Question about Husqvarna Garden
How do I change the oil in a sealed transmission such as the one in the HGT2654?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
You cant. Its sealed for life. They rarely need maintenance, if your transmission is giving problems, first try changing the drive belt.
Posted on May 13, 2014
Replace front oil seal 1998 plymouth voyager
which seal on the engine or transmission front engine oil seal not easy or cheap fix will need to remove accessories and crankshaft pulley ----if transmission than need to remove wheels and c/v axles the following link show how to change oil seals on a voyager https://search.yahoo.com/yhs/search?p=oil+seal+98+voyager&ei=UTF-8&hspart=mozilla&hsimp=yhs-004
Jul 01, 2016 | Plymouth Cars & Trucks
What gaskets and seals will i need to change a 94 ford explorer transmission
I would change the pan gasket, converter seal and rear transmission seal. Also the rear main seal on the engine.If the oil pan gasket is leaking I would do it now. Way easier with the transmission off.
Apr 03, 2016 | Ford Cars & Trucks
How to change the oil in a hgt2654 transmission?
Not sure about this model but generally Husqvarna transmissions are sealed for life and are not user serviceable. They rarely fail so if you are having transmission problems, try a new drive belt and make sure all the pulleys are clean.
May 12, 2014 | Husqvarna Garden
Oil leak between oil pan and transmission.
Try running some of that high-mileage engine oil next time you do an oil change (it helps to swell engine seals slightly). If the problem clears up or is reduced, then it's likely that the rear main oil seal is starting to leak a little. The rubber seals will harden up and shrink a little with age.
I would also powerwash the entire area clean, so that way any leak will be easier to monitor and pinpoint.
Feb 24, 2013 | 1999 Chevrolet Silverado 1500
How do I change and replace the transmission seal and filter. How do I know if I need to replace the head gaskets.
The rear transmission seal can be changed without pulling the transmission. The front seal requires the transmission to be separated from the engine. To change the rear seal you take off the drive line and use a seal puller. Head gaskets need to be replaced if you find water in the oil, have an overheating engine that runs rough or if the coolant smells like gas. One way to tell is to do a compression check on all cylinders.
Mar 25, 2011 | 1991 Buick Riviera
When changing the trans fluid on my 2004 Avalanche, I understand that you have to disconnect the trans lines from the radiator and run the engine until the fluid stops flowing. Is this correct? If so, do...
I didn't read about running the engine at all during the transmission fluid change. --- Removal & Installation 4L60E/4L65E To Remove:
  1. Raise and safely support the vehicle.
  2. Place a drain pan under the transmission.
  3. If equipped with a drain plug, drain the transmission fluid.
  4. If necessary, remove the bolts and position aside the range selector cable bracket for clearance while lowering the pan. It is not necessary to remove the cable from the lever or bracket.
  5. Remove the catalytic converter.
  6. Remove the oil pan bolts from the front and sides of the pan only.
  7. Loosen the rear oil pan mounting bolts about 4 turns.
  8. Lightly tap the oil pan with a rubber mallet in order to loosen the pan and allow the fluid to drain.
  9. Remove the remaining oil pan bolts.
  10. Remove the oil pan and the gasket.
  11. Remove the filter by twisting and pulling on it.
  12. Remove and discard the filter seal. The filter seal may be stuck in the pump; if necessary, carefully use pliers or another suitable tool to remove the seal.
  13. Clean the transmission and the oil pan sealing surfaces with solvent, and air dry. You must remove all traces of the old gasket material.
To Install:
  1. Coat the new filter seal with transmission fluid.
  2. Install the new filter seal into the transmission case. Tap the seal into place using a suitable size socket.
  3. Install the new filter.
  4. Install the oil pan and new gasket. Tighten the bolts alternately and evenly to 97 lb in (11 Nm).
  5. Install the catalytic converter.
  6. If previously removed, install the range selector cable bracket and bolts. Tighten the bolts to 18 lb ft (25 Nm).
  7. Apply a small amount of sealant GM P/N 12346004 (Canadian P/N 10953480), or equivalent to the threads of the oil pan drain plug, if equipped.
  8. Install the oil pan drain plug, if equipped. Tighten the plug to 13 lb ft (18 Nm).
  9. Lower the vehicle.
  10. Fill the transmission to the proper level with DEXRON® III transmission fluid.
  11. Check the COLD fluid level reading for initial fill only.
  12. Inspect the oil pan gasket for leaks.
4L80E/4L85E To Remove:
  1. Raise and suitably support the vehicle.
  2. Place a drain pan under the transmission oil pan. Drain the transmission fluid and install the plug. Tighten the drain plug to 13 lb ft (18 Nm).
  3. Support the transmission with a transmission jack.
  4. Remove the transmission crossmember.
  5. Disconnect the range selector cable end from the transmission range selector lever ball stud. NOTE: It is not necessary to remove the selector cable from the bracket.
  6. Remove the transmission range selector cable bracket. Reposition the bracket and cable.
  7. Remove the oil pan bolts. NOTE: The transmission oil pan gasket is reusable. Replace as needed.
  8. Remove the oil pan and gasket.
  9. Remove the magnet from the bottom of the pan, if necessary.
  10. Remove the oil filter and neck seal.
To Install:
  1. Clean the transmission and the oil pan sealing surfaces with solvent.
  2. Install the filter neck seal and filter.
  3. Install the oil pan gasket to the pan.
  4. Install the magnet into the bottom of the pan, if necessary.
  5. Install the oil pan and bolts. Tighten the oil pan bolts to 18 lb ft (24 Nm).
  6. Install the transmission range selector cable bracket. Tighten the bolts to 18 lb ft (25 Nm).
  7. Connect the range selector cable end to the transmission range selector lever ball stud.
  8. Install the transmission crossmember. Tighten the fasteners to 70 lb ft (95 Nm).
  9. Install the transmission mount nuts. Tighten the nuts to 30 lb ft (40 Nm).
  10. Remove the transmission jack.
  11. Lower the vehicle.
  12. Fill the transmission to the proper level with DEXRON® III transmission fluid.
Aug 26, 2010 | 2004 Chevrolet Avalanche
Jaguar 1998, 70000 miles. Do i need to change transmission fluid?
no no no drive drive 70 000 is nothing for that car
Apr 15, 2010 | 1998 Jaguar XJ8L
Possible transmission oil leak
absorb the frluid into a white paper towell ... if it is red in color then its transmission fluid .... if its clear or brown then its likely engine oil ... if the transmission is leaking a little then there are additives that can be put in the transmission to soften the seals .. that will often fix small seal leaks ...if the leak is slight and not damaging driveways then its not likely to cause major trouble as long as you keep your eye on the transmission fluid level .. ... if its engine oil then you could have a leaking valve cover gasket, oil pressure sending unit (sensor) ... or it could be jjust from spills as oil is changed or added .
Apr 02, 2010 | 1995 BMW 5 Series
Engine spudders when changing gears
The mechanic should check on the gears form N, R, P, 1st gear, second, third gear of the transmission . you also have to check the oil seals of the gears of the transmission.Don't forget to check also the shift level and the shift fork of the transmission.check the said gears ,the shift fork ,the shift level and the oil seals if they are worn out or destroyed you should replace them.Most of the time if the engine spudders when changing in gears it means that there is a problem in the oil seals of the transmission gears . Don't forget to check also the transmission bearing to be sure. Because it is spuddering .
Sep 04, 2009 | 2002 Ford Mustang
Changed the oil yesterday in my 2003 cts caddy and today the tranny is slipping, could oil change have anything to do with this
Engine and transmission are completely sealed off from one another. No way changing the engine oil will affect the transmission unless a brain sturgeon put engine oil into the transmission by mistake. If you did the service, you know that didn't happen.
Jul 29, 2009 | 2003 Cadillac CTS
Garden Logo
75 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
