Question about Campbell Hausfeld 1800 PSI Electric Pressure Washer
I have a PW 1825 and the turbo lance is stuck in the spray gun, it will turn CW + CCW but it will not be pulled out. I've turned it CCW and pulled with all my might but it will not budge! Anybody know what's up?
2 Suggested Answers
  • 905 Answers
SOURCE: Campbell Hausfield Pressure washer model
Most likely, the housing has split and seal is not being made. There is a chance that the hose is leaking where the fitting is crimped on (my experience, but different pressure washer). Are you able to see a leak when turned off but garden hose is connected and turned on?
Is it possible that water was still in the hose / gun and froze while it was in storage?
Posted on Aug 25, 2010
Have a small safe with a three number combination. I am not sure how the numbers should be rotated.
Depending on the unit,, Make , Model etc.
It is usually CCW, CW, CCW sometimes 4 rotations to clear
go to first number, then 3 rotations CW to the next number, then 2 rotations CCW to the last number, rotate CW till the tumbler stops,
Then pull the handle to open, if in doubt,
Call a local locksmith who sells or services the unit and ask the
procedure for that model ,
They may be able to set you straight
Aug 22, 2014 | Home Security
Tip
Fan Clutch R&R With Confidence Using Griller....Glitter Tool
...ever found you self asking which way to turn a mechanical fan clutch's inline coupling nut to remove clutch-fan assembly (It) without mangling a thread or special wrench? Well then, consider the Griller...Glitter mnemonic system described below and never fail to be "thread-wise in the know."
If you know or can bump the starter to see which way the fan spins viewed from the radiator, then knowing any or all of the easy-to-remember devices below will let you get that clutch off, or on, with confidence. For instance, with a left thread clutch nut, the installed clutch-fan assembly will always spin right/clockwise.
Remember, you only need to remember the ones that are easy to remember.
    ·GRILR
    ·GOES RIGHT? IT LOOSENS RIGHT.
    ·If fan clutch spins right/CW, turn its nut right/CW to loosen.
    ·GRITL
    ·GOES RIGHT? IT TIGHTENS LEFT.
    ·If fan clutch spins right/CW, turn its nut left/CCW to tighten
    ·GLILL
    ·GOES LEFT? IT LOOSENS LEFT.
    ·If fan clutch spins left/CCW, turn its nut left/CCW to loosen.
    ·GLITR
    ·GOES LEFT? IT TIGHTENS RIGHT.
    ·If fan clutch spins left/CCW, turn its nut right/CW to tighten.
on Jan 12, 2015 | Vehicle Parts & Accessories
Have a craftsman # 358.350880 saw will not accelerate and lacks power
Check the fuel filter, air filter, and muffler for plugging. Make sure the chain/bar is being properly sharpened, oiled, and adjusted. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. If still no help, clean the carburetor inside and out with spray carburetor cleaner. Check the diaphragm in the lower chamber for flexibility and no damage. If the H and L jet needles have been adjusted, try turning both CW to stops (lightly), then turn each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Allow the engine to warm up, pull the throttle full on, and turn the H needle CW until the engine speeds up, but still 4-strokes. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, but still allows the engine to 'follow the throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Aug 13, 2010 | Garden
Adjusting the idle jets on a homelite super 2
'L' is the idle jet screw and 'H' is the full throttle screw. Make sure the air cleaner is not clogged. Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. Start the engine and allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed up, but still 4 stroking. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine keeps running. Hope this helps!
Jun 03, 2010 | Garden
Carb adjustments/ rule of thumb
Assuming that the adjustment screws 'H' and 'L' have slotted heads, turn both CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on. Turn H CW until the engine starts to speed-up, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine keeps running.
May 21, 2010 | Husqvarna Chain Saw 20" Bar
Hard to start, and wont idle long.
Check the air cleaner and muffler for plugging first. Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. Turn the idle speed screw CW about 1/2 turn. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on and adjust the H needle CW til the engine speeds up somewhat, but is still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L needle CW until the engine runs fairly well, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops moving, but still allows the engine to keep running. Hope this helps!
May 10, 2010 | Garden
Trying to get the oil filter cap off of a 2005 Pontiac Grand Am. Am wondering if it is clockwise or counter-clockwise?
It is a right handed thread, meaning lefty-loosey, turn it to the left.Some of them do get hard to turn. Hope this helps.
May 06, 2010 | 2005 Pontiac Grand Am
I can't get the idel set on the McCulloch Mac130 chain saw. It runs wide open. When you try to idle it dies out.
Try turning the L needle CW to stop (lightly), then back out CCW 1-3/4 turns. Turn the idle speed screw CW about 1 turn. Start the engine and let warm up. Set the idle speed screw so that the engine keeps running but doesn't pull the chain. Turn the L needle CW until the engine runs fairly smoothly, yet allows the engine to 'follow the throttle'. Make sure the H needle is adjusted at full speed for 4-stroking, but immediately 2-strokes when starting to cut wood. If the above idle mix (L) adjustment doesn't help, you will likely need to clean the idle jets within the carburetor. Hope this helps!
Mar 13, 2010 | Garden
Campbell Hausfeld 1800 PSI Electric Pressure Washer Logo
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
