Why won't my Westinghouse VR4090 TV turn on
Has no power with remote or button on side of TV
  • 3 Answers
SOURCE: Westinghouse LTV-19W6 TV Won't change channels
An email from Westinghouse that fixed the problem for me.
Thank you for your inquiry.
We apologize for any inconvenience in waiting for our response, but below is what I can suggest to move forward.
It appears all you need to do is run a channel scan on the unit. Once you have run a channel scan, you will be able to scroll through the channels using the channel up and down buttons.
If you have any further questions, you may contact us through email, or by calling us toll-free at 1-866-287-5555, between 9am and 9pm Eastern Standard Time, Monday through Saturday. One of our technicians will
assist you.
Posted on Dec 04, 2008
stonephoenix
  • 563 Answers
SOURCE: westinghouse LCD power light but wont turn on
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. Since you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 29, 2009
  • 117 Answers
SOURCE: Westinghouse Flat Screen TV will not power on
caps in power supply
Posted on Jun 23, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a Westinghouse W3223 TV which has decided
This going to be tough one to figure out, but at least the back light inverter board and power supply are working, unhook it at least 1/2 hour?
You may have bad main logic board problem. Try reading my guide here and see how much the main baord may cost you.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 25, 2010
Testimonial: "Thanks very much! That seems to have worked."
chesterpendi
  • 195 Answers
SOURCE: TV won't turn on
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Posted on Nov 29, 2011
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
I have a Westinghouse LCD tv and i lost the remote but in trying to run auto scan and it keeps telling me to press enter but I don't know how to
WESTINGHOUSE LCD-TV USER MANUAL Pdf Download.
www.manualslib.com > ... > Flat Panel TV > LCD-T
Westinghouse Digital 27'' Wide-Format LCD - TV User's Manual. ... the analog cable or TV antenna wire (not included) directly to this LCD-TV antenna input. ... a list of video sources using the SOURCE button located on top of the LCD-TV.
images for Westinghouse LCD tv enter button location
Sep 28, 2015 | Westinghouse Televison & Video
Westinghouse tv, remotes do not work on it
Each tv remote has a code list....you must find the code that corresponds withe the Brand of tv and enter the code then ALL the buttons will function properly
Mar 06, 2014 | Westinghouse Televison & Video
My westing hous hdtv is stuck on channel 35-3 and will not switch to another channel, the remote doesn't work and neither do the buttons on the side of the tv, the power button works but won't
Try to unplug power from set for a while and plug back to reboot--immediately delete that channel from the set's memory as it may contain signal that is causing this.
Also look to see if the set has a feature to lock out the buttons and or the remote control---a few do.
Most likely something in the signal for that set caused the set to lock up.
Sep 02, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My Westinghouse LD-325 series LED TV will not shut off/on with the side button but it will respond to the remote OR by pressing the top two button at the same time. By pressing the top two buttons (m
one or more of the tiny switches on that board with the controls is bad--either replace the board with the controls or just use the remote.
The plastic buttons will seem fine--it is the tiny switches under them that causes this issue.
May 03, 2012 | Westinghouse 32-inch Led-lcd Tv - 720p...
Had electrical storm last night. Tv shows the Westinghouse symbol, nothing else. This is when it is turned off. When you turn it on (from the tv, remote won't work at all), symbol disappears for 30...
If your TV has a reset switch on the back, use it. If not, Unplug the TV, hold the power button down for 30 seconds, let it go and remain unplugged for another 5 minutes or so.
Plug it back in, and see what happens. Try changing the inputs/channels/etc to see what happens. If you're still having this issue, Take your TV in for repair.
- Sidenote, a $25 power bar with built in protection curcuits are the easiest way to protect your equipment from this kind of thing, and quite a bit cheaper than forking over $300 for a new TV everytime there's thinder and lighting.
May 11, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
White westinghouse tv code for remote control? And the procedure to program it.
pepelule
Here are the codes for your White Westinghouse TV: 719, 500, 659, 664, 670, 672, 674
I have also included the instructions for programming the remote to your TV. I hope this helps.
  • Remotes: Basic (Television Only)
    1. Turn the Television On
    2. Press and Hold the TV Power button for three seconds until the LED flashes
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press OK. Note: The LED will flash three times.
    5. Test functionality with the TV
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
Oct 25, 2010 | DISH Network IR Remote Control
Remote good but will not work with Westinghouse LTV 32w1
I fixed it by powering off the tv and waiting a couple of minutes and powering it back up. I should have thought of that first!
Apr 29, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
