Computer freeze's up in the middle of edit. Computer encodes media when burning blueray and then at 97% finished gives a fatal error.
    President:
  • 392 Answers
Please clarify these ...
1.) Is this the first time error is coming or from the time of installation of Blue Ray Drive .? 2.) Give ur Pc's Configuration 3.) Are you using any Third Party Tools for Writing ? 4.) Recently did u upgrade your Drivers ? 5.) Recently have you got your RAM Changed?
Posted on Jun 23, 2009
When i was replace the trailing cable my plotter writing the system error:86:01 how to solve
86:01 fatal error code resetable with power cycle- error is down to encoder not reading/ blockage on media path - encoder strip missing
1. clean and clear accuride rails ( long silver bar )
2. Clean or replace encoder strip
3. clean or replace encoder sensor
if all else fails contact Belmonte.co.uk for fast response
Jan 02, 2013 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Creator suite 8 lockup before burning
I have Easy Media Creator 8. When I try to make a Slide Show everything
works till I reach the " Burn". Then it freezes on me.
Any suggestions what is causing this problem.
Thanks.
Josie
Mar 19, 2009 | Roxio Easy Media Creator 8 Deluxe Suite...
I have a RoxionEMC 10 Suite. Whenever I attempt to burn my movie project to DVD , the software tells me 97% progree and 15% encoding. It freezes, I can't go on and I exit. What can I do to correct the...
Bro, I can fix this
Editing software is a must but can be expensive. Roxio is great.
This is my best advise to get everything you need.
Go to www.Myspace.com/KyleGallas to watch a video of a Custom Gaming Computer with Tons of editing software like Roxio...The PC has like $4,000 retail for like $659. It comes with a ton of extras like Cyberlink Power Director, 133 Nintendo DS Games, Fallout 3, Adobe CS4 Master Collection, MS Office Ultmate 2007, Roxio Ultimate 2009...and more...Nothing is trial-ware but yours forever.
Mar 16, 2009 | Roxio Easy Media Creator 10 Suite
My Disney Mix Max says that it will take wmv video files from my computer. I've tried it a few different times. It seems to put it on the device but when you try to play it my Mix Max Screen says ''File...
Download and install the Window Media Encoder.
1.1 To make WMV content, you should download Windows Media Encoder from the
Microsoft Website to download Windows Media Encoder 9 Series.
http://www.microsoft.com/windows/windowsmedia/forpros/encoder/default.mspx
File name: WMEncoder.exe
1.2 Then, install the Windows Media Encoder.
2. Procedure of convert video file to WMP9.
2.1 Open the Windows Media Encoder software
2.2 After WMV Encoder start, new session window will be show as below, select the
“Convert a file” Icon and click “OK”.
2.3 Then select and choose the input source (WMV file) and the output file on the File
Selection Dialog Box. After that click “Next”.
2.4 Select “Pocket PC” for the contents distribution and click “Next”.
2.5 Select “Pocket PC standard video (CBR)” for the video and select “CD quality audio
(CBR)” for the audio, then click “Next”.
2.6 Input the contents (i.e. Title, Author, etc) as desired then click “Next”.
2.7 When the Setting Review Dialog Box appear, click “Finish”. Then the input WMV file
will start encoding automatically.
2.8 Then press “Stop” icon as soon as encoding is started.
2.9 Then the Encoding Results will pop up on screen, click “Close” to close the
Encoding Results dialog box.
2.10 Click on “Properties” tab.
2.11 Then the “Session Properties” dialog box will appear on screen.
2.12 click on the “compression” tab and then click the “Edit” box.
2.13 For the Custom Encoding Settings, under “General”, make sure to set the media
types of Audio to “CBR”, “Windows Media Audio 9.1” and Video to “CBR”, “Windows
Media Video 9”.
Then click on the “259Kbps” tab.
2.14 Please be sure you must follow the below setting, otherwise, the DMP9050 will not play
for the WMV file.
Audio format: 128 kbps, 48 kHz, stereo CBR
Video size: 220 x 176
Frame: 30 fps
Video bit rate: 384K bps
Key frame interval: 5 sec
Decoder complexity: Simple
NOTE: Make sure the setting is correct before starting the encoding process,
otherwise, the DMP9050 will not play for the WMV 9 files.
When finish the settings, click “OK”.
2.15 Click on “Apply” to access the setting, then click on “Start Encoding”.
2.16. When the Pop up dialog box appear, click “Yes” to start the encoding process.
2.17 Encoding in progress, the process time depend on the size of WMV files.
2.18 When it is finished, the Encoding Results dialog box will appear. Click “Close” and the
output WMV file can be played by the DMP9050.
if you have Vista with Windows Media 10 or later by default, then you will need to install the Windows 9 library runtimes. It can be done. This works on XP and Vista
Mar 13, 2009 | Disney Mix Max Digital Media Player
Burning issues
Are you trying to play on a set top dvd player or in your computer ?
if it plays in your computer and not a set top box either your set top box doesn't like to play DVD-R/RW or you can change brands of media
Dec 25, 2008 | Computers & Internet
'Strobing' on finished DVD
Amy, We would need a few more details about your video in question. Origional movie filetype, method of encoding, software used to burn, capture card used to create file etc. I do know for sure that making an ISO instead of a burning the folders or video files as a data/video DVD really doesn't do anything to help you with this problem. Also are you burning a traditional DVD or like many new players will play divx, xvideo, and windows media files. All of which could be burnt to a CD or DVD, and I have seen many files act similar to what your describing. Basically try to encode the video with another program and check to make sure you are using the appropriate frames per second. Here's a link to a free encoder that really works great for me. http://flaskmpeg.sourceforge.net/ O yea if you are trying to copy a vhs to dvd or a dvd without ripping the dvd you will get uneven audio, and video problems its called MACROVISION. good luck, Hack
Jul 11, 2007 | Ulead DVD Workshop 2 for PC
Fatal error on gigabeat MEGF40S
sounds like it is the motherboard. you need to send it in for repair. thanks, connie
Jun 25, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
