Question about Garbage Disposals
Why does my garbage disposal buzz but not work
  • 790 Answers
The unit may be locked up.
You may want to try jogging it back and worth, with a wrench.
Most units have a bolt on the center bottom you can turn back and worth.
Posted on May 12, 2014
They don't work garbage want my money back
Robert,
Garbage disposals are not designed to take ALL of your garbage... and DO NOT use one if you are on a septic system!!
If it is not working, check for voltage to the switch, from the switch to the disposal,,if you have voltage to the disposal, some have a reset on the disposal..
Jul 05, 2017 | Garbage Disposals
It will work but it sounds like metal is grinding in it.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Use vacuum cleaner to see if something is loose.
Otherwise, a noisy disposal that works is functional and not dangerous... but annoying.
Life of disposal is probably shortened since the bearing seal could have failed letting water in, and bearings could be rusted.
Replace disposal if noise bother you.
Gene
May 06, 2014 | In-Sink-Erator InSinkErator Badger 3/4-HP...
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
Garbage disposal
make sure that the fuse is not blown, make sure there is no fork/spoon/etc stuck in the disposer. if it still doesn't work, you have to provide more information about what happens
Mar 29, 2013 | Waste King Whirlaway 291 1/2 Horsepower...
Garbage disposal won't stop running
Check switch. replace switch. If switch checks out, then replace disposal to avoid risk of overheating and in-wall short.
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Dec 18, 2011 | KitchenAid Batch Feed Garbage Disposal...
Won't run
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Sep 25, 2010 | Maytag DFC5500AAX 3/4 HP Continuous Feed...
Garbage Disposals Logo
159 people viewed this question
Top Garbage Disposals Experts
ray gallant
Gil Shultz
Gene Haynes
Are you a Garbage Disposal Expert? Answer questions, earn points and help others
