Question about Dewalt Porter Cable N008792 Regulator Repair Kit
I needPorter Cable PIN100 repair kit instructions
Replace speedometer cable on 1986 Honda Prelude
If just the inner part is broken, remove both ends of cable, pull out broken parts. Buy a universal repair kit at parts store and follow instructions that come with.
Jul 01, 2015 | 1986 Honda Prelude
My magnavox HDTV model #51MP392H/17 the year on the back of the tv is 2004 the picture on the screen looks like its in 3D how can i fix it myself. I tried a new cable box it only worked for a few minutes...
The convergence ICs and resistors have failed. You will need to install a convergence repair kit. The Phillips DPTV305 chassis convergence repair kit is the correct one for your magnavox. Its available at www.tvrepairworld.com and the kit contains the 2 ICs and resistors and the CD with repair instructions.
Jun 16, 2011 | Philips Magnavox 51MP392H Rear Projection...
Broken shift cable on manual trans. how do unhook cable for shifter
pull the console out and take a good look at the bushings which connect the shifter to the cables. before you buy a shift cable kit take a look at a saturn shifter bushing repair kit at a parts store or on ebay, this is a very common problem on saturn S's 91-02 and often can be fixed with the 20 dollar repair kit. look on youtube for instructions on pulling the console, there are only 4 screws, and the boots to deal with.
Dec 11, 2010 | 1999 Saturn SL
The picture has a triple image
Very common and easy fix. Install the RCA repair kit called ' ITC222 and ITC222A convergence option missing repair kit. Its available from www.tvrepairworld.com and contains the parts and the CD with repair instructions.
Jul 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I bought tv repair kit #2014 w/no instructions
Go back to the site where you bought the kit and ask them to send you the instructions again.
Feb 20, 2010 | Sony KP-57WS500 57" Rear Projection...
E74 xbox 360 AV cable?
to fix the E 74 problem, i sudgest going to http://llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm. they have a step by step solution for both the red rings of death(3, and 1) or the E 74 error. i sudgest buying the kit they sudgest, its $29.99 or so. then just follow the step by step instructions when your kit gets to your house
Feb 24, 2009 | Microsoft Xbox 360 Console
PIN100 leaves about a 1/8" of pin exposed every time.
I have seen many Porter Cable pin nailers with a bent or broken driver. Easy to check. With breakdown in hand (http://images.toolpartsdirect.com/schematics/portercable/pin100.big.pdf) remove head nut and other parts to gain access to piston/driver. (parts # 60084) Most drivers have the tip missing or driver is bent. Replace as needed. If driver looks good replace driver into cylinder and push all the way down. The driver should extend about 1/8" past nose. Check for obstruction around lower bumper. Parts are not expensice and are available at WWW.toolpartsdirect.com. Please email if you have any questions. Good luck.
Feb 16, 2009 | Porter Cable 23GA Pin Nailer Kit
Coolant Repair Kit
Its listed under the repair kit catagory. They have the instructional CD by itself or the entire coolant kit which has the coolant and instructional CD. Heres the link.
http://servicemanuals.vstore.ca/
Jul 24, 2008 | Philips Magnavox 51MP392H Rear Projection...
HDMI Cable Repair
Depending on how hard the cable was pinched you may or may not have problems HDMI cables are very insolated and it takes alot to damage one. However if there are problems the repair kits that you can buy online are very usefull and you will probably have to cut and replace the pinched part on the inside of the wires but the kits should have step by step instructions if not feel free to contact me for detailed instructions.
Good Luck,
Chris
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Dewalt Porter Cable N008792 Regulator Repair Kit Logo
26 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
