Calculate gallons of a tank
A HEXAGONAL AQUARIUM. EACH OF THE SIX SIDES IS 16 INCHES BY 23 INCHES. HOW MANY GALLONS OF WATER WILL THIS FISH TANK HOLD?
  • Office Equip... Master
  • 8,068 Answers
I assume the length of a side is 16 in, and the height of the prism is 23 inches.
Volume of a prism is V_prism=(Area of base)*(height of prism)
Area of base is made up of the area of the 6 equilateral triangles with sides =16 inches. The height of such triangles is given by 8*SQRT(3).
Use the Pythagorean theorem or the trigonometric ratios to find the height of each of the 6 traingles.
Area of base =6*16*(8*SQRT(3))/2 sq in
Volume =6*8*8*23*SQRT(3) cubic inches
Calculate the value in cubic inches and convert to gallons: I leave that task to you.
Posted on May 12, 2014
How many gallons of water in a fish tank 8 feet long by 2 1/2 wide by 4 foot high
I think you will be looking at about 500 gallons.
598.4 US gallon.
498.3 UK Imperial gallon.
Jan 31, 2018 | In Office Equipment & Supplies
The coolant in mill should be mixed ratio 32 parts water and 1 part coolant.it has 99 gal and is 40% full.existing mixture has 23 pts water and 1 pt coolant.i have to get it back to 32 to 1
Add 38 gallons of water to the current mixture assuming you have a 250 gallon tank. This will bring your current ration back to 32 to 1
99 gallons / 23 = 4.3
4.3(32-23)=38.7
99 gallons + 38 gallons = 137 gallons.
250 gallons - 137 gallons = 113 gallons Left to fill
113/32 = 3.5
Add 3.5 gallons of coolant to the remaining 113 gallons of water needed to fill your tank completely.
Apr 17, 2016 | Cars & Trucks
How many gallons of water in a 4'by 24' round pool?
the volume of the tank is calculated by the formula
22/7 x 24 x 4
= 301.7143 cubic feet
1 cubic foot = 7.48052 US Gallons
therefore your tank will hold 2257 US gallons approximately
Mar 04, 2015 | Pool & Spa
How many gallons does a water tank hold
About 488 cubic feet or about 3650 US gallons.
Sep 09, 2014 | Office Equipment & Supplies
72in x 29in x 24in how many gallons calculator
72 x 29 x 24 = 50,112 cubic inches / 1728* = 29 cubic feet. There are 7.48 gallons per cubic foot, so the tank is actually 216.92 gallons, assuming the dimensions given are inside measurements. I hope you have a strong stand and floor because the water alone weighs 1735.36 pounds (8 pounds per gallon).
*12 x 12 x 12 = 1728 (cubic inches to cubic feet conversion)
Jul 17, 2014 | Aqueon All Glass Aquarium Co. 210 Gallon...
How can I properly determine the amount of watts per gallon of lighting I need for my aquarium?
How many watts you need depends on the type of plants and the volume of the tank. Here is an excerpt from an article that will help you determine proper wattage.
Instructions
Identify the species of plants you have in your tank or that you plan to put in your tank and how much light that species needs. Each species of plant will have an optimal lighting requirements, from low light to bright light. To determine the plant species, compare photos on the Aquarium Plants Photos and Profiles page of the Aqua Hobby website, or take samples of the aquatic plants to your local aquarium store for identification.
Write down how much lighting each of the plant species in your tank needs. Give each plant a rating of low, medium or bright. The books "The Complete Fishkeeper" and "Freshwater Aquariums for Dummies," as well as your local fish store, are good sources of information for this.
Review your list and determine what type of plant dominates your tank. For example, if you have mostly plants that need bright light, then use a bright-light formula. If you have an equal mix of plant lighting needs, then use a medium-light formula.
Calculate a range of watts of lighting you need for your tank with one of the following formulas, depending on the amount of light you determined you needed for your plants. For low light, multiply one and two by the number of gallons. For medium light, multiply two and three by the number of gallons. For bright light, calculate three and five by the number of gallons. For example, for a 20-gallon tank with plants that need medium light, you would get a range of 40 to 60 watts (2 x 20 = 40 and 3 x 20 = 60).
Read more: How to Determine Watts Per Gallon for Aquarium Lighting ' eHow.com http://www.ehow.com/how_8014286_determine-per-gallon-aquarium-lighting.html#ixzz23KB8HErA
Aug 14, 2012 | Fish
How do I know what size filter I need for my aquarium?
The general rule of thumb is that all of the water inside your tank should pass through the filter at least four times per hour. This equation should make it easier for you to calculate. Here is an example - a 30 gallon tank needs a flow rate of 120 gallons per hour.
Aug 14, 2012 | Fish
What is a flow rate in aquarium water pumps?
A flow rate is the amount of gallons your water pump can push in an hour. Water pump should be able to push five times as many gallons as the of the tank. For example if you have a 20 gallons tank you'll need to use a water pump with a minimum of 100 gallons flow rate.
Aug 09, 2012 | Fish
Hi i need to know how many gallons a 4ft by 2ft by 2ft tank holds thanks
Hi Kelma,
First determine the area to be filled
4 x 2 x 2 = 16 cubic ft
You need to determine how many cubic feet a gallon displaces.
Find out how many gallons the tank will hold by dividing:
Area to be filled / Displacement per gallon = Total capicity of tank in gallons
Best regards
Mike
Oct 12, 2009 | Office Equipment & Supplies
443 people viewed this question
k24674
jasbo
jasbo
