Question about Briggs & Stratton 15,000 Watt Home Standby Generator
B&S Model 040229 12kw has LCD display with 9999 code, what does it mean. It had a dead battery
Unit has not run for two years and we bought the home and the generator came with it
  • 20 Answers
Fault codes on this unit are usually 1 thru 8, or FC_1 thru FC_8.
You will need a usable battery installed for the control panel to operate. If you still get 9999 with a good battery, you will need to test it with a known good control panel, which may be the problem.
Posted on Jul 22, 2014
2 Suggested Answers
  • 172 Answers
SOURCE: Hello,
These units are equipped with a low/no oil shutdown. When you hold the switch over to start it, it overrides the shutdown interlock until the unit builds oil pressure in the engine. When you release the switch to the run position the interlock is engaged. Ensure there is sufficient oil in the crankcase, check the wiring from the oil pressure switch to the ignition cutout-(it may have been pulled off or damaged). If that checks out, then either jump across the 2 wires at the oil sending unit or disconnect the harness from the sending unit to test to see if the sending unit is bad. Try both unless you know the switch is normally open or normally closed. Replace the sending unit if needed.
Posted on Jan 05, 2010
All i have is white screen
No, replacing the battery will have no effect. Even if the battery was dead and even removed from the unit, plugging the unit into a charger or wall adapter effectively bypasses the battery. You will see that the problem will remain. A white screen can be caused by several things:
1. A defective LCD display.
2. A boot-up issue.
3. A partially disconnected LCD display where the backlight is still connected, lighting up just the background.
Please see this site for more info on LCD & boot-up issues.
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Mar 09, 2014 | Garmin Nuvi 40
My braun 6550 model was recharged but no display seen any more. The shaver has been used for more than 7-8 years. But this time I use it when it is low battery & charging at the same time. I try to...
This shaver model was very popular back in the 1990's. They aren't meant to last more than 10 years with regular use. They can be reconditioned, as replacement parts are available, but it's probably not worth the trouble. You've put your shaver to good use--it's time for a new one. You can offer up your shaver on eBay for parts as-is and actually make a little $$ (some people can make use of the parts, for those who repair these things). I'd recommend getting an 8000 series model. They are very well made and still quite a lot cheaper than the 9000 (Pulsonic) series.
Sep 14, 2010 | Braun Flex Integral 6550 Electric Shaver
The projector is approximately 4 years old & on average runs for about 60 hours per week, 40 weeks of the year. After fitting a new lamp last October & resetting the projector, the image is still...
Additional information is required for us to assist. Can you better describe what you mean by "poor image"? Are the colors separated? Is the picture out of focus? Are the colors wrong?
Please describe the picture or post a picture of the screen if you can.
Thanks,
Dan
Feb 03, 2010 | Sanyo PLC-XP57 LCD Projector
I have bought a GE cordless phone model 29670, base unit working fine but cordless unit no sound or display even though battery charged more than 10hrs before first use.
I took the phone to the shop where I purchased, they replaced the battery cordless unit with a new one, now it is OK. All displays are perfect.
Thanks & regards
Balakrishnan.
Oct 13, 2009 | Uniden Cordless Phone
My 2008 gsxr 600 that i bought 2 days ago is running off of battery only not recharging while running. bike shuts down when battery is dead can push start but soon dies again also shows SD on the display...
Its nothing to do with the damper
The battery may not be accepting charge due to its age or condition (although as u can bump it soon after it sounds ok). Check this out with a charger & meter
There may be a bad or dirty connection somewhere between the alternator & regulator/rectifier or from there to the battery
It could also be a defective alternator winding or regulator/rectifier unit
Ride Safe
Bike-doc
Please mark this as useful (if it has been!!)
Aug 03, 2009 | 2008 Suzuki GSX-R 600
Clock and temp. display is black, not displaying anything in a lexus ls400 1992
you need a new one mines does that it only displays when its extremely hot outside. I have the same car exact year and everything
May 30, 2009 | 1992 Lexus Ls 400
Inspiron 8500 99% dead
your laotop problem most from display unit (ATI MOBILITY RADEON 9000), you need consider
1) first you need to make sure the EXT VGA diaplsy is ok or not, if both display are same problem, please do next
2) if the display card is separat to motherboard you need check the card connection with the motherboard, there is pair plug/socket
clean it and set back. still bad, need to change one
3) if the display card is on board chips you cant change it, you have to find a special technician to do BGA repair
4) if EXT VGA display normal you need check LCD cable connection and LCD panel, this step please keep in touch me
hope help you to deal well
May 14, 2009 | Dell Inspiron 8500 Notebook
Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
Sep 01, 2008 | Kenmore 62702 Microwave Oven
E4 error code
I called Uniden about the same problem.  They say it is a code that means it is defective base unit.  I had purchased it within one year and they will gladly send me a new one.  I don't know if they will offer anything beyond the one year mark.
They say it was a spike in the power lines that causes this error.
Oct 09, 2007 | Uniden TRU9488 Phone
Briggs & Stratton 15,000 Watt Home Standby Generator Logo
103 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
