Question about 1995-1997 Chevy Tahoe Ignition Starter Alarm Switch
2003 chevy tahoe
I have a 2003 chevy tahoe. When you turn the key it will not start. The lights on the car do not dim, and the batterie is fine. what could it be?
    President:
  • 1,114 Answers
If it just "clicks" check starter cable. If you have an aftermarket alarm, make sure it's off. There are 2 or three ignition fuses under the hood and I think one or two on the left side dash panel at the door (open the door on driver side and you can see the plastic panel on the side of the dash directly in front of you) There maybe an Ignition relay under the hood (fuse panel) and one on the right side dash (same as left) To check the relays, it takes two people, one to turn the key and one to listen for the relay "click", if you hear it click, you have power and the relay is good. Check them all, the owners manual will give you all the exact fuse and relay locations. Beyond that, try and jump start the truck. Make sure all of your equipment is "off" Radio, A/C etc. then try and start, if the jumping vehicles RPM's drop, let them sit for a few minutes with the second vehicle running and try again. If it still won't start, and all the fuses and relays are good, you've got a bad cable from the red square batt box next to the alternator that runs to the starter, or a very loose cable, or a bad starter. I am not a mechanic, however I have owned 4 Yukons and my current one has 243k. I've seen all the quirks! (and fixed them all) Hope this helps
Posted on Jun 23, 2009
My 2003 chevy tahoe won't start in the morning
Many possible causes....Too little info to make an intelligent suggestion. Try charging the problem vehicle's battery with jumper cables for 2 minutes with the supply vehicle running at fast idle (or about 1500-2000 RPM, if it is tachometer equipped) before you try to crank the problem vehicle on a cold morning. If it starts right up, you likely have a weak battery that needs replacing.
Feb 13, 2012 | 2003 Chevrolet Tahoe
I replaced a new battery on my 2003 chevy tahoe, after I noticed it was completely drained. Now I am unable to start my vehicle. The dashboard is reading "driver unkown". How can I resyc back to...
Turn ignition key to run position so that red & yellow idiot lights stay on. Leave in this position for 10 minutes. At first you should see theft light flashing then it will go to on. Then turn key to off. Then start vehicle.
Nov 27, 2010 | 2003 Chevrolet Tahoe
2004 chevy Tahoe Z71 won't start. Vehicle is in park, lights come on and don't dim when the key is turned. Also when the key is turned there is no clicking and the started doesn't engage
Check to see if the security light is flashing. If it is turn the ignition on, but don't try to start it. let it set for ten minutes, do this three times with out taking the key out of the ignition. After the third time your vehicle should start. If not let me know and we can go from there.
Randy
Nov 09, 2010 | 2004 Chevrolet Tahoe
2003 Tahoe Z71 Will Not Start
does it crank, but not start? does it not start at all? it may be your ignition switch failing.
Mar 18, 2010 | 1995-1997 Chevy Tahoe Ignition Starter...
How do i reset the change engine oil light on a 2003 chevy tahoe
Turn your key to the on position(do not start), then push the throttle pedal to the floor three times, turn of the ignition, wait a second or twothen start the engine, this should reset it. Works on the 2000 Tahoe LT 4WD
Dec 27, 2009 | 2003 Chevrolet Tahoe
I attempted to change a left signal fuse/ car wont crank/
CHECK BATTERY CONNECTIONS AND BATTERY CONDITION
Jul 01, 2009 | 2001 Chevrolet Tahoe
03 chevy tahoe wont start
Turn on you headlights and have someone crank it. If batt is bad, the kights will dim. If you have a poor connection the lights will go out. Also, remove and clean the negative cable connection on the batt. Remove, clean and reinsta'' g lluck
Jun 05, 2009 | 2003 Chevrolet Tahoe
Chevy tahoe won't turnover, power to everything, no clicking in starter to indicate that it is the starter, nothing happens when you turn the key? any sugg My problem is similar. My 2003 4wd will start...
Next time it won't start turn headlights on and see if they dim when you turn key to start, if they dim its most likely starter, if they don't dim possible starter switch, Have you tried to start it in neutral position? Try that, if it starts in neutral than its park neutral switch, if not could be starter switch, Just make sure you chk. all fuses and any relays associated with ignition first.
Feb 15, 2009 | 2003 Chevrolet Tahoe
2003 Chevy 2500HW won't start
recheck battery cables make sure there clean and tight. sounds like its not geting good conection, or starter is bad.
Feb 01, 2009 | 2003 Chevrolet Silverado 2500HD
1995-1997 Chevy Tahoe Ignition Starter Alarm Switch Logo
2,023 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
