Question about ASUS Computers & Internet
Wifi lost connection
The wifi connection suddenly disappeared. No wireless network available under settings although I am sitting at home with the wifi working on the tv and phone. How do I reconnect wifi network?
    New Friend:
  • 3 Answers
This is the common problem coming these days with the laptops. so if you are also having such kind of problem with your laptop, simply update your wireless driver then reboot your computer. it will start working fine properly.
Posted on Nov 29, 2015
  • 59 Answers
Wifi is turned off on your laptop ,what model is your laptop ?
Posted on May 12, 2014
marked
  • 6487 Answers
SOURCE: Lost wireless capability
You need first to check if the wireless adapter is installed properly, Ricght click My computer>Properties>Hardware tab>Device manager>look for network adapter and check if the wireless adapter is listed if its there right click on it and go to properties and check the device status..
If the adapter is not showing under network adapter look for anything that says Unknown or other device and you that's where you can find a improper installed device you just need to install the driver for that.
Hope that helps........
Posted on Jun 22, 2008
MrSamBoi
  • 42 Answers
SOURCE: wireless network adapter uninstalled it's self, vista home premiu
this should be your laptop
http://www.laptops.yourtechreviews.com/compaq-presario-f700-reviews/
if it is your laptop
here is the link for your drivers
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3548233
Posted on Dec 30, 2008
rtrahan
  • 741 Answers
SOURCE: wireless network detected not listed in view available wireless
Two things. First go into Device Manager and make sure the driver is loaded. Right click on Network Adapter, then right click on your wireless card. you can update driver, remove driver and let plug n play pick it back up, or if looks like no problems then leave it be. second, did you set it up going thru the Wireless Network Wizard..Its under Accessories>comminication in Windows XP.(You didn't indicate which OS you are using). What is probably happening is you are not quite set up correctly and your WEP is blocking you from connecting because the computer does not have your WEP key....if you have any questions let me know.
Posted on Apr 03, 2009
tmaddonna
  • 10 Answers
SOURCE: Asus eee pc 900a wireless connection not working
I've experienced the same problem with my ASUS netbook. Uninstall the wireless hard - remove hardware in control panel, reboot the machine and allow it to auto find the adapter again. This should correct it. If there are still problems verify that you have the most current driver for the wireless adapter, either from Asus, or the wireless adapter chipset manufacturer (i.e. Intel, broadcomm, etc.)
Posted on Sep 03, 2009
ckuzkuz
  • 255 Answers
SOURCE: wifi button not working
I would start with reinstalling your driver for the WIFI:
Acer Drivers
I think it should help you with your problem, although the WiFi works okay
Posted on Nov 05, 2009
Testimonial: "uninstalled the wifi driver in device manager, rebooted my system and it works thanks for the fast answer"
My friend gave me a windows embedded ce 6.0 netbook, how do I log in onto my wifi?
Select Connections from the tabs across the bottom. Select WiFi. Find your own wifi from the list of available networks (SSIDs) and select and hold it. Then select Connect. In the next screen, make sure The Internet is selected and click Next. On the Configure Network Authentication screen, make sure Authentication is set to Open and Data Encryption is Disabled and click Next. On the next screen, click Finish. This will bring you back to the Configure Wireless Networks screen. Wait a few moments while your phone connects. Once complete, the status will display as Connected. Click ok from the top right section of the screen then close the Settings window with the x in the top-right section of the screen. Once you've joined a WiFi network manually, your smartphone automatically joins it whenever the network is in range. If more than one previously used network is in range, your pc joins the one last used.
Sep 28, 2014 | Computers & Internet
Why does my tablet keep saying authentication problem when trying to connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Dec 30, 2012 | Archos Arnova 10 4GB 4)
Lost wi fi connection to our wireless network, tablet displays "turning off" under the wi fi settings.
I suggest to reinstall the wireless card driver first ..just in case, this will solve any driver issues and will make it functional in case the driver or the setting are corrupted..
To download the driver in case you do not have it on disk or saved somewhere ..just go to acer.com ...select downloads ...drivers and select the model and operation system you use..
download the wifi driver ..run it again ..and after that restart ..and try to make the connection again ...Check the wireless card in device manager to see if it shows in order ...and did not appear in yellow which indicates driver related issues..
also be sure you have network signal ..and the router is functional ..in case other computer is working with this network ..check to see if the connection actually works ..
To redo the connection ..just open the settings for wireless...and click scan for networks ...In the list of available connections ..select yours..and click connect ..insert password if needed.
Good luck !
Nov 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
I was doing something with my dell latitude d610 laptop key board and i lost the linksys wifi connection...although i came to know through my friend to press fn+f2 key,wifi LED comes on but no wireless...
Most likely configuration problem,Im afraid youll have to get the settings adjusted yourself most netbooks will auto configure unless you manually or by error change the settings.
Good luck
Davey Snake!
Jul 20, 2011 | Dell Latitude D610 Laptop Computer -...
How do i set up wifi
To set up Wifi connection on HTC Smartphone:
  1. Press HOME
  2. Press MENU
  3. Tap Settings then Wireless controls
  4. Select the Wi-Fi check box to turn Wi-Fi on. The phone will scan for available wireless networks.
  5. Tap Wi-Fi settings.
  6. Select from the displayed network detected.
  7. Tap a Wi-Fi network to connect. If you select an open network, you will be automatically connected to the network. If you select a secure network, enter the key and then tap Connect.
Jul 02, 2011 | HTC F3188 Smartphone
Can not connect ipad to router
If your Linksys wireless router is already setup with a wireless network, do the following to connect the ipad to the network:
Tap the Settings icon on the home screen of the iPad. Go to General, then Wifi. Once in the wifi section, you should see available wireless networks. Choose the network that is setup on the Linksys and connect to it. Enter the password if you have one set on the wireless network and tap join.
If your linksys is not setup with a wireless network, consult the manual for it to configure it properly.
May 06, 2011 | Linksys Wireless-G WRT54G Router
Has anyone had any luck with getting on internet mine say can not associate
This worked for me:
Click on the little TV, the RT28701 box will appear. Select the "Wireless Information" tab and highlight your network connection, then click the "Advanced" tab. Check "Use Windows to configure my wireless settings" and the "Automatically connect to non-preferred networks" boxes. "Networks to Access" should read All Available.
Next, double click your highlighted network connection. The "Wireless Networks Properties" box will appear. Make sure the Network Name (SSID) is your network connection.
Under "Wireless Network Key (WEP)" box the information should read:
"Encryption: WEP"; "Authentication: Open"; "Network Key: (the number on your modem)"; "Key index: 1"
All the little boxes should not have checkmarks in them.
Click OK which will return you to the RT28701 box. Click OK again to return to the desktop. Click "Start" tab to shut down netbook and then restart. Turn Wifi on by holding down F9 function key for about 5-10 seconds, or double click Wifi icon and then click the Power On box, which will turn it on. Wait for little tv to show up on bottom taskbar and the red x to disappear from it. Then, click Internet Explorer and it should connect.
Sep 17, 2010 | Sylvania G-Netbook
I have a medion computor which is unable to connect to my wireless broadband. The wireless network is recognised, but it doesn't connect. i also have a laptop, but this connects to the wireless broadband....
first off it would be helpful to know some more details, do you know the answers to these questions? also i assume you are connecting to a wifi router in your home network.
1) is there a password for the wireless network you must configure? 2) what operating system are you using? 3) if the OS is windows, do you know if you are using the wireless network settings panel that is part of windows, or does it have another brand name when you click on the wireless or network icon?
some possible causes i can think of are:
1) settings got reset and it cant connect without a password or confirmation to join an unsecured network 2) a new network popped up near the one computer that doesnt work and is being preferred due to signal strength although it is not a valid choice for you to get online 3) in the case of windows, software provided by the wireless hardware manufacturer is fighting with the windows wireless configuration 4) the wifi card in the computer is broken
Feb 17, 2009 | Medion MD 96340 Laptop
I'm trying to download songs to my iphone and it says I must connect to a WiFi network. How do I do this? I tried following the steps on the screen but I'm at a loss when it says choose a network and it...
In order to connect to a WiFi network, you must be in the range of a WiFi network to which you are authorized access, or is completely unlocked. If you have a wireless router for your home internet you will be able to connect to that network by finding its name in the list of available networks and putting in the correct password, or no password if you haven't set one for your network. GSsecure08 is most likely one of your neighbors' networks, and that neighbor most likely has a password that you don't know, so you won't be able to access that network. When looking through the list of available networks, ones with a lock next to them will require a password. No lock means you are free to access it, although there is no guarantee how secure your data is as you are using someone else's internet connection. If you can't find a network in your house, many coffee shops offer free or cheap WiFi. Otherwise, buy the songs in iTunes on your computer and sync to your iPhone.
Hope that helped,
Colin
Sep 30, 2008 | Lands Phones
Computers & Internet Logo
133 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
