Question about Sport & Outdoor - Others
What site has parts for duramaxx 55lbs motor model 90010 ?
I need the pin model number 33210193 for prop and nylon nut model number 32205192 and washer.
  • 3 Answers
SOURCE: Can't find part number
I would like you to find the bar code on your shredder. Once you find the bar code label look right under the bar code strip and get the numbers. It is a serial number.
Posted on May 02, 2008
SOURCE: Trolling motor will not spin with out being turned by hand.
This may sound really dumb but it's worth a shot. I bought a trolling motor and it did the same thing as yours. I put up with it until I broke a prop blade. When I was changing the prop I discovered about fifty feet of monofilament fishing line wrapped around the shaft, partially melted, hidden by the prop hub. Once removed, it worked fine. Hey, try it, can't hurt.
Posted on Dec 11, 2008
  • 244 Answers
SOURCE: GDO repair
If unit is pre 1993 (Safety beam era), Sears will not sell you any parts. Google Liftmaster gear kit. Buy for $25-30. Not hard if you are handy. Buy the complete kit with bearings.
Posted on Jan 15, 2009
t_vinson57
  • 58 Answers
SOURCE: Achiever, Model CCS 5000, shredder, need a part (a large nylon gear)
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
SOURCE: i cant seem to figure out how to take my prop off
I had the same problem tonight. I wound up getting it off by appling a diagional pressure to the prop. That held the shaft screw. Then my Dad turned the wing nut with a neddle nose pliars conter clockwise and it came right off.
My problem and probably yours too is once inside there is a pin holding the prop to the shaft that was broken. I don't know how to get the new pin back in since it is inside the prop with no access from the outside.
Posted on Jul 23, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minnkota endura c-50 shear pin size
    You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
    Trolling Motor Replacement Props Minn Kota Motors
    You will find prop nut kits here just follow the link.
    Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
    Need installation and adjustment manual for quicksilver power2 prop.
    What engine is this prop on? Size and Horse power? Year and make? Model number would also be a great help.
    Jul 25, 2011 | Quicksilver Mercury/Quicksilver Parts...
    I cant seem to figure out how to take my prop off my minn kota trolling motor. there is a plastic nut and a screw in the center of it. they both just turn. ive used a screw driver to turn the screw and...
    Jul 22, 2010 | Minn Kota Endura 30 Freshwater Transom...
    How to remove the prop
    there is a plastic nut that screws onto the prop shaft and needs to be unscrewed. there is also a metal pin that goes through the shaft that needs to be in place and in the right position when you replace the prop. make sure you clear out any fishing line etc that may have collected behind it when you change props.sually recommend you put a little clear silicone grease on the parts as you assemble them as well.ake sure you disconnect the power leads from the battery while your doing this to avoid injury.
    May 27, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    The prop will turn on my minn kota endura 44 but it has no power is there a shear pin on this motor
    Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
    Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
    If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
    If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
    May 04, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minnkota trolling motor prop removal
    remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
    Apr 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Take the prop off and make sure the pin that goes through the shaft is in place. The prop could also not be sitting on the pin proper.
    Nov 29, 2008 | Humminbird 575 Fishfinder
    Sport & Outdoor - Others Logo
    32 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
