Question about Electric Mobility Rascal Scooter Wheelchair Batteries
Rascal 200 economy scooter not working, Brand new batteries, horn works has full charge.
5 Suggested Answers
gopakumarg43
  • 74459 Answers
SOURCE: Rascal 240 scooter Battery charged ,scooter
Hello
There is an overload protection switch in it. It will look like the the protection switch that can be seen under the mixes. The picture of the overload protector is added here. Its press button will only seen outside. Just putsh it once and check. The motor has carbon brushes inside it to get armeture contact. If these burshes are worn out, the motor won't turn, and the scooter won't move. There will be two of them in opposite directions. They are replacable parts. The picture of it is also given here. Check these first. If you need anymore assistance from me, feel free to get me by FixYa.
gopakumarg43.gifgopakumarg43_0.gif\
OK
Posted on Aug 05, 2011
SOURCE: scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Posted on Aug 10, 2012
batvette
  • 16 Answers
SOURCE: rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Posted on Sep 01, 2012
aspiandy
  • 4 Answers
SOURCE: Batterie is full charge and horn will honk but the scooter motor dose not work
I have a simmerler problem
On my scooter the electric/magnetic brake got wet and the brake corroded stuck and the wires to the brake had come off.
I'm now searching for a replacement brake.
Posted on Feb 23, 2013
Trouble shoot Rascal 200 mobility scooter. Horn works. That is all.
Hi check reset circuit reset button .it might have tripped . Cheers
Nov 26, 2016 | Health & Beauty
Used scooter, new batteries that were charged off the machine when i bought it, now the rascal wont charge the batteries..any suggestions
Is there a particular battery charger for this vehicle? Can you use a car battery charger directly to the batteries?
Jul 17, 2015 | Health & Beauty
Rascal 230 wiring diagram
Check the multi pin connector on tiller and where it connects under the seat between the batteries. Most common problem.
Oct 09, 2014 | Electric Mobility Rascal Scooter...
Where is the circuit breaker on a rascal 305 scooter?
You should be able to follow the battery lines to it..
Have you checked the freewheel lever to ensure it is engaged?
Aug 23, 2014 | Health & Beauty
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
Rascal 305
Check for "stuff" binding axles, make sure all connections are tight, lubricate everything.
Apr 11, 2014 | Health & Beauty
Sometimes my electric mobility scooter acts as though it's dead - but, the batteries are fully charged and the horn will work. Other times, it acts perfectly normal. The downside is, it's left
okay now this is most likely a loose connection
does the rear axle come away from the main frame ? if so check the connectors there clean gently,,,,
Now check the battery connections does the battery pack come away from the scooter if so again check the connections here , clean and make sure connections are good.
Regards
Jan 12, 2013 | Electric Mobility Rascal Scooters,...
Rascal 600
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
Electric Mobility Rascal Scooter Wheelchair Batteries Logo
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
