Question about Singer 5050 Mechanical Sewing Machine
Singer 5050 c sewing slow - Singer 5050 Mechanical Sewing Machine
SOURCE: Singer 5050
I was hoping you would have got another answer, I have a mechanical sewing machine ( Singer 5040) with the exact same problem. However, if i use the programed stitches I can sew a zigzag. If i do it manually and set the zigzag width to any width ( even the widest) I get only the same straight stitch, and no mater what length I select it is the same too, very close to gether about 1 1/2 inch stitch.
I took my entire maching apart to expose inside both top side and underneath, nothing apeared loose or broke and i oiled it up. I bought a new bobbin holder and still the same effect. So it has to be something serious is my conclusion...sounds like a trip to Sears to me...LOL
Posted on Oct 17, 2008
  • 2385 Answers
SOURCE: singer 5050
Does your sewing machine create unwanted loops or does the thread snap on the top of your machine? Does it seem like your machine does not want to work with you? Your problems could be related to tension. First off, I recommend putting a white thread in the bobbin and a black thread through the needle. This will be imperative as you will need this to learn which thread is your main problem.
When you sew, which thread is the one malfunctioning? Do you see loops of black, white or is the black snapping? This is how you will be able to pinpoint your problem for further analysis.
When you sew, which thread is the one malfunctioning? Do you see loops of black, white or is the black snapping? This is how you will be able to pinpoint your problem for further analysis. If you see loops of black, your needle tension is too loose or your bobbin is too tight. First try tightening the main dial on your machine to a higher number. If that does not work, try using a small screwdriver to turn the screw underneath the bobbin-case in the front of your machine clockwise. Please remember that even a little turn can mean everything in your work. I recommend only turning it 1/4th of a turn each time you test it. Now if the loops were white, it means your bobbin tension is too loose. Do the same as above, tightening the screw clockwise with a screwdriver. If it seems too tight, please do loosen it and try to find a happy medium between your needle thread and your bobbin thread. If the thread snaps, your tension is too tight. Do the reverse of the above. Either lower the number on your needle if the thread is snapping or turn the screw on the bobbin-case counter-clockwise. Again, each little bit of the turning counts, so only turn it about 1/4th the way. It is always good to be extra careful. Keep working with both until you get a nice even stitch. An even stitch means the black should be on the top of your fabric and white should be on the bottom. It is perfectly okay if you see a little speck of one on the other side. If all fails, try putting two drops of sewing machine oil in your machine and let it run through for about five minutes. The mechanisms might be a little overworked and are having a problem with your machine. It is good if you keep a lot of fabric scraps available in case you over oiled. You do not want to be working on a difficult project for your sewing machine only to spit some oil on it. Keep sewing on the fabric scraps until there is absolutely no residue from the oil. Putting any more that 2 drops as stated earlier might cause more problems than you expect. Always use the oil sparingly. If none of the above solutions have worked and you feel frustrated by your machine, a local Sewing Repair Shop visit should only run you about $40 and is highly recommended for your machine. A professional can tell you if what’s wrong with your machine is fixable at-home or not. A full repair for older machines before working with them is highly encouraged.
Posted on Sep 15, 2009
  • 139 Answers
SOURCE: threading a singer 5050?
http://www.singerco.com/resources/threading.html
This is an awesome site!
Posted on Apr 05, 2010
  • 139 Answers
SOURCE: How do I thread a Singer 5050 C sewing machine?
http://www.singerco.com/resources/threading.html Check out the threading diagrams on Singer's website.
  • 139 Answers
SOURCE: I purchased singer bobbins to use in my singer
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 14, 2010
Sewing slows after use
The manual: http://www.singerco.com/uploads/download/446_5040_5050.pdf
Jan 08, 2012 | Singer 5050 Mechanical Sewing Machine
I need the singer sewing machine model 5050 owners manual
You can download a free pdf file from the Singer Website, link is
http://www.singerco.com/accessories/instruction-manuals, type in the search field your model number "5050" and click "search", wait for the screen to build, it will take a few seconds but you should see a "free download" link to click, again wait for the pdf file to open up, then save it to your PC, print it out and bind it in covers if you can.
Hope this helps you out. Most Singer and White manuals are available on the Singer website.
Sep 25, 2011 | Singer 5050 Mechanical Sewing Machine
Need Singer 5050 manual - is there a free downloadable version?
Yes, go to www.singerco.com and under customer support you will see instruction manuals, then enter 5050 and you will have your free download of your manual to save to your computer.
Jan 29, 2011 | Singer 5050 Mechanical Sewing Machine
What is the part that holds on the spool of thread called on a Singer 5050?
Do you have a manual?
I checked the online manual available on the Singer site for your model and the part you mention is called a Horizontal spool pin and holder.
If you would like a copy of the manual go to the Singer site:
http://www.singerco.com/accessories/manuals.html
Type in 5050 and click on Search.
On the next page click on Free download!
Hope this helps!
Oct 17, 2010 | Singer 5050 Mechanical Sewing Machine
I bought a 5050 model on ebay and the handwheel is
Unless you want to deal with the little screws to take it apart, you may take it to an authorized singer service dealer. Look in your local yellow pages under sewing machines.
Apr 08, 2010 | Singer 5050 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
52 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
