Question about HP Mini 110-1037NR Netbook
How to restore hp mini original settings - HP Mini 110-1037NR Netbook
3 Suggested Answers
navin2004536
  • 63 Answers
SOURCE: I couldn't restore my mini hp. How to restore
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Posted on Mar 20, 2010
hunter19_46m
  • 7482 Answers
SOURCE: restore original setting on HP Mini 1000
Hi schnezz23...
Try these solutions to your problem
Start your computer in the Safe Mode.
To start in Safe Mode.
Turn your computer on.
Keep tapping F1, F2 or F8 (depending on your computer) while the computer is starting up
When the computer starts select Safe Mode
1. Uninstall any softwear you may have put on the computer before the problem started.
2. Do a complete System Restore: Start>All Programs>Accessories>System Tools>System Restore.
This will bring your system back to a time before you installed the softwear or Microsoft installed drivers,etc.
Note: Just be sure to use a date in a darkened box, that is before your trouble start date.
When you have done the above, restart the computer and if your still having the problem, then the installed drivers,updates,softwear,etc might have
corrupted the Operating System.
If that happened then that means either repair or reinstall the operating system.
You will need to do the following:
1...Repairing the Operating System...
A...You will have to have the Operating Dics that came with the computer.If you did not make any or none has been made since you have had your computer, then you may be able to make the CD/DVD's for your computer.
Check in the Programs and see if there is a program that will allow you to make a back-up CD/DVD's for your system.
Note...If you do not have the disks that came with your computer or the ones you should have made when you first got your computer...then you will have to go to the manufacture's webpage and see if they have a recovery disk available for your computer, if they do not a recovery disks available then you can also try ebay to locate the recovery disks.
The original disks will have your product key number that came with the computer, you can also find it on the tower, or under the bottom of your laptop, or maybe the piece of paper that the CD orginally came in may have the number on it.
You can also download a small program and it will tell you your product key number.
Go to the following webpage to download your FREE key finder.
http://www.magicaljellybean.com/keyfinder/
B...You will now insert the disc into the CD/DVD player
C...Restart the computer
D...When the window opens that tells you to press "Any" key, you will press any key you want to press.
E...If you do not receive a message that says "press any key to boot from CD", then then the computer is not ready to boot from a cd.
To correct this problem you will have to go into your computer's Bios and change the computer to boot from a CD.
To get into the Bios, shut the computer off,restart, while the computer is starting up keep tapping F1 as the computer is starting up.
When you are in the Bios, select to boot by CD by moving the cursor with the direction arrows on the keyboard.
Once you have selected to boot by cd the exit and restart the computer...the disc is already in the cd/dvd player.
Your system will then boot from the cd.
F...After a minute or less it should ask you if you want to Quit Repair, or Continue.
You will select Repair this time, but you may have to come back here and select Install if the repair does not work.
It will ok the agreement document if it asks you too.
Tap F8 on your keyboard to pass it when ready.
It will ask you if you want to Install, Repair, Delete Partition, or Quit.
Select Repair
Inside the box there will be one or two partitions.
Choose the largest partition.
After you have chosen the largest partition, you will then press the "r" key to start the repair
After the repair is complete, then you will need to restart your computer.
G...Computer Restart
After the repair is complete, shut the computer down (the computer will shut down a few times during the installation of the operating system
that is normal).
Then restart your computer, when the computer restarts it will have a box to put your product key...put the product key in the box and click.
The computer should start up and run as if it was a new computer.
You do not need to re-register
You can now remove the disc.
If this fails to clear your problem then you may have a hardware problem.
It could be faulty ram
If you still have the same problem, then you have two choices.
1.Reinstall the entire Operating System and you may have to update some drivers.
This will require you to go back to the start of the repair info and select Install instead of Repair.
2..Take your machine in to have the hardware tested.
Keep in mind that if you do a complete reinstall of the Operating System you will lose all the information on the computer,such as pictures, programs, videos, everything you installed will be gone.
Please take time to rate me four thumbs up
Posted on Sep 15, 2011
Need too restore to factory
The HP Mini laptop comes with either the Windows 7 or Windows Vista operating system.
You can restore the HP Mini to its factory settings using the laptop's recovery partition.
Restoring the HP Mini to its original factory settings will get rid of hard to eliminate viruses on the laptop's hard drive.
A factory restoration is also a good way to get rid of older files still stored on the computer that you no longer need and start with a clean slate.
Windows Vista
Click "Start" in the lower-left corner of your HP Mini Windows Vista home screen, then type "Recovery" into the Search box at the bottom of the Start menu. Click "Recovery Manager" in the list of options that appears above the Search box. The HP Recovery Manager will open. Click "Advanced Options" and then "System Recovery." Click "Next." Your HP Mini will restart. The HP Recovery Manager will open up automatically after the restart is complete. Click "System Recovery," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore. Select "Recover without backing up your files," and then click "Next." The restoration process begins. This could take between 30 and 90 minutes, depending on the of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows Vista. Windows 7
Click the "Start" icon in the lower-left corner of your HP Mini Windows 7 home screen. Click "All Programs" and then click "Recovery Manager." Click "Recovery Manager" again to open the HP Recovery Manager program. Click "System Recovery" from the list of options beneath the "I need help immediately" section on the left side of the program. The HP Mini will automatically restart and open the HP Recovery Manager. Click "System Restore," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore. Select "Recover without backing up your files," and then click "Next." The restoration process could take between 30 and 90 minutes, depending on the of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows Vista.
b>
Feb 04, 2013 | HEWLETT-PACKARD HP Mini 5101 Netbook
How do i restore my hp mini to factory seting
I see you need help in restoring your HP mini back to defaults settings.
See this Link for further HP details on how to for proper technical troubleshooting
Oct 31, 2011 | HP Mini 1000 Netbook
How to restore HP Mini 5103 to factory settings?
Restoring the HP Mini to its original factory settings:
1. Click the "Start" icon in the lower-left corner of your HP Mini Windows 7 home screen. Click "All Programs" and then click "Recovery Manager."
2. Click "Recovery Manager" again to open the HP Recovery Manager program.
3. Click "System Recovery" from the list of options beneath the "I need help immediately" section on the left side of the program. The HP Mini will automatically restart and open the HP Recovery Manager.
4. Click "System Restore," and then click "Next." Click "No" if a message pops up on your screen asking if you want to use Microsoft System Restore.
5. Select "Recover without backing up your files," and then click "Next." The restoration process could take between 30 and 90 minutes, depending on the size of your hard drive and how much information you have stored on it. The HP Mini will restart when the laptop has been restored to its original factory settings, and you will be prompted to set up Windows.
Jun 25, 2011 | HEWLETT-PACKARD MINI 5103 Netbook
I'm lookin to restore my hp netbook to factory settings. I tried to system restore and it wasn't allowed.
if you want to do the factory default setting then you need to install the operating system with the help of recovery cd's.
if you have the recovery cd's you need to connect the usb external cd/dvd drive to the computer.
if you don't have the recovery cd's you can get it from www.hp.com or you can call hp telephone support they will help you out.
Dec 12, 2010 | HP Mini 1000 Netbook
How do I restore an HP Mini 110 Computer
To restore the original operating system and programs using the System Restore utility that is installedon the device, follow these steps:1. Turn on or restart the device, and then press the esc key repeatedly while the "F10 = BIOS SetupOptions" message is displayed in the lower-left corner of the screen.The "System Restore" page opens.2. Use the arrow keys to select System Restore, and then press enter.3. Follow the on-screen instructions to restore the system.
Doing this will wipe the hard drive.
Use the following link to download the service guide manual if needed.
http://h10032.www1.hp.com/ctg/Manual/c01895806.pdf
Dec 06, 2010 | HP Mini 110-1037NR Netbook
HP dv6000 turion processor. machine starts and all blue lights appear. dvd briefly lights and then machine turns off and then turns itself back on and repeats the process.
Preforming a system recovery to return the computer to its original condition may be necessary if the operating system is damaged, or the hard drive is corrupted, or the computer is infected by a virus.
___Also look this> HP expanded the battery pack recall on May 19, 2010. Click here to validate your battery. Performing a system recovery removes all software and files saved to the hard drive, reinstalls the original operating system, and then configures the settings for the default programs. Since the merger of Compaq and HP, several different recovery tools and processes Names for these tools include: Recovery Solution, Recovery Manager, F11, Recovery Disc, Driver and Application Recovery Disc, Roxio BackOntrack, Microsoft Backup & Restore. have been provided for recovering notebook PCs to their original operating condition. To help you select the correct recovery process, the table below identifies the different models, the time frame when they were produced and sold, plus the originally configured operating systems. Click on the name of the document in the right column for detailed information. Choose the Correct Recovery Process for Your Notebook Notebook description Recovery procedure information HP and Compaq Notebook PCs and Mini PCs shipped with a Windows 7 operating system. Recover Windows 7 Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Windows 7 instead of an HP solution. Recover Windows 7 Operating System Using Microsoft Windows Backup and Restore Presario, Pavilion, and HP Compaq Business PCs shipped with a Windows Vista operating system. Recover Windows Vista Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Vista instead of an HP solution. Recover Windows Vista Operating System Using Microsoft Windows Backup and Restore HP and Compaq Mini with Windows XP using the HP solution. Recover Windows XP Operating System On Mini Notebook Using HP Recovery HP and Compaq Mini with Windows XP using the Roxio recovery feature instead of the HP solution. Recover Windows XP Operating System Using Roxio BackOn Track HP and Compaq Mini with Mobile Internet Environment (MIE ). Recover Windows MIE Operating System On Mini Notebook Using HP Recovery Presario, Pavilion, and HP Compaq Business PCs manufactured and sold in 2006 or later . Recover Windows XP Operating System Using HP Recovery (2006 or Later)
Presario and Pavilion PCs manufactured from 2001 and 2005 . Recover Windows XP Operating System Using XP Operating System Discs (2001 to 2005)
And
Recover Applications Using Drivers and Applications Recovery Disc (2001 to 2005) Pavilion PCs with Windows Media Center edition of XP manufactured from 2001 to 2005 . Recover Windows XP Media Center Edition Operating System on HP Pavilion PCs Using HP Recovery (2001 to 2005) Compaq Presario PCs supplied with a Compaq Recovery CD and manufactured from 2001 to 2005 . Recover Windows XP Operating System on Compaq Presario PCs Using HP Recovery (2001 to 2005) Omnibook and certain Pavilion PCs manufactured pre-2001 . Recover Windows XP Operating System and Applications on HP Omnibook and Pavilion models Using HP Recovery (Pre 2001)
Nov 13, 2010 | HP Pavilion dv6000z Notebook
Need a program to restore my computer to original settings
no need program follow this steps to restore your computer.... just click start all programs Accessories then System Tools then System Restore
Jun 23, 2010 | HP Mini 1035NR Notebook
I need to restore my HP mini 210 to factory settings
try pressing f11 on boot up to see if you have a recovery manager insalled
Feb 20, 2010 | Computers & Internet
HOW CAN I RESTORE TO PURCHASE DATE?
The most effective way to restore a PC to the original settings when it was purchased is to reformat the hard drive. This would need to be performed by a technician or knowledgeable individual. You can reinstall windows easily enough yourself, though, by inserting the windows CD at startup and booting from the CD. You can then follow the instructions provided to reinstall windows.
Jan 07, 2010 | Computers & Internet
Restore factory default on HP mini laptop.
Hey guy's stop wasting your time on asking stupid questions! The hidden system recovery for HP mini 110 is this~
1st - Make it sure the Adapter and the Battery is already attached on your laptop.
2nd - Press the power button to turn it on.
3rd - When you see the HP logo on screen just easily press F6 rapidly.
4th - Stop pressing the F6 when the "Windows Starting" appears on.
5th - After that easily read all the useful instructions on how to system restore your HP mini 110.
Note: Don't mind the Dell, F10 or anything just do this ok?
Tech.Support ~ jhayr
Apr 17, 2009 | HP Computers & Internet
HP Mini 110-1037NR Netbook Logo
29 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
