Question about Samsung WA5471AB 4.7 Cu. Ft. Top Load ENERGY STAR Washer with PureCycle
Samsung washer wa5471ab leaks water after washing several loads (underneath, front left corner)
Leak usually occurs during the 4th load. Put a piece of newspaper underneath the washer to monitor and leak is on the front, left side. What could be the source of the leak? Seems to only occur after several loads are washed, regardless of cycle and water temp.
  • DeLynn Stubbs Bilyeu
    DeLynn Stubbs Bilyeu May 12, 2014
    The soap dispenser is on the back in the middle. There's a liquid bleach dispenser on the left side. I'll confirm that both aren't clogged. Thanks for the tip.
  • Debbie Holloway
    Debbie Holloway Jul 26, 2015
    If it's a large load, the drum will move during washing cycle (you can actually push it back and forth when it's empty and look) and the water that's in the bleach dispenser will drain straight through the washer onto the floor. Happened to me too. I had a blanket that I had to adjust during the cycle. Good news, there's nothing wrong with your washer!
    New Friend:
Ours was leaking and then displaying "No Fill". I found the drain hose on the left rear underside of the washer had become disconnected. We scooted the washer forward far enough to tilt it back so I could get underneath to reconnect the hose. The hose is pliable and the clamp was easy to reattach with only my hand.
Posted on Feb 15, 2015
    Problem Solver:
  • 13 Answers
The pump could be starting to wear out or it has a small crack in the housing. You will have to tip back your washer to change the pump. Someone told me pumps wear out when the loads are to big for the size of machine. Not sure if it is true???
Posted on May 12, 2014
    DeLynn Stubbs Bilyeu May 13, 2014
    Thank you. I've been wondering if the pump could be showing signs of wear and tear. The washer is only 2 yrs old, but I have washed large loads of towels the entire time, which could be part of the problem.
    Problem Solver:
  • 7 Answers
You probably have a clogged filter. It's a pretty easy fix, but can be tough to turn filter cap.
Project will take about a half hour, Tools needed 5/16' or 1/4" nut driver, or socket with extension. Flashlight, door stop or small piece of wood. Low profile tupperware container and a small trash can that can hold water. A bath size towel.
Step one: Remove the panel under the washer door, with a 5/16" or1/4" nut driver or socket driver with extention. There are three screws to remove them cover comes off.
(set screws and cover aside from where your working)
Step two: Locate on the right hand side a round pipe with a "s" looking plug, it is tight but turn counter clockwise with a good bit of pressure and it will slowly loosen up. (Have a low profile tupperware container etc to slide under the pipe to catch the water. It may be good to have a bucket or plastic trash can to dump into as small container fills up. Also a towel to help contain the spills.)
Step three: Once cap is removed, you will see a basket, pull it out and clean it out, You may find a sock, lint, paper or change, something that is causing you troubles in there.
Step Four: Wipe out, and re-assemble. replace basket, screw cap back into place, secure snugly. Then Replace cover, It is helpful to have a small piece of wood, door stop small book to wedge slightly under the panel as you re-install the screws. Also, a flashlight to help you see the holes for alignment is nice.
Good Luck.
Step two:
    Thank you. We'll check it out.
  • Mike Lee
    Mike Lee Jul 07, 2014
    I have exactly same problem, did you fix it?
  • 957 Answers
Is your soap dispenser on the left side? sometimes they get clogged and you have to take it out and clean the line that goes to the tub.
Testimonial: "The soap dispenser is on the back in the middle. There's a liquid bleach dispenser on the left side. I'll confirm that both aren't clogged. Thanks for the tip."
4 Suggested Answers
  • 574 Answers
SOURCE: not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Posted on Aug 30, 2009
SOURCE: I have a two month old Samsung WF350 front load
I just received my Samsung WD 8804 front loader washing machine, and during the 3rd wash trial, I noticed the same problem of water trickling down from the base of the front door. I took a closer look and the problem is actually due to a cracked rubber seal, which can be seen through the glass door. I have informed the technician.
Posted on Aug 30, 2010
  • 51 Answers
SOURCE: I have a Samsung Front
check your pump
Posted on May 13, 2011
Water leak at front left corner of our Samsung WF210ANW/XAA01 front load washer
You will need to order and replace the door seal, also verify the door is not loose due to worn hinges. Go to www.applienceparts.com for parts if you like.
Oct 26, 2016 | Samsung WF210ANW 3.5 cu. ft. front load...
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
Aug 06, 2014 | Samsung Front Load Washer Control Board...
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
Sep 17, 2017 | LG WM2487H Front Load Washer
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Water is leaking onto the floor underneath my Whirlpool Cabrio (top-loading).
If its a small intermittent leak from the front left corner its the tub ring, whirlpool has redesigned the tub ring to fix this concern..
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Water leaking from underneath after washer drains
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Get back with the results
regards Faggly
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Water leaking from bottom of door during wash cycle
this will more likely be your door seal open the door pull your seal so u can see inside and feel around as u look u will more than likely find a hole the water looks like it comes from somewhere else but it will be from the hole in the door seal seen this with hundreds of washers m8
Aug 26, 2007 | Kenmore 43142 Front Load Washer
Samsung WA5471AB 4.7 Cu. Ft. Top Load ENERGY STAR Washer with PureCycle Logo
333 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
