Question about Consew 206RB
How to connect knee lifter Consew 206 rb-5. Knee lifter got disconnected
The machine worked perfectly. When I was winding a thread I noticed that machine makes less noise. Then I realized why, the knee lifter got disconnected . I can't figure out how to fix.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Consew 206RB-5 knee lifter installation with measurements and pictures: http://indsew.com/tips_and_guides.asp - There is a picture of how to put it together and there is a blue print with measurements how to position it and install it.
Posted on May 16, 2016
3 Suggested Answers
SOURCE: I am wanting to know the exact way to thread my
check with consew & see if they have a operation manual or try these
websites
sew usa
sewing manuals.com
ebay
Posted on Jul 29, 2010
SOURCE: Just got a new Consew 206 but can't figure out how
First make sure your oil pan is installed. Sitting at the machine the opening should be to the right. Turn the table upside down. Then move the rod with the two brackets over the opening in the oil pan. The opening should be just below a part with a roller bearing on it. When the knee pad is moved the rod on the shaft comes in contact with the roller bearing and lifts the lever for the walking foot. The front bracket should be about 1 inch from the front of the table and the long rod centered roughly in the left third of the opening in the oil pan. Use a magic marker to mark the holes for the brackets then pre drill your holes. Test moving the rod because if it is too tight in the brackets it won't move when you move the knee pad. I used the part with the curved rod to make contact with the roller bearing. The part for the pad goes in front. Since there were no instructions and Consew was no help I figured it out by trial and error. Hope this helps.
Posted on Nov 14, 2010
Juki ddl 555 knee lifter is not lifting the foot. How can I fix it?
I imagine that it is the mechanical knee lift that you actually lift with your knee? Sometimes the screw that holds the knee lift rod comes loose a little and starts to slide in the holder. Sit on the floor where you can see the underneath of your table and use a wrench or vise grip to loosen the bracket that holds your knee lift bar with the pad on it. Move the bar to the left and retighten the screw and I think you will be ok. Sometimes if there is too much oil in your pan or you have moved the machine and some of the oil spilled out, a little oil gets out of the pan onto the bar and makes it start to slip. If that doesn't work we'll try something else.
Jun 13, 2014 | Juki MO-644D Mechanical Sewing Machine
How can I fix the knee lift that is very hard to push
how much srping tension do u have on presser ft. is the tension knob on top of machine screwed all the way down., never necessary by the way. next your arm attached to the knee lifter may be bent and not contacting the lifter bar for presser ft. get under machine and move knee lift with hand to see where contact is being made. bend accordingly. also the link from knee lift bar to link inside the back of the machine may be broken. u have to take off the back panel with all its screws. watch the gasket. you can replace the bar yourself since this will not intefer with the machine timing etc.
Jun 13, 2014 | Juki Sewing Machines
Knee lift won't engage on my Juki. Ddl-8700industrial straight stitch
tilt machine back and look at the lifter bar. try moving it now without any pressure on it. move ok then problem too much presser ft tension of the lifter plate on the vertical bar under the machine is bent or not high enough or not align with the botton of the part the machine thta connects to the presser ft. the lifter bar connected to the knee lifter can be bent to line up with the bar on the machine. go to the other side of the machine and look in thru the oil pan to see how they match up.
Apr 07, 2014 | Juki DDL-8700 Industrial Straight Stitch...
When using the knee lever, the thread tension appears to change. Is this a software problem or is there a hardware adjustment that needs to be made?
the knee lever should have nothing to do with the tension.
if the thread tension is changing without you changing it, then it sound like a software or computer part of the machine is messed up & needs to be serviced by a repair shop who have the tool to check it
Sep 15, 2011 | Bernina Sewing Machines
Just got a new Consew 206 but can't figure out how to install the knee lift onto the head. Can you help me? thank you.
Aug 14, 2010 | Consew 206RB
Just got the Consew 206RB-5 Are there any instructions how to put together the table and the machine i just got? Thanks
You need someone to do it because you have to get the motor and the belt in the correct place, you can't do it by instructions over the web
Aug 10, 2010 | Consew 206RB
I am wanting to know the exact way to thread my consew 206 rb-5. We have always had problems with it. I am wondering if that has been the problem all along.
websites
sew usa
sewing manuals.com
ebay
Jul 29, 2010 | Consew 206RB
Consew 206 rb froze up suddenly-
You may want to lean the machine back and look very, very close for a very small piece of thread jammed in that race way. Resetting the timing is something you can do but first look for the simple stuff.
Apr 27, 2010 | Consew 206RB
Tension discs/ shredding needle thread
Your knee pad raises the presser foot and in turn releases the disc tension. The mechanism for this is in the front of the machine. If you can remove a nose piece this will be a lot easier to see,
There is a pin that pushes the tension discs open and quite often this has been removed or adjusted so a to not release tension when the presser foot is raised {more likely if this was a production machine} If someone took the tension control apart to accomplish this that my guess as to question 2.
The best part about Consew is the parts are common and the whole tension assembly isn't expensive. You can find service manuals on their website (see link) http://www.consew.com/Files/112347/InstructionManuals/206RB-5.pdf
Apr 12, 2017 | Consew 206RB
Consew 206RB Logo
155 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
