Question about RTO Basement Watchdog Sump Pump
The sump pump is "chirping" periodically
No red warning lights are on - the two lights that are on are green - operating and charging (periodically) -
  • Chris Day
    Chris Day May 12, 2014
    Hi Kim Pearlman, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Is this a new install or has the pump started chirping recently? More often than not, the issue is battery related and if a new install, could be as simple as the terminals being hooked up incorrectly.
2 Suggested Answers
glc1620
  • 8 Answers
SOURCE: watchdog sump pump want stop beeping
if you have a home entertainment system just turn it on and up kidding the sump pump for our home is always running i have never heard in beep just whines constantly Is the pump still working? I have had pumps go bad before but they never beeped they didn't do anything after burning up the motor i wonder if its a battery maybe 9v
Posted on Sep 10, 2012
Should the green light stay on on my regulator that's bolted to my generator on my 76 Harley Davidson Sportster
Hi Bryanfryman, yes the green light indicates your charging system is operating normally within factory parameters. If only the red light is on then the generator is not producing enough to charge the battery and service is required. If the red and green lights are on at the same time, then you have limited charging and if they stay on for an extended period of time generator service is required. If no lights come on while the engine is running your generator is not charging and service is required. If you have any other questions about your charging system or any other issue on your Sporty you can reach me at xlch@mail.com. Good luck and have nice day.
Jul 28, 2015 | Harley Davidson Motorcycles
Hi. I just purchased the insignia digital wireless headphones for my boyfriend and the headphones won't charge properly. It says to put the on the dock station and the red light will stay on(up to 4 hours)...
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
Dec 30, 2014 | Audio Players & Recorders
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times...
http://www.kidde.com/Documents/User-Guide-900-0102-A-ENG.pdf Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
Red LED
The red LED will flash as described below under the following
conditions:
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
Sep 09, 2013 | Kidde 9000102 Night Hawk Combination...
Have dell d610 battery light flashes 4 times red then one green, can't unplug
I would take note of the message you are getting and buy a new battery. I believe the red flashing lights mean that one or more of the cells in the battery are dying, and it's best not to turn off alarm lights like these. Did the battery hold charge for a longer period than one hour before you started to see the flashing light warning?
Apr 22, 2013 | Dell Latitude D610 Notebook
Hi, my Dyson DC16 works fine but after removing from charge base following recharge the red and green lights remain lit and the unit will not operate until i remove the battery and reconnect to vacuum,this...
If it is within the warranty period get Dyson to replace it. If not, live with it until it fails completely, then buy a Hoover. Your computer board is starting to fail. That's not repairable.
Aug 06, 2017 | Dyson DC16 Root 6 Bagless Handheld...
Watchdog sump pump want stop beeping
Sep 10, 2012 | RTO Basement Watchdog Sump Pump
Hello, what is the significance of the lights when charging? The red and the two green lights are flashing when charging. After the time charge (1 night), the Dyson DC 16 does not function, the battery...
yes the reason the green and red light were flashing the way they are is because its a warning to you that the battery is either no longer good or there is problems with your wireing. Also those vaccumes were designed to not charge when there to cold or to hot as a saftey issue.
Aug 06, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Red indicator light comes on periodically in upper left hand corner of dash; does not stay on all the time; rectangular shaped light (not oil).
Yhe indicator that you are seeing is most likely a charging system light (alternator). It could be other things like a brake warning lamp, but I don't know what king of car you are talking about, so I have no way to look it up for you.
In any case, YELLOW or AMBER lights on the dash mean that you should use caution while driving and get the car checked as soon as it is convinient for you. On the other hand, RED warning lamps mean STOP OPERATING THE VEHICLE until you have resolved the cause of the light coming on (unless you like being stranded - or worse!).
Please also review these articles:
What Else Could Be Wrong?
What To Expect From An Online Car Expert
May 29, 2011 | Oldsmobile Alero Cars & Trucks
Should the "charged" green light illuminate also
Yes. If it doesn't then the battery is too old to hold a charge.
Jan 21, 2011 | JUMP START SYSTEM
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
RTO Basement Watchdog  Sump Pump Logo
103 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
