, check for that! good luck with it!
Oct 16, 2008 | Dishwashers
Maytag Dishwasher
we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
Oct 01, 2007 | Dishwashers
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
