Question about Air Purifiers
Could the power switch for living air xl need to be replaced due to age,moisture.etc?
    Sergeant:
  • 308 Answers
Not likely. Is the microswitch on the back where the air filter goes making contact? Is the fuse good? If it's the pc board inside, bad capacitors, bad solder connections, or even corroded contacts or broken wires could be the problem.
Posted on May 12, 2014
I have 2 Living Air XL-15 that no longer will power on. I have checked and the clip that depresses the switch is fine but nothing. How can I tell if the fuse is no good?
Continuity is one way, they need to be able to conduct. If they are ceramic- use a test meter. If they are glass, does the wire reach from end to end or it melted? Does it resemble an old flash bulb that had been used? If so, or no continuity- replace fuse.
Also clean the contacts for the ionizer plate.
Jan 30, 2012 | Alpine Air Air Purifiers
Oreck XL air purifier (Tower Model)
Is this purifier wet at all, or been in any heavy areas of moisture. This purifier is very undependable with moisture. It may just have to dry out. Let me know if this solves your problem or we can explore further options.
Please keep me updated, thanks
Apr 13, 2008 | Oreck XL Professional Air Purifier
My living air xl-15 prove it light does not come on anymore and it seems that the unit does not prodoce ozone. I tested the light in the normal postion set at 12:00 with the plate out but to no avail....
If you are sure that the plate is clean, in perfect condition, and inserted correctly, it would appear that the transformer is defective. This means that power is not going through the metal contact fingers into the plates.
The light probably has burned out. It is not essential to the working of the machine, so it isn't anything you need to be concerned about.
Vollara (formerly Alpine/EcoQuest) is no longer producing or servicing the XL-15. However, a newer version, called the Classic, is available. You can call Customer Service 800-989-2299 and they will tell you your options. Use #16618 if you need a referral number.
Jan 08, 2011 | Alpine Air XL-15 Air Purifier
I bought my Living Air XL15 in Ebay. It was
The ozone plate may need to be replaced.
Mar 01, 2010 | Alpine Air XL-15 Air Purifier
Alpine XL-15 fan has stopped working
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
No Ozone
Mine has a switch lower right hand side that will stop the ozone.
Aug 31, 2008 | Ecoquest Living Air Classic Air Purifier
Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
Living Air XL (no smell)
pull out the plates and clean contacts that touch plates with rubber eraser then put plates back in check switch on back of screen to make sure its making contact.
~~~creekkid~~~
Dec 19, 2007 | Alpine Air XL-15 Air Purifier
Alpine Air Living Air XL15 not producing Ozone or Deodorizing. New plates
Confirm that the appropriate sections of the circuitry are powered up and drawing power; check the interlock switch action; toss it back to the maker because the Hi-V transformer or ladder circuit or sense or hold caps were (if testing proves) never quite functional.
Dec 03, 2007 | Alpine Air XL-15 Air Purifier
Air Purifiers Logo
42 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
