Question about Miele Optima G2470SCVi Built-in Dishwasher
Dishwasber drain seal not sealing - Miele Optima G2470SCVi Built-in Dishwasher
Rubber door seal does not drain
run a wire thru it no doubt it is plugged with crud
May 01, 2016 | LG WM Washing Machines
Blanco Supreme 533-U sink drain leaking at seal
The sink basket/strainer that fits into the large hole of the sink should have either a bead of silicone sealant applied to the sealing lip of the assembly or a ring of plumbers putty. Silicone will work very well if the mating flanges are clean and dry.
With the baket in place, the rubber seal goes between the large nut and the sink. A bead of silicon on this is optional on the sink side of that rubber seal. and the nut tightened down snug , forcing some of the silicone out fro beneath the mating flange and rubber seal. Tight enough so the basket is not free to move. Be it plastic or brass/metal, that order is the same, only a plastic nut is not tightened as tightly as a metal nut would be.
On the bottom of the drain basket assembly there is a nut, to retain a plastic or brass tail piece. The plastic tail piece will have a polyetheylene "flanged washer" for a seal to the bottom of the sink basket. If it is a brass tailpiece, a rubber seal and metal nut is used with "pipe dope"/thread sealing compound used on the threads of the metal nut. With the plastic nut, you can apply a few wraps of teflon tape to the threads of the drain basket, but is not required in most cases as the poly flanged washer will form the seal. The plastic nuts should not be tightened any more than hand tight.
beneath that, the rest of the drain assembly attaches. If plastic- no more than hand tight. if metal, only about 1/4 turn past hand tight. Metal nuts and parts should use rubber gaskets/seals and the plastic parts should only use the poly tapered/lip seals.
Jan 15, 2012 | Plumbing
Replace differential seals
Do you mean the seals at the hogs head? If so you purchase them drain the fuid by removing some bolts and loosing all then pry at bottom to drain. Remove old seal clean check for wear on internal parts in the differential clean off magnet if you have one. Add new seal tighten bolts replace with dealer recommend fluids and capacities
Dec 01, 2011 | 2001 Dodge Dakota
We are having a leak on the bottom of the front loader door on the wash cycle
Check the door seal. There is a boot drain on the seal that may be clogged. This drain allows the water to drain out of the seal when water gets in there. You may need to replace the seal. HEre is a link to the part you will need.
Happy Holidays The FixYa Team
Dec 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
I purchased a moen lavatory sink pop up yesterday, installed it but water trickle down through the threads, it came with a bubble type rubber seal a flat rubber seal and a plastic washer/seal . I tried...
When you installed the new drain unit, did you put "plumbers putty" on the underside of the flange when you put it in the sink bowl? There should be a plastic type washer that gets squeezed on the plastic ball of the pop up mechanism to seal that area also. And the bubble rubber seal probably is the one to use with the flat plastic washer when tightning the big nut on the bottom. Make sure all three of these areas get sealed properly.
Aug 29, 2010 | Moen 103459 Drain Pop-UP Plug
My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
Jan 03, 2010 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Water is leaking from the front of the refrigerator freezer side onto hardwood floors it looks like it is comming from the back what would be the cause
Either the drain line is clogged and the condensation cannot drain to the pan to evaporate, or the door seal is not sealing properly allowing to much air (with humidity) into the unit creating to much condensation and overflowing the pan.
First locate the drain hole and line and make sure they are clean and clear. If you poor an 8 oz glass of water through it, it should drain out to the pan if it is clear.
If you find no clog inspect the door seals for cuts tears or any place that is not sealing properly.
Oct 12, 2009 | Refrigerators
My Water Keeps Draing
The seal for the drain is leaking. It is either the drain itself or the seal beneath the drain. If it is the seal beneath the drain then you will have water going underneath the whirlpool and causing damage; if it is the drain itself simply replace the drain as it's seal is either broken or worn.
Jul 22, 2009 | Home
Door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Aug 23, 2008 | LG WM2487H Front Load Washer
Pav2300aww spinning very slow,and not draining
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Nov 02, 2007 | Maytag Performa PAV2200
Miele Optima G2470SCVi Built-in Dishwasher Logo
26 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
