Question about Video Game Consoles & Games
How do I purchase just wii remote battery and where?
  • 164 Answers
There are many options, like Amazon : http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=wii%20mote%20battery
Posted on May 14, 2014
We received the wii system w/ a battery charger included ,but there were no instructions as to whether you can recharge batts. w/o having the them in the unit ,what the red,green light means what the...
Installing the Batteries
    Important Note: If you would like to use rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
  1. Remove the battery cover on the back of the Wii Remote and insert two AA batteries, using the plus (+) and minus (-) guides in the Wii Remote's battery compartment to insert the batteries in the proper direction.
  2. Be sure to insert the minus (-) end first when inserting new batteries, and remove the plus (+) end first when replacing the batteries.
  3. Replace the battery cover.
  4. Go to the Next Step (Wearing the Wrist Strap) >
  1. Place your hand through the wrist strap and hold the remote firmly in your hand. wiiremotewrist1.gif
  2. Slide the strap lock towards your wrist so that the strap will not fall off. Do not over tighten the strap lock so that it's uncomfortable. It should be tight enough to hold the wrist strap in place. wiiremotewrist2.gif
    Go to the Next Step (Syncing the Wii Remote with the Wii Console) >
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Jan 23, 2011 | Nintendo Wii Console
Tip
Wii remote buttons are sticky or stuck down
Try cleaning the buttons of the nintendo Wii Remote using the cleaning instructions below, being sure to follow the directions carefully.
    What you will need:
  • 1 clean toothbrush (no toothpaste on it)
  • 1 cup of warm tap water
  • 1 paper towel
    Instructions:
  1. Remove the batteries from the Wii Remote.
  2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the Wii Remote in any type of liquid.
  3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the Wii Remote around the buttons.
  4. Work the bristles down around the sides of the buttons.
  5. After cleaning the Wii Remote, dry it off with a paper towel.
  6. Let the Wii Remote air dry with the buttons facing down for at least a couple of hours.
  7. Test the Wii Remote for proper response.
  8. Repeat the steps if necessary.
If the buttons are still sticky after cleaning, the Wii Remote will need to be replaced. Our experience shows that this type of problem is usually caused by physical damage and not covered under Nintendo's warranty. You can purchase a replacement at retail stores that sell Nintendo products.
on Mar 04, 2010 | Video Game Consoles & Games
I have a wii remote charger and have just purchased some rechargeable batteries but they don't appear to be charging, everything is set up correctly but remote only showing 1 light lit and then going dead
Make sure your charger is plugged in your Wii AND turned on. If you do this, the remotes should charge.
If the remotes still don't charge, there's a problem.
May 03, 2010 | Nintendo Wii Remote Controller
What is the lifespan of the Wii remote? Having problems is it the remote or docking station. Have had it for two years is it time to replace?
Normally, the Wii remote will work properly unless dropped on the floor or banged against any hard surface. The Sensor connected to your Wii can sometimes end up dying because of normal use. This can be purchased for a mear 10 dollars at any Wal-Mart. If the sensor is not the problem, make sur that you are at the same level as your sensor when playing games. If you happen to be higher or lower, your Wii remote may end up moving unvolantarily around for no reason. The Wii remote is sturdy and has never broken up for me for the past 2 ½ years. Does the problem arise only when you use the docking station battery? If so, the battery would be the problem. I have stopped using this battery because of problems like these. I would recommend recharable Ni-hM batteries instead.
Hope this helps,
Regards
Jul 25, 2009 | Intec Charge Station w/ Rechargeable...
Wii remote works with normal batteries but not with battery pack
same poblem if this is solved cud somwon plz send me the solution to jordanchattington@hotmail.com cheers
Jun 30, 2009 | Nintendo Wii Remote Controller
Wii Remote ligths do not turn on.
The same problem happened to me when i accedently spilt some water on my wii remote. Try to see if anyone in your family may have done that or if you did.
Jun 17, 2009 | Nintendo Wii Remote Controller
Wii Remote doesn't work
1. Make sure that your batteries are in correctly. See working Wiimote for reference.
2. When you sync the Wiimote, press the red button in the battery compartment and immediately there after, press red sync button in the Wii Console front panel (where the SD card goes between the Eject and Reset buttons).
3. Power off Wii console completely and restart.
4. Press any button on the Wiimote to activate.
5. If the above steps don't work, you may want to return it to the store for a replacement.
Apr 12, 2009 | Nintendo Wii Remote Controller
Some games wont register extra controllers
ress the red button inside the battery cover of the wii remote, then press the red button inside the cover at the front of the wii. do this at the wii menu to register remote 2 3 and 4
Apr 07, 2009 | Nintendo Wii Console
Wii remote
You have to get the wii remotes circuit checked by a qualified electrician, as it shoudl not do this, and is quite possibly faulty if it does do that.
May 19, 2008 | Nintendo Wii Console
Can't play with 2 players
Make sure you have paired both remotes to your Wii console.
Open the little door on the front of the Wii (under the disc slot), and open the battery cover of the Wii remote (but leave the batteries in).
Push the red button on the Wii (next to the SD card slot), then push the red button on the Wii remote (next to the batteries). You should see the Wii remote's lights blink.
Do the same for your other Wii remote.
Now on the bottom row of 4 lights on the Wii remote, one should have the first light lit, and the other should have the second light lit. You should also be able to see a cursor for each remote on the Wii Menu.
Apr 03, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
