Question about Rheem Pool & Spa
What is a pv output fault on rheem pool heater
3 Suggested Answers
  • 760 Answers
SOURCE: rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Posted on Jul 05, 2010
taran_2005
  • 10515 Answers
SOURCE: I have a Rheem pool
The heater only works when there is (FFL) Fluid Flow..through it, check the pump to see if its operating, then the line strainer to be sure its not clogged preventing water flow, then the flow switch, it may have stuck in the Low Flow position...Look all that over and get back to me. we keep going until we sort it out.
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 07, 2011
I am getting a Hi Limit 2 Fault message on my heater
overheating check gas pressure if too low will overheat if ok check manual bypass see if spring is bad also make sure filters are clean and pump is functioning ok
Sep 01, 2015 | Rheem M206A 206K BTU Pool and Spa Propane...
What could cause A Raypak 336a heater brand new i get a (pv output fault )will run for 10 min then shut off
if wired 120 volt see wiring on inside of front panel also check gas pressure sounds like safety mode
Jun 29, 2014 | Raypak Pool & Spa
Rheem M406A, HL2 fault
high limit bad check gas pressure over heated
Oct 16, 2011 | Rheem M406A 399K BTU Cupro Nickel Pool or...
My Rheem model P-M266A-EN-C is displaying this: GVC. The heater isn't working. What does this mean?
GVC means Gas Valve Closed. This fault can be caused by many different problems, or even a faulty gas valve. Here is a link to a PDF file that give a step by step troubleshooting chart. This may help put you on top of the actual problem. http://shop.solardirect.com/pdf/pool-heaters/gas-pool-heaters/raypak-r-series-oim.pdf
Sep 03, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
How do i solve a fan error code??
If the fan is running then the most likely cause is a bad pressure switch or disconnected tube between the fan and the pressure switch. I would recommend calling Rheem's technical support and have them walk you through the diagnostics. Unfortunately once a specific fault is found and resolved then other faults may be found. I hope this helps.
Aug 07, 2011 | Rheem M206A 206K BTU Pool and Spa Propane...
ROL Fault code
replace fusible link and check gas pressure and for burners clogged
Jun 06, 2010 | Rheem 266K to 399K BTU Swimming Pool...
I have a Rheem Raypack pool heater and cannot locate my manual. The model is pr266a-ep-c. Is there a way to get the manual?
If you run a search for Rheem or RayPak the site should bring you to a menu that will have most manuals.
www.raypak.com/uploads/6000.52AG.pdf
This link may help but I think it goes to an older heater, but it will give you a start.
May 08, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Pool & Spa Logo
265 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
