Question about Kenmore HE2 Plus Front Load Washer
Why would there be a clicking sound from the soap dispenser?
    Master:
  • 359 Answers
Good morning Sandra: Sorry for taking so long to get back to you. I wanted to think about this first and today I did my laundry. The clicking sound can be a few things. The question is, is this normal? There are solenoids near the soap dispenser that control the movement of water. Water is flushed through the soap tray at various times during the washing process. The first time to pick up pre wash soap. The second is to pick up the wash soap. The third time the bleach and finally the softener. The machine will go through these steps even if you do not have any of the above mentioned chemicals in the tray. Each one of the sections requires a separate actuator. Some may be closing while others are opening. If your machine seams to be working fine (your soap, bleach, pre wash soap and fabric softener) are gone at the end of the wash cycle then I would not be concerned. If the clicking seams to be constant during the wash cycle and this seams to be a new phenomena. You might consider calling a tech, but I would not be in a hurry to fix something that is not broken.
Best of Luck
RR
Posted on May 15, 2014
  • 62 Answers
If its' working normally and dispensing properly, I wouldn't work about it. The washer has to manage emptying the various containers at the appropriate time and you might be hearing this process.
On the other hand if this sound happens continuously all the time, there might be a problem there, maybe in the control module.
The advisers at RepairClinic.com are expert in this kind of thing, you might try them if you need further help.
Posted on May 13, 2014
  • 27 Answers
Bad dispenser motor.
Posted on May 12, 2014
    Problem Solver:
  • 11 Answers
HI there, in my own experience it could be something poking out of the drum (check for things left in the drum like bra wires etc..) and as it turns it rubs against the outer drum causing that sound or in my own case it was a cable tie rubbing on the soap dispenser draw whenever the drum was in motion! It depends really as you don't say when in the cycle it happens?
Just bought new Otto sensor soap pump & Soap is not dispensing
Same with me! And with all the postings there is not ?ONE answer., tells me something!
Apr 05, 2014 | Umbra Otto Automatic Soap Dispenser,...
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
I have the CFW-8000 washing machine. When the
It sounds like the timer showing 1:09 is the time in minutes (109 minutes = 1 hour 49minutes) which is approximately the same as your own timer shows.
The soap dispenser often gets blocked and you will have to remove it and clean away all the residual, built up soap.
It sounds like the drain plug in the base of the unit has become blocked and that is why the soap dispenser is filling with water. All the water SHOULD DRAIN THROUGH the dispenser when it washes the soap down into the washing machine.
Also sounds like your water or fabric softener is blocked too!
Take the plastic parts out and clean away all soap residues.
Nov 18, 2009 | Crosley Washing Machines
The door for the soap dispenser is stuck half open even after I ran it thru a couple of cycles
This may or may not be the answer you are looking for but I know with mine the soap dispenser will not close unless the outside dial is completely in the "off" position. Trying turning the dial clockwise very slightly. If you hear a click and it resets the soap dispenser position that should work. Otherwise I have no idea. :)
Aug 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
Jul 09, 2009 | American Standard Contemporary Kitchen...
Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Mar 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Our dish soap is not dispensing from the flip container.
sounds like you have a water circulaton issue, make sure your getting enough water in machine, and nothing is blocking the dispensor eform getting hit with the waster stream
Jan 11, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher soap not opening
These rely on mechanical timers and springs on the soap dispenser. They get a bit gunked up after a while. Don't prewash and run the the dishwasher for a few cycles with the dispenser open (put the soap tablet in the cutlery basket). If you listen to the machine you may be able to hear the click when the dispenser should open which at least tells you that it should be working
Jun 13, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Kenmore HE2 Plus Front Load Washer Logo
94 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
